Robin07
- 137
As I understand it: In a regular cylindercal soleniod the winding starts at one point(top) and winds down to the other side(bottom) of a cylindercal core. Once the wind reaches the bottom, the wire returns back to the top and so forth, until the desired winding is achieved, let's say 10 layers. The electron path would then follow the archtecture of the wire moving very quickly(short of the speed of light) up and then down the cylinder in a consistant clock-wise direction.
The above description involves only one wire. The change in architechture in my proposed design would only allow electron flow in one direction, from the top to the bottom. The question I have is, Will this change make a markable difference in the strength of the soleniods' magnetic flux field?
I propose to start the first wind at the top near the core of the cylinder, as in the design of a conventonal cylindercal soleniod but terminate the wire when it reaches the bottom, repeat this process so that I end up with 10 seprate layers. I undestand that each wire will need to have a return path in order to facilatate electron flow. So, each individual wire will be soldered to a common buss that runs in the interior or exterior length of the soleniod.
This setup would be very simple/cheep to put together but in my local, availability is nill. I quite literally can't even purchase one spool of any wire, ever since radio shack closed there door.
Thanks
If any part of my description isn't clear, i"m sorry to say but, my camera is broken. If the proposed description has some potential I will do my best to borrow a digi cam and post it in a hand drawing.
Thanks again
Thanks
Thanks again
