Normal approx binomial question.
  • Thread starter Thread starter Shawj02
    Binomial Normal
Shawj02
Ok, the question says
Binomial with n=40. p=0.6 use normal approximation and determine..
a) value at 14.
b)value lest then 12.
So I thought I had this down and packed but the answer in the back of the book tells me otherwise. Anyways the following is my working.
Y~Nor(13.5<x<14.5)
Mean=np=24
S.D = sqrt(np(1-p)) = 3.094
larger prob area
Z=(x-mean)/S.D
=(14.5 - 24)/3.094
=-3.07
(Tables book, 3.07 = 0.9989)
So (1-0.9989)
smaller prob area
Z=(x-mean)/S.D
=(13.5 - 24)/3.094
=-3.39
(Tables book, 3.39 = 0.9997)
So (1-0.9997)
So the final answer is:
larger prob area - smaller prob area
total prob =(1-0.9989) - (1-0.9997)
=8*10^-4
But the actual answer is meant to be 0.049?
B) I do pretty much the same thing But after the whole Z=(x-mean)/S.D (x=11.5)
end up with Z=-4.034 Which isn't on the tables book. So I can't figgure out the final prob.
Thanks!
First, I get
<br /> \sigma \approx 3.0984<br />
Regardless of this, your work for the first portion looks good. My calculations (in a spreadsheet and in statistical software) show the normal approximation to equal 0.0007, certainly not 0.049 - are you sure the solution you are looking at is for this particular problem? I also used the binomial distribution to work out \Pr(X = 14) for this case, and I get 0.0008, so the approximation is reasonable.
The Z-value you get for the second problem is correct. The fact that it is below the smallest value in the normal table means that (to the decimal accuracy of the table) the corresponding probability is zero. That matches up rather well with the number from the binomial distribution, so all looks good.
Note: the reason these answers are so small is easy to see: both the cutoffs (12, 14) are several standard deviations from the mean. The normal distribution used for approximation is symmetric (every normal distribution is), and for the given values of n and p the binomial distribution is also quite symmetric: there just isn't much probability that far out in the tails.
Namaste & G'day Postulate: A strongly-knit team wins on average over a less knit one Fundamentals: - Two teams face off with 4 players each - A polo team consists of players that each have assigned to them a measure of their ability (called a "Handicap" - 10 is highest, -2 lowest) I attempted to measure close-knitness of a team in terms of standard deviation (SD) of handicaps of the players. Failure: It turns out that, more often than, a team with a higher SD wins. In my language, that...
Hi all, I've been a roulette player for more than 10 years (although I took time off here and there) and it's only now that I'm trying to understand the physics of the game. Basically my strategy in roulette is to divide the wheel roughly into two halves (let's call them A and B). My theory is that in roulette there will invariably be variance. In other words, if A comes up 5 times in a row, B will be due to come up soon. However I have been proven wrong many times, and I have seen some...
