Undergrad Why Are 8 Valence Electrons Essential for Atomic Stability?
  • Thread starter Thread starter jwags99
    Electrons
Eight valence electrons are essential for atomic stability due to the octet rule, which states that atoms are most stable when their outer shell is full. A complete electron shell, such as the configuration 2s²2p⁶, results in lower energy and increased stability. Atoms tend to gain, lose, or share electrons to achieve this stable configuration. The discussion references additional resources that elaborate on the relationship between full electron shells and atomic stability. Understanding the octet rule is crucial for grasping chemical bonding and reactivity.
jwags99
TL;DR
Question about the stability of atoms
Hello, all!
I've been trying to understand why the octet rule is followed, but I have not had much luck yet. Does anyone know why 8 valence electrons are ideal for the stability of atoms? I appreciate any help you can give!
Thread 'What is the pressure of trapped air inside this tube?'
As you can see from the picture, i have an uneven U-shaped tube, sealed at the short end. I fill the tube with water and i seal it. So the short side is filled with water and the long side ends up containg water and trapped air. Now the tube is sealed on both sides and i turn it in such a way that the traped air moves at the short side. Are my claims about pressure in senarios A & B correct? What is the pressure for all points in senario C? (My question is basically coming from watching...
  • · Replies 36 ·
