Number of circles within a circle
  • Thread starter Thread starter Rade
    Circle Circles
The discussion centers on whether there are an infinite number of circles within a given circle, with participants agreeing that, mathematically, there are indeed infinite circles as long as the circles have no width. The analogy to the infinite points between 0 and 1 on a number line is made, emphasizing that similar limits apply in both cases. One participant clarifies that if circles are defined as having no area, then an infinite number can fit within a larger circle. However, if circles have a non-zero area, only a finite number can fit without overlapping. Ultimately, the consensus is that an infinite number of distinct circles can exist within a circle when considering them as mathematical constructs without width.
Rade
There are an infinite number of radii within any given circle, are there also an infinite number of circles within a circle as shown in the attached image ?
Mathematics news on Phys.org
Given a radius R, there is an infinite number of 0 < r < R, so the answer is yes. I can't see the attachment though, but there is no way to display that. Non-formally speaking, you could be talking about a shaded disk of radius R, I guess. :biggrin:
Seems like an analogous question to "Are there an infinite number of discrete points between 0 and 1 on the number line?" Is there something special about the circle aspect of this question?
I can see the attachment fine--are you still having problem ?
:confused: Don't know, that is why I ask. Consider that 0 and 1 that serve as limits in your example are similar limits in that they are both integers, but in the circle example it is not clear to me that both limits are similar.
It takes an average of a few minutes for the Staff and Mentors to see that there is an attachment awaiting approval. Once I saw it and approved it, everybody can see it. radou just viewed your post before I approved it.
And about the number line thing -- are you familiar with how limits work in a finite section of the number line? A related topic would be Zeno's (sp?) paradox, for example.
BTW, is this a homework problem? We should move it to the homework forums if it is.
There are an infinite number of circles if the perimeter has "no" width and the distances between the radii are zero. ie A Shaded Disk.
No it is not.
Neither of these constraints apply--see the figure in post #1--perimeter has width, not a shaded disk.
I'm not entirely sure what you're saying, but if each of the 'circles' is actually an object with nonzero area (say, the set of all points within 0.001 units of a circle) then only finitely many can fit into the (large) circle without overlapping, since the area of a circle is finite.
Well yes, that's why there isn't an infinite number of circles...
CRGreatHouse- The circles I specify for an infinite amount are not existent, just mathematical with the area between the circles zero.
OK, but there would be an infinite number if the perimeter of added circles "has no width"--in the same way that there are an infinite number of radii (without width) in a circle--correct ?
Yes, certainly. There's a circle for every real number between 0 and the outer radius.
A disk of some radius R≥0 can be thought of as {(x,y) : 0≤x2+y2≤R2}
A circle with a radius r≥0 can be thought of as {(x,y) : x2+y2=r2}
As you can see,
\left\{ {\left( {x,y} \right):x^2 + y^2 = r^2 } \right\} \subset \left\{ {\left( {x,y} \right):0 \leqslant x^2 + y^2 \leqslant R^2 } \right\}{\text{ if }}0 \leqslant r \leqslant R
If R>0, there is an infinite quantity of distinct r that satisfy 0≤r≤R;
thus, there is an infinite quantity of distinct circles within a disk of radius R>0.
Bomba923--thank you very much for the time and clarity of your answer--what I would expect from the mathematics section of this forum.
