Why Is the Night Sky Dark If the Universe Is Infinite?
  • Thread starter Thread starter vincentm
    Concept
The discussion centers on Olber's Paradox, which questions why the night sky is dark if the universe is infinite and eternal. Participants explain that if the universe were both infinite and static, the night sky should be bright due to the infinite number of stars. However, the universe is expanding and not infinitely old, which means we cannot see all stars, and redshift causes distant light to become undetectable. The conversation also touches on the implications of this paradox for the Big Bang theory, suggesting that if the sky were bright, it would contradict the Big Bang model. Ultimately, the dark night sky is explained through the combination of cosmic expansion and the finite age of the universe.
vincentm
I'm having trouble wrapping my head around this, can someone explain this to me?
Thank you,
Vincent
Space news on Phys.org
Thank you,
Vincent
Read a book.
(What? You wanted a better answer? How about asking a better question. :rolleyes:)
DaveC426913 said:
Read a book.
A little brusque maybe?
Vincent - Olber's paradox arose in the Newtonian universe, and still can be used to provide a constraint on speculative 'toy' cosmological models.
"Why is the sky dark at night?"
A seemingly naive question that has a profound answer.
If the universe were :
1. Infinite and
2. Infinitely old i.e. eternal and
3. Static (all three being true together) then the night sky should be burning bright!
The surface brightness of a star does not depend on distance, unless there is ISM absorption, the luminosity and the angular surface area both depend on \frac{1}{r^2} so the surface brightness: luminosity/angular-surface-area is constant. Therefore wherever you look, if the three above conditions all hold, you will see the surface of a star, and that surface brightness will be that of the average star in the sky, similar to but a little less than that of our own Sun, so the whole sky would be almost as bright as the surface of the Sun! If you take the absorption of distant star light by ISM gas and dust into account that ISM will also eventually heat up to the average star surface temperature as the universe is infinitely old.
Before the expansion of the universe was discovered it was generally thought by astronomers, back to the ancient Greeks, that the universe was eternal.
Newton realized that in such a universe all the stars (galaxies today) would after some interval all coalesce together under their mutual gravitational attraction. As this had not happened the universe had to be inifinte as well, then any gravitational force would be canceled out by an opposite force.
Why then was the night sky dark?
The answer of course is although the universe may be infinite it is not infinitely old and so we cannot see further than our particle horizon, and the universe is not static, it is expanding thus red shifting the majority of the starlight.
I hope this helps, you can take the paradox further in curved space-time and closed universes when it provides a constraint on more modern models of the universe.
Garth
It wasn't an admonishment, it was responding in kind to his query.
I hoped to elicit from him what he *did* know, and what was troubling him - to have him put some effort into learning, rather than :rolleyes: being hand-fed the answers.
How you you know he even knows what Olber's Paradox is??
DaveC426913 said:
Read a book.
Wow, thanks for being rude. For your information the book's section on this is a little hard to grasp, i was hoping for an explanation from here, if everyone was to follow this advice of yours then why would this site continue to exist? Remind me never to ask for your help, by the way thanks Garth!
OK, I guess it came across as a little harsh. It wasn't intended to be harsh, so much as it was intended to be tutorial. My curt response was a not-so-subtle way of saying "I'll put as much effort into this as you do."
See, this forum has a policy of encouraging guidance - helping people through things, rather than doing the work for them. A very common phrase on this board is: "Show your work!"
If your question explained what you DO know about Olber's paradox and where it goes wrong for you, it would be far more likely to elicit all sorts of helpful responses.
Anyway, since Garth covered it fairly well, there's nothing for me to add.
Touche' i could have formulated my question better, my apologies as well.
Anyways the way its explained to me in the book I'm reading is an example of a spherical shell surrounding the earth, and as this shell grew in radius then the total luminosity of the stars would increase because more stars are incased in the "shell, but this isn't exactly true, right?
