Need help understanding how these limits were evaluated
kostoglotov
Hi, the problem is imply to show the following
\lim_{n\rightarrow \infty} 10^n e^{-t} \sinh{10^{-n}t} = \lim_{n\rightarrow \infty} 10^n e^{-t} \sin{10^{-n}t} = te^{-t}
How can I do this? Just a hint or a first step would be great, thanks :)
I've tried to make the substitution y = ln[f(x)], but I didn't get far with that.
I'm pretty sure they used L'Hopital's Rule after bringing out ##e^{-t}##.
No typos ? Then you can just pull out the ##\ \ t\; e^{-t} ## !
Do you know the $$\lim_{ y\downarrow 0}\ {\sin y\over y }\quad {\rm ?} $$
Likes kostoglotov
That's what I ended up using :) But I'm not sure if it's ok to make the substitution n = 1/a whereby as n -> inf, then a -> 0...
I also don't understand why it is works for the hyperbolic sine, but I'm happy to just accept that it does, and maybe explore the proof that it does separately; this problem isn't part of a precalculus or limits specific study effort, it appeared as part of a challenge problem in a chapter of a differential equations text I'm working on.
For ##\sinh x \equiv {e^x-e^{-x}\over 2} \ \Rightarrow \ \sin\; i{\bf z} = i \sinh {\bf z}##
or you can use the Taylor series of ##e^x = 1 + x + {1\over 2}x^2 + ... ## to show that
$$\lim_{ y\downarrow 0}\; {\sinh y\over y }\quad = 1 $$
It is much simpler than the case of ##\sin(x)/x##. Using the definition of ##\sinh(x)## we have
\begin{array}{rcl}\sinh(x) &amp;=&amp;\frac{1}{2}(e^x - e^{-x}) \\<br /> &amp;=&amp; \frac{1}{2} [1 + x + x^2/2 + x^3/6 \cdots - (1 - x + x^2/2 - x^3/6 + \cdots)]\\<br /> &amp;=&amp; x + x^3/6 + \cdots<br /> \end{array}<br />
so ##\sinh(x)/x = 1 + x^2/6 + \cdots \to 1## as ##x \to 0##. Alternately, just use l'Hospital's rule on ##f(x) = \sinh(x)/x##.
Likes kostoglotov
  • · Replies 16 ·
