On commuting of position and momentum operators
dingo_d
I have to proove:
[\hat{y},\hat{p}_y]=[\hat{z},\hat{p}_z]=i\hbar\hat{I}
[\hat{A},\hat{B}]=\hat{A}\hat{B}-\hat{B}\hat{A}
Ok so I know that
[\hat{y},\hat{p}_y]=\hat{y}\hat{p}_y-\hat{p}_y\hat{y}=y\left(-i\hbar\frac{\partial}{\partial y}\right)-(-i\hbar\frac{\partial y}{\partial y})=i\hbar
Analogus for z component. But how to show that it's i\hbar\hat{I}?
Since they're operators they can be expressed in component form - they correspond to some kind of matrix, right?
I don't see how to get that \hat{I} :\
A few hints:
1. Remember that [,] is an operator and thus it should act on an arbitrary function, in QM its the wave function.
2. Remember that (d/dy)y f= f+ydf/dy (why?).
Ok so I can set a wave function \psi (x) and say: \psi (x)=\langle x|\psi\rangle. And I can use product rule.
So [\hat{y},\hat{p}_y]\psi(x)=i\hbar\psi(x), but how to relate that with identity operator? :\ I mean, acting with identity operator won't change my wave function...
When you write
that makes mathematical sense because the left and right-hand sides are both wavefunctions. If we want to write
[\hat{y},\hat{p}_y]=?
we have an operator on the left-hand side, so we should have an operator on the right-hand side. Since you already derived the result for the first equation, just note that it is equivalent to
[\hat{y},\hat{p}_y]\psi(x)=i\hbar \hat{I}\psi(x)
and you will have the correct value for the operator statement.
I see, it's like when I have \vec{F}=m\vec{a} - if I have a vector on the one side I must have vector on the other side...
(we said sth about it on my group theory class, but as a side note...)
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