That argument is just as valid and approaches the geometry from a different direction. Take any thin shell around the Earth containing typical stars. The luminosity of each star L ~ \frac{1}{r^2} but the surface area of the shell, and hence the typical number of stars within it, A ~ r^2 so the total luminosity from each shell, of whatever radius r is the same. Now add each shell out to inifinity and no matter how small the luminosity from each shell is, the total diverges to infinity. It isn't exactly true because what hasn't been taken into account is the light that is blocked by stars in the foreground, which is why it is easier to do the calculation my first way round.
Garth
I think it's a fair question, DaveC. Had you posed the question... we would have jumped all over you because you DO know better. But I think it's a very honest question coming from vincentm; and deserves a friendly answer. Dave is very knowledgeable about this stuff, so don't be too hard on him, vincentm. Less than honest questions appear here too often, and sometimes it is difficult to resist getting impatient. You are asking all the right questions vincentm.
Even in an infinite (spacially and temporally) universe, Olber's paradox is mooted by redshift. The more distant an object is, the more redshifted its light. Light from objects sufficiently distant from us will be redshifted into undetectibility.
Good point, though I would replace the word 'mooted' with the word 'mitigated'. A starscape lit so would still be nigh-infinitely bright.
That is why Garth specified a static universe.:rolleyes:
But doesn't a static universe say that it is not expanding? :confused:
Yes -that is why it was a paradox to Olbers and the others back then, today with an expanding universe there is no paradox - the sky is dark at night!
garth
garth
Ok, stupid question time:
How does Olber's Paradox play into supporting evidence for the big bang?
Only in that as a Big Bang universe is not infinite AND eternal AND static it is not surprising that in such the sky is dark at night.
Note: This isn't very strong evidence for the BB, it would only be strong evidence for the opposite, i.e. If the sky was burning bright at night then we would know we were not in a BB universe. Of course in that case we wouldn't be here at all as it would be too hot!
Garth
Well, we already need to start delving into the infrared regions to see much of anything beyond what Hubble has shown us, and more distant objects will be redshifted still more.
True, but that's because most of us are under the assumption that redshift is caused by cosmological expansion. When Hubble and his team established the relationship between redshift and distance, he did not embrace this view. He was working within the confines of a steady-state model. Even in Hubble's steady-state model, Olbers paradox would be laid low by the distance/redshift relationship, even for a temporally and spacially infinite universe.
What metric do you have in mind that is more predictive than the FRW model?
I am proposing no metric in that post, merely pointing out that if distant objects are more redshifted than closer objects, sufficiently distant objects will be redshifted out of obvservability, regardless of the mechanism responsible for the redshift, mooting Olber's Paradox.
Agreed, you are not proposing a metric. But, it seems internally inconsistent to use the redshift <> distance without a metric.
Not a stupid question
That is not a stupid question . . . . In fact it is one of the best questions you can ask. What it means, logically, is the universe cannot be both infinitely old and spacious at the same time.
(addendum) ...when the universe is homogenous and isotropic at the large scales.
If the universe is heterogenous at the large scales, then the basic appearance of 13 billion light years away might still exist today, just far away. Such a perspective might exist for a few Hundred Mpc around us, so it wouldn't defy the Copernican Principle completely - not any more than living somewhere else in Earth would affect the sunspots. But of course, we won't know until 13 billion years from now (if we stick with most recent paradigm that has lasted over half a century). Remember that many cosmological ideas are theories: the idea of a finite universe in time or space could be a very accurate fiction, so could the idea of a infinite universe/multiverse.
I disagree that the universe need be static to validate Olber's paradox. In an infinitely old [and spacious] universe that contains an infinite number of stars, we should see an infinite number of photons bombarding us from every direction. Expansion is irrelevant since the photons have an infinite amount of time to reach us [btw, how does an infinite property of anything 'expand'?] Of course, if distant photons are somehow redshifted out of existence [violating the ever-popular laws of thermodynamics], new physics are required. Otherwise, the night sky should as bright as the surface of the sun.
