Notation of General Relativity
Mike2
I'm reading, General Relativity, by Robert M. Wald. On page 39 he has the following notation:
<br /> \displaystyle{<br /> {\rm R}_{{\rm [abc]}}^{\,\,\,\,\,\,\,\,\,\,\,\,{\rm d}} = 0<br /> }<br /> <br />
and
<br /> \displaystyle{<br /> \nabla _{{\rm [a}} {\rm R}_{{\rm bc]d}}^{\,\,\,\,\,\,\,\,\,\,{\rm e}} = 0<br /> }<br />
What do the square brakets [ ] mean? How can the subscript of the \nabla be included in these brakets? I've not seen this notation in the other books I have, so I could use a little help.
Thanks.
The brackets denote that tensor is symmetric in the indices inside the brackets.
The reason why the index of the \nabla can be included in the brackets is simple: the entire construction \nabla_a R_{bcd}{}^{e} is itself another tensor. It has five indices, under four of which it is symmetric.
You could think of it as a new tensor T:
T_{abcd}{}^{e} = \nabla_a R_{bcd}{}^{e}
where all of the lower indices of T are symmetric:
T_{[abcd]}{}^{e} = 0
- Warren
- Warren
So this bracket notation is the same as the sum of all permutations with a coefficient of +1 for even permutations and -1 for odd permutations?
The subscript on the \nabla confuses me because on page 31, Wald writes, "It is often notationally convenient to attach an index directly to the derivative operator and write it as \nablaa, although this is to some extent an abuse of the index notation since \nablaa is not a dual vector."
So what is he doing using it like this?
This notation is defined on p26.
It wasn't stated explicitly by either of you so, just in case, I'll point out that it's the vanishing of the antisymmetric part that means it's completely symmetric in those indices. In other words
R_{[abc]}{}^d=0 \Leftrightarrow<br /> R_{abc}{}^d=R_{(abc)}{}^d.
It doesn't matter that it's a tensor.
...since \nablaa is not a dual vector."
To make operations on the components of \nabla explicit.
Does the subscript on \nabla stand for differentiation with respect to the a'th coordinate curve of some as yet unspecified system?
Is that system always orthogonal?
Thanks.
If you mean covariant differentiation with respect to the ath coordinate of some as yet unspecified coordinate system, then yes.
Again, by "system" I'll assume you mean coordinate system. A coordinate system S is orthogonal with respect to some inner product ( , ) if S's basis vectors are mutually orthogonal with respect to ( , ). In GR, ( , ) is the spacetime metric, and S needn't be chosen orthogonal with respect to it. On the other hand, given any point p on a manifold, one may always choose a coordinate system which is orthogonal at p.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
