Solving D.eq. with Homogeneous Method: Tips and Tricks for Beginners
  • Thread starter Thread starter em919
em919
I need some help to solve this D.eq. I've tried the homogeneous method but I didn't work!
Which method can I use?
y'=(-3x+4y-18)/(2x-y+7)
Hi, em919! ;)
First of all, you need to solve the simultaneous equations
-3x+4y-18 = 0,
2x-y+7 = 0.​
If the solution to this set of simultaneous equations is (x_1, y_1), you need to make a couple of changes of variables: t = x + x_1 and z = y + y_1. Your new independent variable will be t and your new dependent variable will be z; you'll see that this new differential equation in z is homogeneous. Once you solve this equation, you need to plug back into get the solution in terms of y and x.
Hope this helps. :)
Nice!
When I do this the constants go away but what should I do with the other side of the d.eq?
Differentiate both sides in z = y + y_1; you'll see that z' = y'.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
