Normal and centrifugal force for arbitrary curves
The discussion focuses on deriving equations for normal and centripetal forces acting on a ball rolling down a parametrized curve in a homogeneous gravitational field. The goal is to determine where the ball might leave the curve by calculating these forces at each point. The radius of curvature for the parametric curve is provided as a key formula, which is essential for the calculations. Participants are seeking a comprehensive equation that incorporates the curve's parametrization to find both forces. This approach aims to enhance understanding of the dynamics involved in the motion along arbitrary curves.
Gavroy
Hi, i have a curve g:[0,t]->IR² with g(t)=(x(t),y(t)) in a homogenous gravitational field and i want to look at a ball rolling down this curve. therefore i want to derive some equations in order to calculate the normal force and the centripetal force at each point of this curve in order to see where the ball "leaves" the curve. therefore i am looking for an equation that gives me both forces just by using the parametrization of my curve. is there an equation for this?
This might help, the radius of curvature for a parametric curve is:
radius(t) = ( (x'(t))2 + (y'(t))2 )3/2 / | (x'(t) y''(t)) - (y'(t) x''(t)) |
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
