Can Night Vision Devices Convert Reflected Frequencies Back to Original Colors?
  • Thread starter Thread starter rajeshmarndi
    Color Vision
Night vision devices operate differently, with Starlight amplifying ambient light and IR units using infrared emissions or reflections. Starlight devices produce a black and white image, enhancing sensitivity, while IR devices generate monochrome signals without detecting visual colors. Color images can be created using monochrome sensors with color filters, but removing these filters improves the signal-to-noise ratio. The discussion clarifies that IR devices do not translate reflected frequencies into accurate colors, as they lack visual range detection. Overall, night vision technology focuses on light amplification rather than color reproduction.
rajeshmarndi
isn't the frequency that is reflected back to a night vision device by a source at night correspond to a particular color? Which can then be converted back to its original color?
Welcome to PF, Rajeshmarndi.
There are a lot of night vision devices, including several generations each of IR and Starlight. They don't all operate the same way.
Starlights amplify ambient light, and I don't really know anything else about them.
IR units operate through infrared emission ('passive') or reflection ('active'), which means that the 'translation' is a B&W signal. That usually comes out as a particular colour gradient which depends upon the interpretation circuitry and visual display characteristics.
Color photos are generated by using monochrome (black and white) sensors with alternating color filters and having software sort out which pixel is which color. Removing the filters and shooting everything monochrome increases the signal to noise ratio because you aren't blocking any of the signal with a filter.
So with a "starlight" device, black and white will mean higher sensitivity.
And just in case the IR part wasn't clear - for an IR device, there is no visual range color being detected so nothing to translate to accurate color.
Low light color cameras do exist as well:
Using image intensifier ("standard" night vision technology):
http://www.copst.com/media/filebank/org/F04-001-D01-B%20Lunavision%20Datasheet.pdf
http://www.laseroptronix.se/cam/CCD%20Niviscameras.pdf
Using high gain CCD:
http://www.toshiba.com/taisisd/indmed/products/pdf/ik1000me.pdf
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
