Does a Stretched Spring in a Jack-in-the-Box Weigh More Due to Negative Energy?
A jack-in-the-box with a compressed spring is theorized to weigh more due to the energy stored in the spring, aligning with the mass-energy equivalence principle. When the spring is stretched, the question arises whether it adds weight or remains lighter due to the concept of negative energy. The stored elastic potential energy in a spring, calculated as 1/2 k x^2, is always positive regardless of whether the spring is compressed or stretched. The discussion hints at a broader implication regarding the balance of mass and energy in the universe, particularly in relation to gravitational potential. The analogy serves to illustrate complex interactions between energy states and gravitational effects.
droog
I seem to recall reading an analogy describing the total mass/energy of a jack-in-the-box. This said that a compressed spring insided a box would "weigh" more than the same when relaxed (albeit immeasurable small). This makes sense given the equivalence of energy and mass. But what if the spring is stretched out (and held out inside the box). Does the box now "weigh" more again due to the energy stored in the streched spring or is the sign preserved making the whole deal "lighter". I'm sure this analogy was given by a respectable physicist when describing negative energy due to gravitational potential - I just can't recall where.
The elastic PE stored in a spring is given by 1/2 k x^2, where x is the displacement from its unstretched position. Whether compressed or stretched, the stored energy is always positive.
OK thanks. So what was the purpose of the example I wonder? I'm sure it was given to show more than just the equivalence of mass and energy. The proposition related to the cancellation of mass/energy within the totality of the universe on account of the "negative energy" contributed by the gravitational attraction of all the mass/energy.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
