Newton's laws in variable mass systems
114 replies · 22K views
D H said:
O RLY?
Assume frame B is moving at a constant velocity V wrt frame A. Using F=dp/dt=d(mv)/dt as the definition of force (which is the context for which you asked me to provide the transformation), the force in frames A and B on object with time-varying mass is
[tex]\begin{aligned}<br /> \mathbf F_A &= \frac{d}{dt}(m\,\mathbf v_A) \\<br /> \mathbf F_B &= \frac{d}{dt}(m\,\mathbf v_B)<br /> \end{aligned}[/tex]
where [itex]v_A[/itex] and [itex]v_B[/itex] are the velocities of the object as expressed in /observed in frames A and B. Velocity transforms additively:
[tex]\mathbf v_B = \mathbf v_A + \mathbf V[/tex]
With this,
[tex]\begin{aligned}<br /> \mathbf F_B &= \frac{d}{dt}(m,\mathbf v_B) = \frac{d}{dt}(m(\mathbf v_A+\mathbf V) \\<br /> &= \frac{d}{dt}(m\mathbf v_A) + \frac{d}{dt}(m\mathbf V) \\<br /> &= \mathbf F_A + \dot m \mathbf V<br /> \end{aligned}[/tex]
YARLY! Imagine a collection of non-interacting balls traveling all uniformly relative to an inertial reference frame with a velocity V. If you mentally isolate a smaller and smaller subset of them, according to your formula, it seems there is a force acting on this subset. But, by definition, this force can not come from the neighboring points. Where does this force come from then?
Instead of using logical fallacies, Dick (post #49, red herring; post #51, appeal to ridicule), why don't you try to find the math error in post #50?
D H said:
Find the math error in post #50?
There is no math error. There is a physical error:
together with
D H said:
[tex]\begin{aligned}<br /> &= \dot m <br /> \end{aligned}[/tex]
D H said:
From [...] Marion, Classical Dynamics of Particles and Systems, [...] :
The definition of force becomes complete and precise only when "mass" is defined. Thus the First and Second Laws are not really "laws" in the usual sense; rather they may be considered definitions. Because length, time, and mass are concepts normally already understood, we use Newton's First and Second Laws as the operational definition of force. Newton's Third Law, however, is a law. It is a statement concerning the real physical world and contains all of the physics in Newton's laws of motion.​
I question Jerry B. Marion's philosophy here.
An example: it is often argued - and validly, in my opinion - that the third Law implies that centrifugal force isn't a force; centrifugal force is not part of a Newtonian force-pair, as defined by the third Law.
The third Law, like all other physical laws, serves as operational definition of the concepts it makes statements about.
It appears that Marion's underlying premise is one of dichotomy: that physics statements are either a definition, or a physical law. That whole dichotomy-attitude needs to be dropped. Physics laws are both: operational definitions and laws.
Another good one! You're just chock full of humor today, aren't you?
You can find tons of physics texts that define F as F=dp/dt, starting with Newton. That said, you can find others that define F as F=ma. You can also find others that claim that Newton's laws, strictly speaking, apply only to particles, so it doesn't matter which definition you use.
The advantage of using F=dp/dt lies in the connection to the conservation laws. The disadvantage is the force acting on a mass-varying object is frame-dependent with this definition. The advantage of using F=ma is that whether mass is constant or varying, this definition makes force frame independent. The disadvantage is the lost connection with the conservation laws. Using F=ma in conjunction with work is a bad idea for variable mass systems. It will lead to incorrect results.
This is the point. Please derive
[tex] \Sigma\mathbf{F}_{ex} = \frac{d \mathbf{P}}{d t}[/tex]
for an (open) system with variable mass.
Your point is fallacious. Specifically, it is your qualification "ex" (meaning external) on the force is that is fallacious.
So, without fallacies:
There is some larger, closed system of constant mass particles in which our somewhat arbitrary open system lives. Call the particles in our open system set A and the other particles set B. Whether a given particle is in set A or in set B varies with time. At some time t denote A(t) as the set of particles that are in set A at time t, B(t) as the set of particles in set B at time t. I'll split set B into two disjoint subsets, sets B-(t) and ΔB(t) such that B(t) = B-(t) ∪ ΔB(t). The reason for this partition of B(t) is that the subset ΔB(t) is about to join A(t): A(t+Δt) = A(t) ∪ ΔB(t) and B(t+Δt) = B-(t).
