Clearing the Misconception on Light's Wave-Particle Duality
Ratzinger
There appears to be a strong and continuing miconception about light/photons as far as this so-called "duality" is concerned. Let's get ONE thing straight here - Quantum mechanics does NOT have two separate descriptions of light for when it behaves as a "wave" and when it behaves as "particles". PERIOD! It has one, and only one, consistent description for light, and that's that.
Now, after reading that, would one still want to consider light as having a "wave-particle duality"?
From the way I see it, the continuing misconception here is due to the ambiguity of the quality used in the question. We apply our classical ideas of what "wave" is, and what a "particle" is. A particle, like a grain of sand, has a definite boundary in space, i.e. a grain of sand doesn't appear spread out that it's exact shape and boundary are vague. Thus, it has what we classically define as a particle. A wave, on the other hand, can spread out over space.
Now, a photon, as a particle, was NEVER defined this way! A photon description in QM is NOT defined as having an exact shape and boundary in space. It is defined as clumps of energy. So in energy coordinates, it has definite "points", but it has no definite "size" in real space! This isn't your classical particle.
Having said that, the most common explanation for the "wave-particle duality" is that light behaves as waves in experiments such as the double slit, and behaves as particles when we do things like the photoelectric effect. Now, the fact that it is EASIER to describe an observation using one type of description while describing another observation using another type of description does NOT mean that they can't be described using ONE consistent discription. Most people often do not realize that one CAN describe interference effects (a typical wave phenomena) using photons![1] In fact, such technique CLEARLY explain diffraction patterns, and how the uncertainty principle is clearly at work. We don't normally subject students to such things because it is MORE involved than using the simple wave description. But we should not fool ourselves into thinking that the photon picture cannot be used to arrive at the idential phenomena that once thought can ONLY be described using the wave picture.
Again, one needs to learn QM and realize that there are no separate description for this wave-particle duality illusion. It is only a duality based on our pre-existing prejudice that something must either be a wave, or a particle. This "duality" thing only appears to be a major "issue" in pop-sci books and articles. It is a non-issue in QM texts.
Zz.
[1] T. Marcella, Eur. J. Phys., v.23, p.615 (2002).
1. I always thought that the word duality in QM referes to unmeasured (wave-like)/ measured (particle-like). So am I wrong?
2. Is that Marcella paper freely available on the net or another source that covers its content?
Duality means exactly that - the 'things' act like waves and particles in different experiments, double slit etc.
No idea on the Marcella
I found the quote particularly well written... just to find out that it was Zapperz who wrote it :smile:
Couldn't agree more with what he said.
But Nick Herbert describes in his "Quantum reality" the wave/ particle coexistence as unmeasured/ measured duality. Turning down the brightness until only spots are on the phosphor plate reveals particle-like reality if measurements take place. The distribution of the spots shows wave-like reality between the measurements.
So acording to Herbert there is no duality between experiments, only some experiments (double slit) reveal the crazy quantum behavior between measurements better than others (photoelectric).
The duality is mean that quantum object is not a particle and is not a wave. What is it? May be it is some-thing another? May be suitable another model? As an alternative to wave-particle duality I can consider the model based on background of pilots-waves deBroigle-Boum. In this Pilot Model a local test particle we can measure as wave what's follow from WAVE-PILOTS BACKGROUND.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