Chronos said:
I contest the claim the universe need be static. In an infinitely spacious, infinitely old universe that contains an infinite number of stars, we should see an infinite number of photons bombarding us from every direction. Unless those photons are somehow redshifted out of existence by new physics [i.e., replacing the ever popular laws of thermodynamics], The night sky should as bright as the surface of the sun.
But the sky would only be 'burning bright at night' if the universe were infinite & eternal & static.
If it were not static but expanding then the temperature of the sky would be attentuated by the red shift,
F \propto \frac{1}{(1 + z)^2}[/tex]<br /> <br /> there would be similar attentuations for a finite size, depending on the circumference, or a finite age, depending on the distance &#039;out&#039; to either event horizon, or back to the epoch of &#039;first light&#039;.<br /> <br /> As the universe is both cosmologically red shifted (however that is interpreted), and limited in both age, and (as it is thought) distance out to the particle horizon, the combined attentuations result in the very faint sky background luminosity (down to about mag 29 I believe). <br /> <br /> The CMB provides an example of one form of radiation (the whole sky) that was not covered by Olber&#039;s paradox, which has been attenuated from ~ 3000<sup>0</sup>K to ~ 3<sup>0</sup>K.<br /> <br /> Garth
Wouldn't it be more logical to say that the sky isn't dark at night. It looks dark to us because person nature evolved us with eyes that detected the highest level possible without looking directly at the sun and our eyes just arn't sensitive enough to see the avaliable light at night. If they were we would be blind in the daytime unless we had really thick sunglasses.
You would need pretty big eyes to see mag 29!
Garth
Miniature hubbles.
I don&#039;t entirely disagree, just wonder what number you derive assuming an upper limit of z = 1100?
Chronos said:
I don't entirely disagree, just wonder what number you derive assuming an upper limit of z = 1100?
Try 2.760K .
Garth
  • #31
Show the math, Garth.
  • #32
Olber's paradox continued
The following website offers a different explanation, which I don't entirely agree with. It appears to explain Olber's paradox by the finite lifetime of a star rather than the finite age of the universe. While this phenomenon would certainly lower the apparent brightness in a finite age universe, it would have no effect in an infinitely old and infinitely large universe.
http://physics.uwstout.edu/deptpages/physqz/olber.htm
On a related note, let's assume that the universe was infinitely old and infinitely large, but expanding at a rate less than the speed of light. True, light from distant sources would appear to be red-shifted; however, wouldn't each distant object be receiving an infinite amount of energy, causing its own temperature and wave frequency to increase? In other words, how can you attenuate an infinite energy source? Do you see what I am driving at?
  • #33
The area of the sky which a star covers is inversely proportional to the square of the distance.
The brightness of a star is inversely proportional to the square of the distance.
Therefore, the brightness of a star is roughly proportional to the area of the sky it covers.
The integral of n^p from n=1 to n=infinity is finite only if p, the exponent, is less than -1.
In this case, stars would not appear in every point in the sky only if the surface area of all the stars combined at r decrease faster than 1/r, so the number of stars at this distance is proportional to distance^k, k<1.
In a star system, there remains the same number of stars (1 usually, ex. the sun) at differing radii, so k equals 0 for star systems.
In galaxies, mass is proportional to radius, so k equals 1 for galaxies.
At large scales, it is claimed by the cosmological principle that density at the largest scales is the same throughout, meaning a k that equals 2.
  • #34
Olbers’ paradox and the speed of light
I suggest that there is more to Olbers paradox than met the sharp eye of Edgar Allen Poe.
For the purposes of discussion assume that Poe’s resolution of this paradox was the correct one, namely that the night sky is dark because the universe is not infinitely old.. Paul Wesson ( Paul Wesson, "Olbers' paradox and the spectral intensity of the extragalactic background light", The
Astrophysical Journal 367, pp. 399-406 (1991).) has explained this quantitatively by calculating that the amount of background light that has
reached us since the universe began, from within the particle horizon, is insufficient to dispel the darkness of the night. The expansion of the universe, he calculates, only darkens the sky by a further factor of two.
