How Do You Isolate 'v' in a Projectile Range Equation with Initial Height?
  • Thread starter Thread starter xovangam
The discussion focuses on isolating 'v' in the projectile range equation when the initial height is not zero. Participants clarify the equation and emphasize the importance of squaring both sides to eliminate the square root, leading to a quadratic equation in terms of 'v'. They explore the necessary steps to rearrange the equation and confirm that it ultimately results in a solvable quadratic form. The final expression for 'v' is derived, confirming that it can be simplified further under the assumption that all variables are positive. The conversation highlights the mathematical process and collaboration in solving the equation.
xovangam
given this formula for the range of a projectile when the initial height (y) is not zero:
Code:
d = (v * cos(a) / g) * (v * sin(a) + sqrt((v * sin(a))[SUP]2[/SUP] + 2 * g * y)
in a project I'm working on i need to compute 'v' given 'd', 'a', 'y' and 'g', so i would like to rewrite this equation in terms of 'v' - my trig identities aren't so hot, could someone possibly help me to express this equation in terms of 'v' instead of 'd' ?
TIA
*er - this was supposed to post in General Math...oops. i don't know how to move it there w/o crossposting..
Hi xovangam! :smile:
So the equation is
d=\frac{v\cos(a)}{g}(v\sin(a)+\sqrt{v^2\sin^2(a)+2gy})
Right?
The square root is the most important problem here. So you'll first going to need to rewrite your equation as
\frac{gd}{v\cos(a)}-v\sin(a)=\sqrt{v^2\sin^2(a)+2gy}
and square both sides. You'll end up with a quadratic equation in v.
is this on the right track ?
Code:
((gd/v*cos(a)) - v*sin(a))^2 = v^2*sin(a)^2 + 2gy
A = gd/v*cos(a)
B = v*sin(a)
(A - B)(A - B)
= A^2 - AB - AB + B^2
= A^2 - 2AB + B^2
(gd/v*cos(a))^2 - 2*(gd/v*cos(a))*(v*sin(a)) + (v*sin(a))^2 = v^2*sin(a)^2 + 2*g*y
=> (gd)^2/(v*cos(a))^2 - (2*gd*v*sin(a))/(v*cos(a)) + v^2*sin(a))^2 = v^2*sin(a)^2 + 2*g*y
=> (gd)^2/(v^2*cos(a)^2) - (2*gd*sin(a))/(cos(a)) = 2*g*y
how do i get v^2*cos(a)^2 out of the bottom of the fraction on the left, multiply both sides by v^2*cos(a)^2 ? it seems like I'm going to end up with 'B' = 0 in the simplified equation ? (i.e. Av^2 + Bv + C)
Looks good. So now have something of the form
\frac{A}{Bv^2}+C=D
This is very easy to solve for v! Indeed:
\frac{A}{Bv^2}=D-C
Thus
\frac{Bv^2}{A}=\frac{1}{D-C}
Hence
v^2=\frac{A}{B(D-C)}
cool. so
Code:
A = (g*d)^2
B = cos(a)^2
C = -(2*g*d*sin(a))/(cos(a))
D = 2*g*y
and thus
Code:
v^2 = (g*d)^2/(cos(a)^2*(2*g*y + (2*g*d*sin(a))/cos(a))
Seems right!
and can i further simply that to:
Code:
v = (g*d)/cos(a) * sqrt(2 * g * d * tan(a) + 2 * g * y)
If you know that everything is positive, yes.
So the equation is
Right?
No. You will end up with a quadratic equation in v^2, so if you set y = v^2 you get a quadratic in y.
RGV
RGV
If you check the solution in the previous post, you see that you do end up with a quadratic equation in v. Is the solution wrong somewhere?
The equation you wrote before had the form
A/v - Bv = sort(v^2 + c), so squaring it gives
A^2 /v^2 - 2AB + B^2 v^2 = c + v^2. Multiply through by v^2 to get a quadratic in v^2.
RGV
RGV
And in this case, it was a quadratic. Like I claimed. I don't see your point.
I was responding to the statement that it is quadratic in *v* (not v^2). Of course, that might have been a typo.
RGV
RGV
Really, excuse me, I don't understand what the confusion is here. If you square both sides of the equation and rework it a bit, then the resulting equation will be quadratic in v, no??
This is certainly not true with every such equation (where you indeed have to make a substitution), but it is true with this equation, and that's all I said...
The equation becomes A^2 - 2AB v^2 + B^2 v^4 = c v^2 + v^4, where B is not equal to +1 or -1, so the v^4 terms do not cancel.
RGV
RGV
In this case, they do! So in this case, we do have a quadratic equation. (or did I make a mistake anywhere??). I really don't see what the big deal is here.
You are right! Sorry: I was looking at the wrong equation.
RGV
In brief :
