Nyquist sampling rate and signal anti-aliasing
The discussion revolves around the Nyquist sampling rate and its implications for signal representation, particularly focusing on the frequencies that can be represented without aliasing. Participants explore theoretical and practical aspects of sampling, filtering, and signal synthesis in both the time and frequency domains.
  • One participant inquires about the lower frequencies that can be represented without aliasing when the Nyquist sampling rate is 2f, suggesting a relationship between sample counts and waveforms.
  • Another participant asserts that all signals with frequencies below half the sampling rate can be reconstructed perfectly, emphasizing the need for a real filter to avoid aliasing in practice.
  • A participant clarifies that if the highest frequency is 100Hz, then all frequencies below 100Hz can be perfectly reproduced without aliasing, given a Nyquist rate of 200Hz.
  • There is a discussion about defining signals in the frequency domain and the implications of changing amplitudes while keeping frequencies constant.
  • Concerns about spectral leakage are raised when varying amplitudes of the same set of frequencies.
  • One participant questions the nature of the signals being created, whether they are steady state or modulated, highlighting potential aliasing issues with modulation.
  • Another participant notes that the form of the signal can vary as long as it adheres to the Nyquist criterion, emphasizing that filtering is necessary after sampling to avoid high-frequency overloads in subsequent circuits.
  • A later post indicates a shift in focus, with a participant abandoning the idea of encoding information in separate signals and seeking to understand the limitations of their approach.
Participants express various viewpoints regarding the implications of the Nyquist sampling theorem and the practical considerations of signal processing. There is no consensus on the specifics of signal modulation and its effects on aliasing, indicating ongoing debate and exploration of the topic.
Participants mention the need for low-pass filtering and the effects of spectral leakage, but there are unresolved assumptions regarding the definitions of signals and the conditions under which aliasing may occur.
Gedelian
Hi all!
Quick question. If a Nyquist sampling rate in a signal is 2f, what lower frequencies can be represented without aliasing? I assume you could have frequencies which have only even number of samples in their wave length, or maybe in half of their wave length. Am I wrong? If someone can post an answer, it would be greatly appreciated.
Cheers!
All signals with frequencies below half the sampling rate can be reconstructed perfectly.
That's the theory. In practice, you need a real filter before the sampling circuit, to cut out frequencies above half sampling rate and it will have a finite cut-off rate around this limit. But I don't think this is your point.
I suspect that you are concerned with the situation where the samples are at regular points in the waveform - thus 'missing the peaks', perhaps. This doesn't matter because there is quite enough information to rebuild the signal perfectly. Correct low pass filtering after the crude DAC will produce the peaks and troughs (overshoots) in the output signal, despite the apparent fact that the (box-car, perhaps) samples don't explicitly 'contain' them.
Thanks for the quick reply.
The frequencies I was asking about are 'pure', in the sense that I want to choose them to build a signal using inverse FFT. So it's not a 'dirty' real life signal which needs filters. As I understand correctly, if you have the highest frequency of, say, 100Hz, and Nyquist rate is 200, then all frequencies below 100Hz can be perfectly reproduced whitout aliases, right?
Right. Produce the right samples and the filter will do the rest - whatever phase of signal you require. What signal do you require? Are you defining it in the time domain or the frequency domain?
The definition comes from the frequency domain. I want to create a series of signals with the same frequencies but different amplitudes. For example, every signal has the same set of frequencies, from 1 to 100Hz, but every frequency in a given signal has a different amplitude, and the pattern of amplitudes in one signal never repeats itself in any other signal. I'm not certain what is going on with phases here, so, I guess I just wanted to know in principle what is and what isn't possible.
The phases won't change.
Secondly, I am not sure but since you change the amplitudes, you may consider spectral leakage.
Not sure I'm clear on what you mean by a "series of signals". Do you have multiple signals that are each steady state or are you trying to modulate the amplitudes of the 100 tones? If you are modulating then you have potential aliasing issues.
I am sensing another question in this, which we haven't picked up on. When you sample a signal, it can take any form as long as it has no components over Fn/2 and, of course, its amplitude mustn't exceed the range of the ADC. What happens after that is 'numbers', whatever your signal consists of. The same applies when you generate a signal; if you choose to synthesise it 'in the frequency domain' or in the the time domain, the signal is still the same and the samples would be indistinguishable. There is nothing significant about components which lie on sub harmonics of the sample frequency. (Filtering is always included after the samples are converted to analogue values because you don't want loads of high frequency stuff which could overload any following analogue circuits)
Hey all, sorry for the late post, I abandoned the whole idea with the signal series. The idea was to encode information in separate signals using amplitudes without modulation, because I needed frequencies for something else. I just wanted to know what are the limitations of that approach. Thanks anyway.