The total momenta of the particles in sets A(t) and ΔB(t) are
[tex]\begin{aligned}<br /> P_{A(t)}(t) &= \sum_{i\in A(t)} p_i(t) \\<br /> P_{\Delta B(t)}(t) &= \sum_{j\in\Delta B(t)} p_j(t)<br /> \end{aligned}[/tex]
Assuming our Δt is small, the momentum of particle i at times t and t+Δt are approximately related by pi(t+Δt) = pi(t) + Fi(t)Δt, where Fi(t) is the net force acting on particle i at time t. Expanding that net force into the contributions from each particle,
[tex]\begin{aligned}<br /> P_{A(t)}(t+\Delta t) &\approx<br /> \sum_{i\in A(t)} \left(<br /> p_i(t) +<br /> \sum_{j\in A(t), j\ne i} F_ij(t) \Delta t +<br /> \sum_{j\in \Delta B(t)} F_ij(t) \Delta t +<br /> \sum_{j\in B(t)} F_ij \Delta t\right) \\<br /> P_{\Delta B(t)}(t+\Delta t) &\approx<br /> \sum_{j\in \Delta B(t)} \left(<br /> p_j(t) +<br /> \sum_{i\in A(t)} F_ji(t) \Delta t +<br /> \sum_{i\in \Delta B(t), i\ne j} F_ji(t) \Delta t +<br /> \sum_{i\in B(t)} F_ji(t) \Delta t\right) \\<br /> \end{aligned}[/tex]
By Newton's third law, each of the following sums will vanish:
[tex]\begin{aligned}<br /> &\sum_{i\in A(t)}\sum_{j\in A(t), j\ne i} F_ij(t) \\<br /> &\sum_{j\in \Delta B(t)}\sum_{i\in \Delta B(t), i\ne j} F_ji(t) \\<br /> &\sum_{i\in A(t)}\sum_{j\in \Delta B(t)} F_ij(t) +<br /> \sum_{j\in \Delta B(t)}\sum_{i\in A(t)} F_ji(t)<br /> \end{aligned}[/tex]
Using this, and summing to form the total momentum of particles A at time t+Δt yields
[tex]\begin{aligned}<br /> P_{A(t+\delta t)}(t+\Delta t) &= P_{A(t)}(t+\Delta t) + P_{\Delta B(t)}(t+\Delta t) \\<br /> &\approx<br /> \sum_{i\in A(t)} \left(<br /> p_i(t) +<br /> \sum_{j\in B(t)} F_ij(t) \Delta t\right) +<br /> \sum_{j\in \Delta B(t)} \left(<br /> p_j(t) +<br /> \sum_{i\in B(t)} F_ji(t) \Delta t\right)<br /> \end{aligned}[/tex]
The final term, [itex]\sum_{j\in \Delta B(t)}\sum_{i\in B(t)} F_ji(t) \Delta t[/itex], will be second order assuming that the set [itex]\Delta B(t)\to\Phi\,\text{as}\,\Delta t\to 0[/itex].
Define
[tex]\begin{aligned}<br /> F_{\text{ext}}(t) &\equiv \sum_{i\in A(t)} \sum_{j\in B(t)} F_ij(t) \\<br /> \Delta m_{\Delta B(t)}(t) &\equiv \sum_{j\in \Delta B(t)} m_j \\<br /> v_e(t) &\equiv \frac 1 {m(t)} \sum_{j\in \Delta B(t)} p_j(t)<br /> \end{aligned}[/tex]
Note that by conservation of mass,
[tex]\Delta m_A(t) = \Delta m_{\Delta B(t)}(t)[/tex]
With this the total momentum of particles A at time t+Δt becomes
[tex] P_{A(t+\delta t)}(t+\Delta t) \approx<br /> \sum_{i\in A(t)} p_i(t) + F_{\text{ext}}(t) \Delta t + \Delta m_{A(t)}(t) v_e(t)[/tex]
Subtracting the momentum of particles A at time t, dividing by Δt and taking the limit Δt→0 yields
[tex] \frac{d}{dt}P_{A(t)}(t) = F_{\text{ext}}(t) + \frac{dm_A(t)}{dt}v_e(t)[/tex]
So, you couldn't derive it. Nice.
Of course not. Your equation is wrong in the context of F=dp/dt.
Why don't you derive your equation? State your assumptions and your definitions. Then use your equation to derive (a) the work performed on a variable mass system and (b) the time derivative (power) of the variable mass system's kinetic energy.
How can I derive a wrong equation?
I don't know. You tell me. I've done math while all you have done is to use fallacious arguments. The equation in post #36 is yours, not mine. Define your terms and derive that result. Then use that result to calculate (a) the work performed on the variable mass system and (b) the time derivative of the system's kinetic energy.
It seems we have misunderstood each other. The equation I posted in #36 was in repsonse to your post #35. The point I tried to make is that that equation is incorrect for open systems, which you yourself demonstrated with the derivation in step #37.
In conclusion, you were wrong in post #14 where you stated a force transformation law.
There is no error in post #14. I derived it in post #50. I challenged you to find the flaw and all you could do was use fallacious reasoning. I haven't the foggiest idea what you are going on about now. Please elaborate.
And use some math instead of fallacious arguments this time.
lol, what ever you say. I don't want to quarrel and get a ban. If someone reads this thread and knows Physics, they will draw a conclusion for themselves.
The distinction between a geometric system, and a material system is crucial to understand when dealing with Newton's second law, and what forces act upon.
