Newton's Law of Cooling, find room temperature
The problem involves applying Newton's law of cooling to determine the room temperature based on the temperature readings of a pan of warm water over time. The initial temperature of the water is given as 47 degrees Celsius, with subsequent readings at 10 and 20 minutes showing temperatures of 40 and 34 degrees Celsius, respectively.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss setting up equations based on the temperature data and the exponential nature of the cooling process. There are attempts to manipulate the equations to find the room temperature, with some participants expressing confusion over the algebraic steps involved.
There is an ongoing exploration of different algebraic manipulations and substitutions to simplify the problem. Some participants suggest specific methods, such as squaring equations and substituting variables, while others express frustration with the resulting polynomials. The discussion reflects a mix of approaches without a clear consensus on the best method.
Participants are working under the constraints of the problem as posed, with no additional information provided about the constants involved in Newton's law of cooling. There is an acknowledgment of potential errors in signs during calculations, which adds to the complexity of the discussion.
hulgy
Suppose that the temperature of a pan of warm water obeys Newton's law of cooling. The water (47 degrees Celsius) was put in a room and 10 minutes later the water's temperature was 40 degrees Celsius. After another 10 minutes, the temperature of the water was 34 degrees Celsius. Find the room's temperature.
(H-Hs)=(H0-Hs)ekt
dH/dt = -k(H-Hs)
Hs is the room's temperature
H0 is the initial temperature of the water
H is the temperature of the water at time t
I'm rather at a loss at how to do this problem. I've tried setting up a system of equations and tried finding the room temperature, but that doesn't work out. So if algebra won't do it, then I'm assuming something calculus-y should. I'm just at a lost as what that is.
You have the temperatures at 10 minutes and at 20 minutes. The exponential terms are e10k and e20k which is the square of e10k . Plug in the temperature data and use that the second equation is just the square of the first one.
ehild
It doesn't work, it only leads to a polynomial that can't be factored.
If it helps at all Newton's law of cooling is dH/dt = -k(H-Hs), the equation above is derived from it.
It didn't lead to an unfactorable polynomial when I tried it. . . I ended up substituting M=e10k, which made it easier to solve (or less intimidating, anyways).
It works, just try.
Let be z=e10k. Then e20k=z^2.
You have two equations:
40-Hs=(47-Hs)z
34-Hs=(47-Hs)z^2
What about squaring the first equation and dividing by the second one?
ehild
OK..
40-Hs=(47-Hs)z
34-Hs=(47-Hs)z^2
I square the first equation
(40-Hs)^2=(47-Hs)^2*z^2
and divide by the second, so I get:
(40-Hs)^2/(34-Hs) = (47-Hs)
...FFFFFUUUUUUUUUUUUUUUUUUUUU
I was doing this all along, but I was writing some of my signs wrong... so yeah. Anyway thanks for the help, answer is -2.
11K
15K
