New Bee question on Gauss Coordinates systems
The discussion revolves around Gaussian coordinate systems in the context of General Relativity, with participants seeking visual examples and straightforward explanations. The scope includes theoretical aspects and conceptual clarifications related to the representation of curved spaces.
  • One participant shares a resource on light cone diagrams in Special Relativity and requests links for visual examples of Gaussian coordinates.
  • Another participant suggests that Gaussian coordinates may be viewed as Cartesian coordinates adapted to curvature.
  • A participant describes a conceptual analogy using bullets to illustrate how Gaussian coordinates can be visualized, noting that in curved spacetime, these coordinates approximate Cartesian coordinates near a specific point.
  • A later reply references a text by Einstein, discussing the relationship between Gaussian coordinates and Cartesian coordinates, emphasizing that Gaussian coordinates can be associated with numerical values of points in space.
  • One participant corrects themselves, acknowledging that their earlier description pertained to Riemann normal coordinates rather than Gaussian coordinates, highlighting that Gaussian coordinates are more general and do not require specific geometric constraints.
  • Another participant reassures the first about the adequacy of their description, indicating that it was helpful for understanding Gaussian coordinates despite the initial confusion.
Participants express differing views on the specifics of Gaussian versus Riemann normal coordinates, with some confusion present regarding their definitions and characteristics. The discussion remains unresolved regarding the precise distinctions between these coordinate systems.
There are limitations in the discussion regarding the definitions and properties of Gaussian and Riemann normal coordinates, as well as the visual representation of these concepts. Some assumptions about the nature of the coordinates and their applications in curved spacetime are not fully explored.
eon_rider
Hello, :)
The below link has great examples and simple explanations of
4D space-time light cone diagrams and how they are used in Special Relativity.
http://www.phy.syr.edu/courses/modules/LIGHTCONE/LightClock/default.html
The university site above was very helpful for visualising how special relativity is graphed.
It’s all good,
But does any expert or enthusiast of General Relativity know of
any sites that show decent visual examples and straight forward explanations
of a Gauss or Gaussian co-ordinate systems? The short book I’m reading on G.R. refers to Gauss co-ordinates but does not show any good examples of what the Gauss co-ordinate graphics look like in full.
I did do a search for images of gauss co-ordinates but
came up with very little. I must not be using the best key words.
Thanks in advance for any helpful links.
Very best
Eon.
I found the short answer may be that gaussian coordinates are just Cartesian coordinates wrapped over a curvature.
or
a Gaussian coordinate system is just a curved Cartesian coordinate system
Imagine shooting 3 bullets all at right angles from each other from a point. The trajectory of the bullets will trace out the axes of a Gaussian coordinate system. You can use the "proper time" of each bullet (imagine that each bullet contains a clock, too) to mark the "tic marcs" on the coordinate axes.
When you imagine doing this in an inertial coordinate system, you get a Cartesian coordinate system. In a general curved space-time, this coordinate system comes as close as possible to a Cartesian coordinate system near the origin (the point from which the bullets were fired).
You should imagine that the bullets are flying a 'free-fall' trajectory and not hitting anything, BTW.
That makes sense. Thanks.
I'm reading "Albert Einstein's Relativity: The Special and General Theory"
A.E. writes "Under these conditions, the u-curves and v-curves are straight lines in the sense of Euclidean geometry, and they are perpendicular to each other. Here the Gaussian coordinates are simply Cartesian ones. It is clear that Gauss co-ordinates are nothing more than an association of two sets of numbers with the points of the surface considered, of such a nature that numerical values differing very slightly from each other are associated with neighbouring points " in space."
So according to the link below, the bullet's trajectory is like the "U" curve. Each "tic marc" is a part of the "V" curve and the intersections are P1, P2, Pn...etc.
Here's a link to the small chart he draws of a gassian system. http://www.bartleby.com/173/25.html
Thanks again.
eon
I have to apologize -the coordinates I were describing were actually Riemann normal coordinates, not Gaussian coordinates :-(.
It's clear from the text that Gaussian coordinates are perfectly general, the u and v curves, for instance, are not constrained to cross each other at right angles. There is also no requirement for the "tic marks" to be uniformly spaced.
No worries and no need to apologize.
I didn't see any issue with your description.
Honestly, the way you described Riemann normal co-ordinates was
close enough for a non-expert like myself, that your description appeared to work for the gaussian coordinates.
You didn't mention right angles. And your feedback did spark my own further research into some of the geometry.
Thanks for the clarification.
best,
Eon.
EDIT: oops...lol...I re-read your description.
You did mention right angles...NO Worries. Still I got it. Thanks. :)
  • · Replies 51 ·
  • · Replies 18 ·
  • · Replies 26 ·
  • · Replies 19 ·
