B Need some clarification to get dimensions for a volume
  • B
  • Thread starter Thread starter AjaxOfTheRockies
    Dimensions Volume
AjaxOfTheRockies
I have a volume of 0.04 cubic centimeters. I need to convert into something I can work with in my shop. Tolerance is not important.
To get dimensions of a cube with this volume, I calculated the cube-root which came out to 0.341. So, my cube would be (rounded) 3mm on a side, correct?
Next question, is what dimensions would a cylinder of 0.04 cc be? That one left me completely stumped. I see lots of instruction online on how to take a dimensions of a cylinder and calculate the volume, but nothing on the reverse.
Thanks!!
—A
[edited to correct my starting number]
Mathematics news on Phys.org
A cube of side length ##3 \ mm## would have a volume of ##0.3^3 \ cm^3##, which is ##0.027 \ cm^3##.
It depends on the shape of your cylinder: long and thin or short and fat. There are lots of different cylinders with that volume, all with a different shape.
Thanks for the info. On the cylinder, I was thinking of one near equal width/length
If the length and diameter of the cylinder are both ##l##, then the radius is ##\dfrac l 2##. The cross-sectional area is ##\pi (\dfrac l 2)^2## and the volume is ##\pi \dfrac{l^3}{4}##.
Excellent! Thank you!!
... On the cylinder, I was thinking of one near equal width/length
Just a relation that you may find interesting:
https://www.mathsisfun.com/geometry/cone-sphere-cylinder.html
In practical terms, I would carefully measure the internal diameter of a suitable cylinder that you may have available, and then calculate what height achieves the desired volume you need to work with in your shop.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
