Newton's Law Problem: Calculating Acceleration on an Inclined Plane
  • Thread starter Thread starter Smile101
    Law Newton's law
The discussion centers on calculating the acceleration of two blocks connected by a rope over a pulley on a frictionless inclined plane. The blocks have masses m1=2.0 kg and m2=1.0 kg, with the incline set at an angle of 20 degrees. The correct formula for acceleration is derived as a=(m2g - m1gsin(θ)) / (m1 + m2), leading to an acceleration of -1.03 m/s² downward. Miscalculations in applying gravitational forces and the sine function were identified and corrected during the discussion.
  • Understanding of Newton's Second Law of Motion
  • Basic trigonometry, specifically sine functions
  • Knowledge of gravitational force calculations
  • Familiarity with inclined plane physics
  • Study the derivation of Newton's Second Law in the context of inclined planes
  • Learn about tension in pulley systems and its role in dynamics
  • Explore advanced applications of trigonometry in physics problems
  • Practice solving problems involving multiple masses and frictionless surfaces
Students preparing for physics exams, educators teaching mechanics, and anyone interested in understanding dynamics involving inclined planes and pulley systems.
Smile101
A block of mass m1=2.0 kg on a frictionless inclined plane of angle 20 degrees is connected by a rope over a pulley to another block of mass m2=1.0kg. What are the magnitude and direction of the acceleration of the second block?
a=m2g-m1gsin(angle)/ma1+m2
how would i calculate m1g and m2g in the first place?
other then that...
a=m2g-m1gsin20/2+1
Your help will beeee very appreciated seeing as I have a test on it tom!
g is acceleration due to gravity = 9.81 m/s2
so basically i would multiply mass with 9.81
m2 = 1(9.81) = 9.81
m1= 2(9.81) = 19.62
a= -19.62-(-9.81)sin20/3
a= 3.3m/s^2 (down)
but the answer is supposed to be -1.03 m/s^2 (down)
m2 = 1(9.81) = 9.81
m1= 2(9.81) = 19.62
a= 3.3m/s^2 (down)
Well for one, it seems that you switched around m1g and m2g. It should be
a=\frac{9.81-(19.62)sin20}{3}
Also, do you know how to get that formula?
a=\frac{m_2g-m_1gsin\theta}{m_1+m_2}
No i don't! But the modified version you gave me is right! I got 1.03! :) thank you soo much :cool:
If the resultant force of m2 is downwards, then for the system vertically. (T=Tension)
m2a=m2g-T
therefore on the incline, m1 moves up, so that
m1a=T-m1gsin\theta
two equations where you can eliminate T by adding them. That is how to derive that formula. It's better to know how to do these kinds of of problems from first principles than to memorize a formula
  • · Replies 21 ·
10K
