Dlockwood said:
First question: I didn't specify stable or unstable. Normally that would include either. I just wanted to know the largest particle that exists in a 'natural setting', that is, without the aid of machines, without electrons, even if they were created by machines.
Dlockwood,
What's a "natural setting" [ or what's an "unnatural setting" ] ?
Second question: Sprectal sensors are inherently slow, operating at best, in nano-seconds. In order to properly analyze the fireball, I assumed that femto-second analysis would be a minimum requirement. While I assumed this is not feasible with current sensor technology,
You're wrong again with respect to spectral sensors not having
femto-second resolution. The sensors employed by Lawrence Livermore
National Laboratory in the laser-fusion program are that fast. They
have to be - the laser fusion events are very short - much shorter than
a bomb.
Courtesy of the International Society for Optical Engineering:
http://www.spie.org/app/publications/magazines/oerarchive/december/dec97/cover.html
is an interview with LLNL scientist Deanna Pennington. Notice Figure 4 -
curve d) shows the pulse to have a width of 620 femto-seconds, while
curve c) shows the spectrum of the pulse. In order to obtain a spectrum
of a pulse that has a 620 femto-second duration, one has to have sensors
that respond with femto-second scale resolution.
I also know that scientists have always been 'stellar' at finding ways to solve this kind of problem. I also assumed that using multple staggered trigger multiple sensor arrays would have been the most likely approach.
Third question: I have long wondered what the emmisions were from a nuclear explosion. Particularly, the differences in frequency between the different types of nuclear devices and the intensities of each frequency per unit of time for each type. Each part of this question would produce three dimensional pictographs of the emmisive events that take place during a nuclear detonation. I assumed that intense gamma bursts would be the first highest intensity emmisions followed by lower frequencies, with some lower frequencies possibly exceeding the intensities of the gamma bursts at later periods. Of course it depends how you define intensity for these emmisions also, which I expected to be discussed in the answer.
Again, you are making erroneous assumptions. With matter, the higher
the kinetic energy - the faster the object travels. However, this is NOT
TRUE with photons, i.e. radiation. Gamma rays don't travel faster than
X-rays which don't travel faster than visible light. They all travel at
the speed of light.
However, the radiation is not transporting in a vacuum - it is travelling
in a medium - the air [ plus bomb debris ]. The detected radiation may
not just free-stream in the air. It may interact and be absorbed and
re-emitted - which, in effect, slows down the transport velocity. [ Ex.
light travels slower in water and glass than it does in air - which is why
you see refracted images of the fish in your aquarium ]. At what
frequencies the light is absorbed and re-emitted is complex - and it is
not a simple function of the energy.
"Intensity" doesn't depend on how you define it - there is A definition of
intensity. The intensity is the number of photons per unit area per unit
solid angle per unit energy [ or frequency ] per unit time.
Lastly, I did mention 'the core' meaning that since there are attractive forces at work in the core, that would include protons and nuetrons, not electrons. The attractive force would be the gravitational attraction of the particles. Repulsive forces could only include protons, unless there are other repulsive forces in the core, and these would refer to the 'like' charges. What I wanted to know, in terms of force, is if the attractive forces were equal to the replusive forces, or if one outweighed the other, and which if any, was the greater force.
The gravitational attraction is INSIGNIFICANT - by many, many orders
of magnitude! Gravity only plays a significant role when one of the
"particles" is a planet or something larger. [ There's a gravitational
attraction on the objects around you exerted by the massive Earth ].
But gravitational attraction between nuclei? PULEEZ!
The nuclear attraction between protons and neutrons don't play any
part in how the expansion of the exploding bomb proceeds. Those forces
are totaly internal to the nuclei - so they don't affect how the nuclei
are accelerated or dispersed in the explosion. [ Consult a high school
physics text as to why internal forces don't affect the motion. ]
And no, I don't believe these questions have been answered. I would be surprised if you didn't know these answers so I am assuming that you won't answer them because you're bound by a secrets act. That's ok by me, but it would be nice if you would give some indication to that effect rather than dancing around these fairly straight forward concepts. I'm sure that any good physicist with a better math background than I have could calculate the answers to these questions in about a year. Most of the information needed is out there.
If there are areas which involve secrets - then obviously those can't
be discussed.
In fact, if that's the case, then one can't even state what those areas
are - because that would be telling people where to look for interesting
secrets.
You'll just have to accept the answers I give as I give them.
Dr. Gregory Greenman
Physicist
