Rade
Number of circles within a circle
14 replies · 11K views
Mathematics news on Phys.org
Discussion
Homework Helper
- 3,149
- 8
Rade said:There are an infinite number of radii within any given circle, are there also an infinite number of circles within a circle as shown in the attached image ?
Given a radius R, there is an infinite number of 0 < r < R, so the answer is yes. I can't see the attachment though, but there is no way to display that. Non-formally speaking, you could be talking about a shaded disk of radius R, I guess.
Admin
- 69,778
- 25,624
Seems like an analogous question to "Are there an infinite number of discrete points between 0 and 1 on the number line?" Is there something special about the circle aspect of this question?
Rade
I can see the attachment fine--are you still having problem ?radou said:Given a radius R, there is an infinite number of 0 < r < R, so the answer is yes. I can't see the attachment though, but there is no way to display that. Non-formally speaking, you could be talking about a shaded disk of radius R, I guess.![]()
Rade
berkeman said:Seems like an analogous question to "Are there an infinite number of discrete points between 0 and 1 on the number line?" Is there something special about the circle aspect of this question?
Admin
- 69,778
- 25,624
Rade said:I can see the attachment fine--are you still having problem ?
It takes an average of a few minutes for the Staff and Mentors to see that there is an attachment awaiting approval. Once I saw it and approved it, everybody can see it. radou just viewed your post before I approved it.
And about the number line thing -- are you familiar with how limits work in a finite section of the number line? A related topic would be Zeno's (sp?) paradox, for example.
BTW, is this a homework problem? We should move it to the homework forums if it is.
Rade
No it is not.berkeman said:BTW, is this a homework problem
Rade
Neither of these constraints apply--see the figure in post #1--perimeter has width, not a shaded disk.Gib Z said:There are an infinite number of circles if the perimeter has "no" width and the distances between the radii are zero. ie A Shaded Disk.
Homework Helper
- 2,832
- 0
Rade said:Neither of these constraints apply--see the figure in post #1--perimeter has width, not a shaded disk.
I'm not entirely sure what you're saying, but if each of the 'circles' is actually an object with nonzero area (say, the set of all points within 0.001 units of a circle) then only finitely many can fit into the (large) circle without overlapping, since the area of a circle is finite.
Homework Helper
- 3,341
- 7
Well yes, that's why there isn't an infinite number of circles...
CRGreatHouse- The circles I specify for an infinite amount are not existent, just mathematical with the area between the circles zero.
Rade
OK, but there would be an infinite number if the perimeter of added circles "has no width"--in the same way that there are an infinite number of radii (without width) in a circle--correct ?CRGreathouse said:I'm not entirely sure what you're saying, but if each of the 'circles' is actually an object with nonzero area (say, the set of all points within 0.001 units of a circle) then only finitely many can fit into the (large) circle without overlapping, since the area of a circle is finite.
Homework Helper
- 2,832
- 0
Rade said:OK, but there would be an infinite number if the perimeter of added circles "has no width"--in the same way that there are an infinite number of radii (without width) in a circle--correct ?
Yes, certainly. There's a circle for every real number between 0 and the outer radius.
bomba923
- 759
- 0
A disk of some radius R≥0 can be thought of as {(x,y) : 0≤x2+y2≤R2}Rade said:OK, but there would be an infinite number if the perimeter of added circles "has no width"--in the same way that there are an infinite number of radii (without width) in a circle--correct ?
A circle with a radius r≥0 can be thought of as {(x,y) : x2+y2=r2}
As you can see,
[tex]\left\{ {\left( {x,y} \right):x^2 + y^2 = r^2 } \right\} \subset \left\{ {\left( {x,y} \right):0 \leqslant x^2 + y^2 \leqslant R^2 } \right\}{\text{ if }}0 \leqslant r \leqslant R[/tex]
If R>0, there is an infinite quantity of distinct r that satisfy 0≤r≤R;
thus, there is an infinite quantity of distinct circles within a disk of radius R>0.
Rade
Bomba923--thank you very much for the time and clarity of your answer--what I would expect from the mathematics section of this forum.
Undergrad Semi-Circles Within a Circle
- bob012345
- · Replies 6 ·
- General Math
- Replies
- 6
Equilateral triangle within a circumscribed circle
- Yankel
- · Replies 5 ·
- General Math
- Replies
- 5
Undergrad Determining whether grid coordinates lie within a circle
- STENDEC
- · Replies 4 ·
- General Math
- Replies
- 4
Undergrad Fitting circles inside other circles
- wolfieon2
- · Replies 20 ·
- General Math
- Replies
- 20
Undergrad Concentric circles and a certain curve's function
- 24forChromium
- · Replies 5 ·
- General Math
- Replies
- 5
Undergrad Area of a circle within a circumscribed triangle
- blueberrynerd
- · Replies 1 ·
- General Math
- Replies
- 1
Undergrad How to determine the area of intersecting circles?
- elegysix
- · Replies 2 ·
- General Math
- Replies
- 2
Perimeter/Area of Shaded Region within a Circle
- zak100
- · Replies 10 ·
- Precalculus Mathematics Homework Help
- Replies
- 10
Adjustments to lie within a circle
- Siron
- · Replies 2 ·
- Calculus
- Replies
- 2
Undergrad Involuted planes within a circle, Klingelnberg-Palloid involute
- artis
- · Replies 13 ·
- High Energy, Nuclear, Particle Physics
- Replies
- 13
