Normal forms of polynomials over a semiring
icantadd
Let R be a commutative semiring. That is a triple (R,+,.) such that (R,+) is a commutative monoid and (R,.) is a commutative semigroup. Let {\mathbf \alpha}_i = \alpha_1,\alpha_2,\ldots,\alpha_n. The n-variate indeterminate is just free monoid on n letters. However, it is common to introduce notation for indeterminates that makes them easier to work with. This notation is that we write every element in the form x_1^{\alpha_1}\cdots x_n^{\alpha_n} = {\mathbf x}^{{\mathbf \alpha}}, and x_i^0 = 1, so that the string in the free monoid on 4 letters (for example), x_2x_3 is written as x_1^0x_2^1x_3^1x_4^0 or in the compact form {\mathbf x}^{0,1,1,0}Define R[x_1,\ldots,x_n] to be the polynomial semiring in variables over R where
R[x_1,\ldots,x_n] = \left\{ \sum_i r_i {\mathbf x}^{{\mathbf \alpha}_i} | r_i \in R , {\mathbf x}^{\mathbf \alpha}_i \text{ is an n-variate indeterminate} \right \} with the where
(\sum_i r_i {\mathbf x}^{\mathbf \alpha}_i) + (\sum_i s_i {\mathbf x}^{{\mathbf \alpha}_i}) = \sum_i (r_i+s_i){\mathbf x}^{{\mathbf \alpha}_i}
((\sum_i r_i {\mathbf x}^{{\mathbf \alpha}_i}) )( (\sum_i s_i {\mathbf x}^{{\mathbf \alpha}_i})) = \sum_k (\sum_I[i=0}^kr_i s_i){\mathbf x}^{{\mathbf \alpha}_k} [/tex]<br /> Nothing other than sums and products defined under the above operations are in R[x_1,\ldots,x_n]<br /> <br /> Now, it seems reasonable to assert that two polynomials p = \sum_i r_i {\mathbf x}^{{\mathbf \alpha}_i} and q = \sum_i s_i {\mathbf x}^{{\mathbf \alpha}_i} are equal iff r_i = s_i for each i. It is also reasonable to assert that polynomials in semiring are equal when viewed as functions of R^n to R. However, we require that all products and sums are in the semiring. So if we want the two reasonable notions of polynomial equality to coincide we must be able to assert that normal form is well defined, that is, if p and q (as above) are normal forms for a polynomial, f, then r_i = s_i for each i.<br /> But we do not have additive cancellations in general, so suppose suppose that p and q are two normal forms for some polynomial f. Then, we can certainly show that r_0 = s_0. But withouth the property that if a+b=a+c \Rightarrow b=c How would one show the other coefficients are equal?
This is a rather specific situation. Generally a polynomial equals another if and only if all coefficients are the same. This has nothing to do with inserting values. Inserting values is usually a ring homomorphism, will say I don't know what your restrictions to a semiring will damage, and should be regarded as such. And generally you cannot conclude that pre-images are identical if their images are. You have to show that the insertion or evaluation homomorphism is injective. I don't think this is possible without further assumptions on ##R##.
##\textbf{Exercise 10}:## I came across the following solution online: Questions: 1. When the author states in "that ring (not sure if he is referring to ##R## or ##R/\mathfrak{p}##, but I am guessing the later) ##x_n x_{n+1}=0## for all odd $n$ and ##x_{n+1}## is invertible, so that ##x_n=0##" 2. How does ##x_nx_{n+1}=0## implies that ##x_{n+1}## is invertible and ##x_n=0##. I mean if the quotient ring ##R/\mathfrak{p}## is an integral domain, and ##x_{n+1}## is invertible then...
The following are taken from the two sources, 1) from this online page and the book An Introduction to Module Theory by: Ibrahim Assem, Flavio U. Coelho. In the Abelian Categories chapter in the module theory text on page 157, right after presenting IV.2.21 Definition, the authors states "Image and coimage may or may not exist, but if they do, then they are unique up to isomorphism (because so are kernels and cokernels). Also in the reference url page above, the authors present two...
When decomposing a representation ##\rho## of a finite group ##G## into irreducible representations, we can find the number of times the representation contains a particular irrep ##\rho_0## through the character inner product $$ \langle \chi, \chi_0\rangle = \frac{1}{|G|} \sum_{g\in G} \chi(g) \chi_0(g)^*$$ where ##\chi## and ##\chi_0## are the characters of ##\rho## and ##\rho_0##, respectively. Since all group elements in the same conjugacy class have the same characters, this may be...
