Newton's Discovery of Mass, Force & G in SI Units
Newton determined the mass of an object using proportionality rather than established units, as the SI units for mass and force were defined much later. He understood that doubling the force would result in a doubling of momentum change, which laid the groundwork for his laws of motion. Although the modern concept of units was not developed during his time, he effectively used pounds and feet for his calculations. The relationship expressed in F=GMm/d² and the concept of gravitational force were also established after Newton's era. Ultimately, the key takeaway is that understanding physical behavior does not rely on specific units but on the principles of proportionality.
adjacent
What did Newton use to determine the mass of an object(During those days)
Even the SI unit for mass was established much time later.
The SI Unit for force was also established much later.
The G in F=GMm/d2 was discovered in Much later.
How did Newton knew that a force of 1N would accelerate a mass of 1KG to 1m/s2?
There are numerous threads here discussing what Newton actually wrote (try searching on "Principia" and maybe you can find these discussions).
As I understand it, Newton expressed the idea in terms of proportionality: twice the force causes twice the change in momentum.
The modern concept of units probably wasn't really developed in Newton's time.
the unit was named after Newton! :wink:
(and he used pounds and feet, anyway)​
You do not need to know the units to determine the laws of physical behaviour. You need to know how to 'double' the mass and to have a means of measuring force and to know how to 'double' a force.
Both of the responses above have something sensible to say and I would say the key thing is the idea of proportionality.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
