New regulations on maritime emissions
  • Thread starter Thread starter Dedale
    Emissions
New regulations aim to halve maritime emissions by 2050, raising questions about their feasibility and effectiveness. Some suggest alternative technologies like kites and rotorships, but savings appear modest, and gas turbines may merely shift pollution rather than eliminate it. Nuclear power is largely dismissed due to public opposition, despite its potential for significant emissions reductions. The discussion highlights that shipping contributes only 2% of global CO2 emissions, questioning the impact of these regulations amidst broader economic factors driving emissions. Achieving a 50% reduction in carbon emissions will require substantial efficiency improvements and a complete overhaul of port infrastructure for new fuel sources.
Dedale
I stumbled on a recent article on the guardian newspaper: https://www.theguardian.com/environ...m-ships-at-sea-to-be-regulated-for-first-time
I was wondering if that was realistic or just some sort of public relation stint. The regulation set a distant future date tu curb commercial ship's emissions by half. 2050
How would you do that ?
I heard about experiments with big kites or rotorships to reduce fuel consumption. But the savings were modest. Gas turbines would displace the pollution problem since natural gas extraction can pollute a lot. For example trough leaks of methane.
Nuclear ships are heavily boycotted. The nucleophobe movement does not seem to do a pause. I am aware of only one nuclear cargo and a few icebreakers in service.
Likes Evanish
As a general rule, I consider any plan that excludes nuclear power to be unserious. Considering that shipping (per the link) is only 2% of CO2 emissions, I consider discussion of it to be essentially pointless. CO2 emissions are still being driven primarily by the same economics and politics that has always driven them; very little due to concerted CO2 reduction effort.
Case in point; the US is one of the world leaders in CO2 reduction, despite not ratifying any of the treaties. How? It happened primarily on it's own, because natural gas got cheap.
Gas turbines would displace the pollution problem since natural gas extraction can pollute a lot. For example trough leaks of methane...
I don't know if that last bit is true or not (I suspect not), but regardless, natural gas only emits about 25% less CO2 than diesel, so it can't get us to a 50% reduction (unlike replacing coal, where it gets you close).
Likes Evanish
Reducing overall emissions of NOx, SOx, and particulates might be feasible. Sounds like they are not regulated now, so probably some low hanging fruit. But a 50 % reduction in carbon requires a large efficiency improvement, and that sounds tough.
Likes russ_watters
So is that a reduction for international shipping, excluding coastal maritime, inland river and lake barges and the like.?
Fishing boats?
Yachts?
Pleasure boats?
Cruise ships?
If bunker oil is to be phased out for tankers and container vessels, then the port infrastructure for fueling needs a complete overhaul.
Wonder how that is going to work out in 30 years.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
