No of C=C bond in carbonyl compound
  • Thread starter Thread starter somecelxis
    Bond
The discussion centers on identifying the correct structural formula for compound X based on its mass composition and reactivity. The composition indicates carbon (64.3%), hydrogen (7.1%), and oxygen (28.6%), leading to two potential structures: CH2=CH-CHO and CH3-CH=CH-CH=CH-COH. The correct answer is CH2=CH-CHO, as it aligns with the given mass percentages and the reaction with hydrogen gas. The participant's confusion arises from calculating the number of C=C bonds, but the mass composition ultimately supports the simpler structure. The thread emphasizes the importance of matching empirical formulas to experimental data.
somecelxis
Compound X has the following composition by mass : carbon(64.3%) , 7.1% of hydrogen and oxygen (28.6%) . X reduces Fehling's solution to CuO . Copper( I) oxide .0.1 mol of X react with 4480cm3 of hydrogen gas in the presence of nickel catalyst. What 's the possible structural formula of X ?
there are 2 choices ..
CH2=CH-CHO
CH3-CH=CH-CH=CH-COH
THE ANS IS CH2=CH-CHO ...Why ? can anyone explain on this? thanks in advance!
mol of hydrogen gas = 4480/22400= 0.2 mol
if there's only one C=C bond , then 1 mol of X react with 1 mol of H2 gas ..
But 0.1 mol of X react with 0.2 mol H2 gas , so there are 2 C=C bond in X ... my choice would be CH3-CH=CH-CH=CH-COH ...
but the correct ans is CH2=CH-CHO
No idea about everything else, but of the two compounds given only one fits.
so which one is correct?
Have you tried to find the experimental formula from the numbers given? Or even simpler - have you tried to find the percent elemental compositions from the given formulae?
i got ratio of ratio of C:H:O = 3:4:1
using precentage
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
