Needing a solid example of a composite mass value
lenfromkits
Hi. I am having a bit of trouble working through all the formulas for calculating the total composite mass of moving particles. If I could just fill in this 'black and white' and very intuitive example then I will be able to use it as a guide to test everything I'm doing.
If we have 2 particles:
A: mass=2Kg, velocity=298,000km/s
B: mass=3Kg, velocity=250,000km/sThen given the kinetic energy of these particles, we know that (based on the idea that the sum of an atom's parts do not add up to the atom's total mass and that the energy involved makes up some of the mass):
mass_Total > mass_A + mass_BIn this example, what exactly would the total mass in Kilograms be?
Thanks 'sooo' much in advance to anyone who can help me with this.
Your two masses are presumably not interacting (or if they were, you would need to give more information in order to determine what the binding energy was). This is different from an atom, where there are electrical and nuclear binding energies involved.
For the noninteracting particles in your example, you can just add the relativistic mass-energies of the two particles. Each of them has a mass-energy given by m/\sqrt{1-v^2/c^2}, where m is the rest mass (e.g., 2 kg).
So, the total mass would be:
2/\sqrt{1-298000^2/299792.458^2}
=18.3168584Kg
plus
3/\sqrt{1-250000^2/299792.458^2}
=5.43576641Kg
For a total mass of:
23.7526248Kg
Thanks!
Doesn't this kind of suggest that 'relativistic' mass is LESS than 'rest' mass? :)
You need to solve:
\gamma(v_1)m_1c^2+\gamma(v_2)m_2c^2=\gamma(V)Mc^2
(conservation of total energy)
and:
\gamma(v_1)m_1v_1+\gamma(v_2)m_2v_2=\gamma(V)MV
(conservation of momentum)
You have two equations (nonlinear) with two unknowns (M and V).
You get a system of equations:
\gamma(v_1)m_1+\gamma(v_2)m_2=\gamma(V)M
Divide the first equation by the second one and you get V=\frac{\gamma(v_1)m_1v_1+\gamma(v_2)m_2v_2}{\gamma(v_1)m_1+\gamma(v_2)m_2}.
From that, you can get
M=\frac{\gamma(v_1)m_1+\gamma(v_2)m_2}{\gamma(V)}.
So:
M<\gamma(v_1)m_1+\gamma(v_2)m_2
starthaus said:
Divide the first equation by the second one and you get V. From that, you can get M The expressions are very nice.
Hmm. I think I saw all this on the Internet already. Is there any chance you can show me how to plug the numbers into it and get to the mass_total in kilograms?
You have all the information, you need to learn how to do things by yourself, it does not help you if I do all your homework.
Why did you bother responding? I asked a specific question.
You have the complete answer, you are just too lazy to finish the calculations.
=18.3168584Kg
plus
=5.43576641Kg
23.7526248Kg
Nope, this is incorrect.
starthaus said:
So:
You mean:
M>\gamma(v_1)m_1+\gamma(v_2)m_2
Passionflower said:
You mean:
no, exactly what i wrote, since \gamma(V)>1
Oh yes indeed, we have to calculate the Lorentz factor from V we get in the first formula.
This has been a very long time ago I worked with these things, a numerical refresher would be good..
Ok, so M would represent the total mass of the system right?
Let's see if I get this right, in steps:
TotalEnergy = KineticEnergy + FieldEnergy = Total Mass - ParticleMass = 17.15728546 - 5 = 6.59533939
But isn't the total energy = 23.75262485?
Something does not add up (for me of course).
yes
Ok, so that would represent the total mass of the system right?
yes
I don't think that this is correct, mass is not additive/subtractive in SR.
What is correct is:
E^2-(Pc)^2=(Mc^2)^2
where
P=\gamma(V)MV=\gamma(v_1)m_1v_1+\gamma(v_2)m_2v_2
E=\gamma(V)Mc^2=\gamma(v_1)m_1c^2+\gamma(v_2)m_2c^2
Total Rest Mass of the System: = 17.15728546
Total Momentum of the System: 22.74028327
Total Energy of the System := 23.75262485
Total Particle Rest Mass := 5
Kinetic Energy of the system:= 23.75262485 - 5 = 18.75262485
Field Energy of the system: = -6.59533939
No?
Edited: Please ignore these numbers, they are all wrong!
No?
I have no idea what you are doing, try writing down symbolic formulas and I'll tell you what you are doing wrong, it is impossible for me to tell you looking at the numbers.
I can tell you for a fact that this one is wrong:
"Kinetic Energy of the system:= 23.75262485 - 5 = 18.75262485 "
since :
KE=E-Mc^2
You are doing:
KE=E-(m_1+m_2)c^2
and that is definitely wrong.
Oops, I apologize, please forget those numbers above as I used proper velocities which messed up things big time.
Hopefully it is right now:
v1 = 0.9940210037
v2 = 0.8339102380
Calculate the gammas using (1/sqrt(1-v2)):
y1 = 9.158429219
y2 = 1.811922137
Get the momenta using (p = myv):
p1 = 18.20734201
p2 = 4.532941263
Get the total energy using (m1 y1 + m2 y2):
Et = 4.532941263
Get the total momentum using (p1 + p2):
P = 22.74028327
Get V using (P/Et)
V = 0.9573798018
Get yV
yV = 3.462220442
Get the total rest mass of the system using (Et/yV)
M = 6.860517765
Get the kinetic energy of the particles using (Ek = Et - (m1+m2))
Ek = 18.75262485
Get the field energy using (Et - M - (m1+m2))
Ef = -16.89210708
So then:
M = (m1+m2) + Ek + Ef
I looked at your update about kinetic energy. If I want the kinetic energy of the particle I take the relativistic mass (energy) and subtract the rest mass of each particle?
v1 = 0.9940210037
v2 = 0.8339102380
y1 = 9.158429219
y2 = 1.811922137
p1 = 18.20734201
p2 = 4.532941263
Et = 4.532941263
P = 22.74028327
Get V using (P/Et)
V = 0.9573798018
Get yV
yV = 3.462220442
M = 6.860517765
Ek = 18.75262485
OK, so far.
You could also write:
KE=(\gamma(V)-1)Mc^2
What is this? What physical meaning do you attach to this?
Ef = -16.89210708
So then:
If
E_f=E-M-(m_1+m_2)
then, it follows that:
M=E-E_f-(m_1+m_2)
Yes:
ke=(\gamma-1)mc^2
By definition.
Well the total rest mass of the system is not equal to the rest mass of the constituents + their kinetic energies, we should add the energy of the field as well. No?
Ef = -16.89210708
So then:
I think I know what you are trying to do.If the collision were lossless, then the kinetic energy after the collision would be:
KE=E-Mc^2
But the collision is not lossless, some energy is dissipated in the form of radiative energy (what you call "field energy"):
E_f=E-Mc^2-KE
In the above, you no longer have
KE=(\gamma-1)Mc^2
but:
KE<(\gamma-1)Mc^2
for reasons of dissipation through radiation.
I have removed a number of messages involving an overly speculative discussion.
I have reopened the thread, but if it goes anywhere other than answering the specific question asked, it will be closed again.
This is the sort of mess you get when you don't think about invariants.
The mass is given by m2 = E2 - p2 (units where c = 1).
E = \gamma m and p=\beta\gamma m, so we can work it out: the total energy is 22.7 kg, the total momentum is +12.7 kg, so the total mass is 18.9 kg.
..which is exactly the same result you get from post 5. The same calculation (based on invariants) as yours is shown already in post 14. In addition, post 5 gives you the speed after collision.
15K