The WMAP results show that spatial sections of the universe are flat (within observational error). Deep Hubble photographs show that the observable universe is filled with luminous galaxies. Stellar age measurements show that local galaxies are roughly as old as ours. A working hypothesis consistent with these observations is that the universe is an infinite dispersion of evolving luminous objects that originated with in an event that took place some 14 billion years ago. The lambda CDM model is not in conflict with such a working hypothesis.
According to this hypothesis the physical reason for our dark night skies is the finite speed of light, c, which together with the age of the universe determines the location of the particle horizon. The quantitative darkness (or brightness) of the night sky depends on the magnitude of c. If c were larger than it is, the night sky would be brighter.
Suppose, as Joao Magueijo has argued in “Faster than the Speed of Light”, that c was much larger in the early universe than it is now. Could the “dark sky” of the early universe then be correspondingly brighter, and the early universe hotter, as the conventional resolution of Olbers paradox suggests? There is evidence that this was the case. Maybe all is not yet cut and dried with Olbers paradox.
  • #35
This need not be correct.
The correct conditions for Olbers' paradox to come into play are:
A universe infinite in extend homogeniously filled with luminous matter which exist for infinite time (eternal)
So theoretically the universe can be infinitely old and infinite in extend, if we assume that either stars have not always existed (which is the assumption the Big Bang theory makes) and/or is not static (which is also postulated by the Big bang theory).
The Big bang theory of course also states that the observable universe is of finite age, but the question wether that means that time is not infinite is still open, we can only ascertain that we can not observe anything before a certain time (i think the time at which the universe became transparent to light).
Theoretically there is also the possibility that the universe has a fractal nature in such a way that the average density of lumnious matter would drop down to zero when we increase the diameter, in which case Olbers' paradox also does not arise.
Just observation shows that this is not the case in the observable universe.
  • #36
However, one musn't consider the Milky Way as the center of the universe. In fact, there is no center of the universe, but rather there are places with more gravitational pressure than others. The only way to see this fractal structure in the immediate future is to assume that the structure does not change much with time. From the timeline of the Big Bang it is deduced that the further we look back, there is greater matter and energy density. But if this matter and energy density was about the same as it appears to us right now (at about the same spot), then it would appear that we are looking down a gravitational pressure gradient, meaning that our region of the universe (nearest 1 billion light years) is located at the suburbs.
In a fractal universe, the local density is inversely proportional to the cube of the scale factor at the region. Therefore, via integration, the density of the whole would fall inversely proportional to the square of the scale factor. The density would fall fast enough - the density of the whole needs to fall at a rate faster than inversely proportional to the radius in order to avoid Olber's paradox. A decreasing scale factor then begs the question - why are we in a bubble of a higher scale factor, and where could there be even higher scale factors? It is physically unlikely that we are completely surrounded by a bubble of lower scale factor (another way to say regions of greater gravitational pressure) - as in completely closed shell.
Another possibility is that there are particular places in the sky where one could look deeply to find spaces between the regions of high gravitational pressure. After zooming even further, one may find that there are other galaxies on the other side of the regions of high gravitational pressure, proven by their low redshifts in correspondence to their anomalously small angular sizes.
But regions of higher gravitational pressure could be large in angular width (tens of degrees) making it more difficult to find the places where these very distant galaxies may be seen. However, beyond that region behind the deep gravitational wells blocking most of this, would be a scale beyond anything currently realized...
  • #37
1. Infinite and
i think Kepler used this to argue there were a finite number of stars in the Universe even before Newton's fears of collapse... (and two centuries before Olber's formulation of the problem).
Garth said:
"Before the expansion of the universe was discovered it was generally thought by astronomers, back to the ancient Greeks, that the universe was eternal.
and a few brits continued to believe it was eternal even afterwards...
in 1907 Fournier published a nice theory solving the paradox by assuming a fractal distribution of stars.
Edgar Alan Poe was the first to propose there simply had not been enough time for the light to have gotten to us. (as well as ?one of? the first illustrations of how weather could be both chaotic and predictable [he must have been reading of LaPlace?]).