A geometric system is simply a mathematically defined region within space that we designate as our system, and particles/mass may well flow into, and out of that region.
Forces do NOT act upon a mere spatial region, they act upon material particles CONTAINED within that region.
Thus, F=dp/dt is perfectly valid, as long as we are talking about a material system, i.e, which is defined by consisting of the same particles throughout time (and in the Newtonian world, thus have fixed mass).
We may perfectly well formulate a Newton's 2.law for geometric systems, and it is highly useful, for example by calculating the reaction force on a tube section through which the fluid passes.
The rate of change of momentum within a geometric system consists not only of the effects of forces acting upon (momentarily) contained particles, but also that less momentum may flow into the region than leaves it, or vice versa (momentum itself being carried by massed particles).
The following thread goes into the details:
https://www.physicsforums.com/showthread.php?t=72176
afallingbomb said:
I already posted a link to the same article in [post= 2858679]post #14[/post].
There are three camps in classical physics regarding Newton's laws,
  1. F=dp/dt=d(mv)/dt. With this definition of force, that F=m·dv/dt+v·dm/dt is a straightforward application of the chain rule. Dick: Does the chain rule not apply in physics?
  2. F=ma, even for variable mass systems. The changes in state that result from mass variations are just another external force. With this definition the equations of motion fall straight out of Newton's 2nd law. An unfortunate side effect of this definition is the loss of connection to the conservation laws. Using this definition of force to compute work is invalid.
  3. F=dp/dt, F=ma: Potato/patato. Newton's laws only apply to point masses with constant mass (e.g., Plastino & Muzzio). To this camp, there is no such thing as a variable mass system in the context of Newton's laws.
The last camp has withdrawn from the argument. The first two camps will arise at the same results if they are careful about their math.
Question: What form of Newton's Second Law is used in Hydrodynamics?
This is a meaningless position.
Let us have an object O moving at constant velocity U; no part of it is subject to any force whatsoever.
I can perfectly well construct a system containing solely of parts of this object, yet that system will experience a constant increase in momentum, with nothing resembling of a force is acting upon any part of object O.
As for this "camp":
Sure the chain rule work, as long as you use it properly.
Leibniz' rule of differentiation of an integral with moving boundaries is a fancy version of the chain rule, and that is the one to use here.
I said the same thing:
but was ridiculed by D-H.
Well, DH is dead wrong on this issue, and that is why he turns to ridicule, since he doesn't have any solid arguments.
Sorry that I didn't see that part of the previous discussion.
This is far from a meaningless position. Whether you want to call [itex]\dot m\,dv/dt[/itex] a force or not is mostly semantics. Whatever you call it, it has the units of force and affects the equations of motion just like a force. The equations of motion will be correct. The only gotcha here is that that calling this quantity a force represents a break between Newton's laws and the conservation laws.
This is the point of view taken by many, if not all, high-fidelity missile and spacecraft simulations. Those simulations don't care about the ultra high-fidelity details that can only be divined by resorting to CFD models. Those CFD-based simulations are too slow to use as the basis for long-term simulations or Monte Carlo testing. All those high-fidelity sims care about is developing the temporal history of the vehicle's state (or vehicles' states in the case of a multi-vehicle simulation).
Calling this a meaningless position is just wrong. You just have to be aware of the limitations of this position. This is not my typical take on this issue; I prefer the F=dp/dt point of view. (Although this is the approach I use when all I care about are the equations of motion).
And why should the momentum changing effect of volume expansion of your arbitrarily chosen control volume be called a "force"?
Why not call it by its proper name, namely..flux of momentum?
You might as well call a dog an apple, since both are organic compounds.
Classical mechanics, the mental framework we're in right now, is blind to other sources for change in momentum than forces acting upon particles contained within a system, along with whatever accretion of matter (carriers of momentum) to the system, for example through expansion of the volume of the geometric region we are talking about (for example having the interior region of ab expanding balloon as our control volume).
That other sources for momentum change exists as well is no good reason to make "force" into a flabby concept.
Because its a very useful concept?
Or maybe, aerospace engineers thinking that the thrust produced by a jet or a rocket is a meaningful quantity and testable quantity is just plain goofy. NOT.
Hi arildno, I remember seeing you present your definition of force before, but the textbooks I have used tend to agree with DH's definition. Do you have a supporting reference, or is this a personal approach?
DaleSpam said:
DH's definition.
Actually, I gave three:
  1. F=dp/dt (e.g., Marion, Goldstein (just double-checked; Goldstein is rather insistent that F=dp/dt is the proper form)),
  2. F=ma (e.g., Halliday&Resnick plus several engineering texts, with the mdot·v term denoted as a force)
  3. F=dp/dt=ma is a potato/patato issue because Newton's laws apply only to constant mass point masses.
I generally prefer (1) F=dp/dt because of the connection with the conservation laws. I do use (2) when the driving concern is the equations of motion.
BTW, it is rather well-known that F=dp/dt is frame-dependent. I don't get what all the hub-bub is about.
