Newton's 3rd Law Homework: How to Solve These Problems?
  • Thread starter Thread starter BriannaUND
    Homework Law
This discussion focuses on solving two physics problems involving Newton's 3rd Law and kinematics. The first problem involves a water balloon dropped from a height of 18.0 meters, where the student must calculate the time it takes to hit a professor walking below at 0.450 m/s. The second problem concerns a jet aircraft launched from an aircraft carrier, requiring the calculation of acceleration over a 94.0 m track in 2.5 seconds. The correct approach for both problems involves using kinematic equations, specifically s = (1/2)at² + v₀t + s₀, to derive the necessary values.
  • Understanding of kinematic equations in physics
  • Knowledge of Newton's 3rd Law of Motion
  • Ability to manipulate algebraic equations
  • Familiarity with basic concepts of projectile motion
  • Study kinematic equations and their applications in motion problems
  • Learn how to apply Newton's 3rd Law in various scenarios
  • Practice solving projectile motion problems with varying initial velocities
  • Explore the concept of average vs. instantaneous velocity in physics
Students studying physics, educators teaching kinematics, and anyone needing to understand the application of Newton's Laws in real-world scenarios.
BriannaUND
I'm having trouble with the following problems:
1) A student throws a water balloon down at his math professor walking on the sidewalk. He drops a balloon from 18.0 meters above the ground when the profesor is 1.00 meter from the point directly beneath the window. IF the professor is 170 cm tall and walks at a rate of .450 m/s does the balloon hit her? If not, how close does it come?
Given: height= 18 m, v (init)= 0, g= 9.8 m/s2 I don't know where to start after this though for I don't know how to figure out the velocity of the balloon!
2)A jet aircraft being launched from an aircraft carrier is accelerated from rest along a 94.0 m track for 2.5 sec. a) what is the acceleration of the aircraft, assuming its constant? and b) What is the launch speed of the jet?
For this one I calculated part a: v= 94 m/2.5 sec = 37.6 m; a= 37.6m/2.5sec = 15 m/s2. However the back of the book states that the answer should be 30 m/s2. And I'm not sure how to go about calculating part b.
Thanks for any help- i appreciate it!
for (1) Start with calculating the effective striking area from the top view.
(2) Not enough info to give numbers. What you can do is talk in terms of the relative masses of the carrier and aircraft, and use the law of Action and Reaction (Newton's 3rd Law). Then you can paste together some formulas.
What velocity do you want to figure out?? Certainly you can't figure out how far the balloon drops in a certain time by multiplying a velocity by time since the velocity is not constant. Do you know s= -(1/2)gt2+ v0t+ s0? Here v0= 0, s0= 18 m. Set s= 1.7 m, the height of the teacher and solve (-1/2)(9.8)t2+ 18= 1.7. Where will the teacher be at that time?
I presume you mean that the aircraft travels across the 94 m in 2.5 seconds from an initial speed of 0.
Your calculation, v= 94 m/2.5 s= 37.s m/s is wrong because that formula holds only for constant speed. That v is the average during the launch, not the final velocity.
Okay, same formula: s= (1/2)at2+ v0t+ s0. Here a is unknown but t= 2.5, v0= 0, s0= 0 and s= 94. Solve for a. Use that value of a with v= at to find the final launch velocity.
  • · Replies 41 ·
