ODE Proof (2nd order linear homogeneous equations)
Daxin
Suppose u, v are two linearly independent solutions to the differential equation u''+p(x)u'+q(x)v=0. If x0,x1 are consecutive zeros of u, then v has a zero on the open interval (x0,x1)
I'm trying to use the Wronskian(u,v;x) to arrive at a contradiction.
I know that the W = uv'-u'v is never 0 since u,v are linearly independent. Furthermore, since it is a combination of C2 functions it must also be continuous on [x0,x1] = I. Also if I suppose that v is never zero on I, then it must be always positive or always negative. Same with u, since we know x0,x1 are consecutive zeros. From this I want to show that the Wronskian is positive at some point in I, and negative at another point, which would lead to a contradiction. Is this the right idea?
Surely you don't mean to have both u and v in the equation itself? Since u and v are to be specific solutions, it would be better to say
"Suppose u, v are two linearly independent solutions to the differential equation y''+p(x)y'+q(x)y=0.
Sounds like a good plan. How are you going to implement it?
I think there is a direct proof: You have
W(x_0) = u(x_0)v'(x_0) - u'(x_0)v(x_0) = -u'(x_0)v(x_0)
and similarly
W(x_1) = -u'(x_1)v(x_1)
and, since W(x) vanishes nowhere, W(x_0) and W(x_1) must have the same sign. Thus
W(x_0)W(x_1) = u'(x_0)v(x_0)u'(x_1)v(x_1) > 0.
Now use the fact that x_0 and x_1 are consecutive zeroes of u to show that u'(x_0)u'(x_1) < 0.
What does that require of v(x_0)v(x_1) if the condition on W(x_0)W(x_1) is to hold?
Yeah thanks guys, I think I get it now.
v(x0)v(x1) would have to be negative. And since v is cts it must have an 0 between x0 and x1.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
