Need help to propulse a small bolid
  • Thread starter Thread starter lmacintosh
The discussion revolves around finding a suitable propulsion system for a small bolid project measuring approximately 6 by 12 inches. Suggestions include using a small CO2 canister, though caution is advised due to safety risks associated with handling pressurized gases. An alternative recommendation is to utilize a small Estes A-type rocket for propulsion. The project does not require a powerful system, only enough to travel a distance of 8 meters. Safety and supervision are emphasized when integrating any propulsion method.
lmacintosh
I have some kind of bolid project (around 6 per 12 inches). The design is ok but I need to find a propulsion system.
This system doesn't have to be powerfull ; only 8 meters to traverse.
I have taken some physics courses, but I'm not an engineer and this have to be relatively easy to build
Thanks for your suggestions !
What exactly is a bolid? Is it some sort of vehicle? If so, then read the following text. If not, ignore everything I said.
A small CO2 cannister will work, though I'd recommend you have someone qualified to supervise your integration of the can into your bolid.
Mind that CO2 cans should be considered highly dangerous. If I recall correctly, a student who was experimenting with them blew his hand off, literally and painfully.
A second option would be a small Estes rocket, probably of the A-type.
Bene fortuna.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
