B On light clocks and reference frames
Raymond Potvin
I had this questioning about the light clock on another thread, and DaleSpam suggested that I open my own thread, so here it is.
I was asking if the light clock mind experiment was not contradicting the reference frame principle.
Raymond Potvin said:
Here are three diagrams showing the relativity of motion between a light source at A and an observer at B. Fig. 1 and 2 show how aberration and doppler effect occur for two bodies moving in different reference frames. Fig. 3 shows how aberration and doppler effect could actually be occurring at the source but would later be nullified at the observer, thus would always be unobservable, for bodies moving in the same reference frame.
At fig. 1, the observer is considered moving while the source is at rest. While the observer at B travels to B', light travels from A to B', so for the observer at B', the light ray suffers the aberration angle α and has the apparent direction of the dotted red arrow, but it also suffers doppler effect because the observer is moving at an angle to the incoming ray.
At fig. 2, the source is considered moving while the observer is at rest. While the source at A travels to A', light travels from A to B, so for the observer at B, the light ray does not suffer aberration but has the same apparent direction as in fig. 1. For us, it makes the same angle α with A'B, and it does not suffer doppler effect because the ray was emitted at a normal to the motion of the source, but it suffers relativistic doppler effect, which gives exactly the same number as in fig. 1 where the observer's speed was producing doppler effect while moving at an angle to the ray.
At fig. 3, both source and observer are considered moving at the same speed and in the same direction, so the only difference with fig. 1 is that the source is also traveling. For the observer at B', the light ray still has the same apparent direction as in fig. 1 since it suffers the same aberration angle, but this time, its direction points to the actual position of the light source because it has traveled the same distance as the observer, there is no measurable doppler effect because the one produced at the source nullifies the one produced at the observer, and there is no measurable relativistic doppler effect either because the two sources travel at the same speed. Of course, it would give the same result if the observer was at A and the source at B.
To me, fig. 3 means that if the source was a laser beam aimed perpendicularly to its motion, this beam would never hit the observer, which seems to contradict the reference frame principle. Does it?
I added that to my drawings:
Elapsed time is not measured with light paths, but with frequencies, thus with light waves if the clock is a light clock. The light clock mind experiment shows a longer path for the light ray, but it doesn't show how this longer distance would be accounted for by the clock. If we replace the two mirrors by a light source and an observer, there would be no way for the observer to measure that distance, because even if, to travel in the direction of the future position of the observer, the ray was emitted at an angle to the direction of motion, thus producing doppler effect at the source, this effect would be nullified at the observer because he would be meeting the same ray at the same angle and at the same speed but in the opposite direction. Moreover, he would have no way to measure the real direction of the ray either because aberration at the observer would indicate that the source was not in motion.
And DaleSpam answered this:
DaleSpam said:
In a light clock the time is not measured using the frequency of the light, the Doppler shift is 0 and the actual frequency is not relevant. The time is measured by measuring the "echo time" from a target at a known range.
So here is my answer Dale:
It seems to me that the relativity principle would prevent an observer on one of the two mirrors from being able to measure that longer echo time because the clock used to measure it would also be slowed by the motion, and in the same proportion as the echo time. So how would it be measured? Another question: for the same observer to measure a longer echo time, the light ray has to travel at an angle to the motion, in such a way that if it was a laser beam, it would have to be aimed at the future position of the mirror, which seems to contradict the reference frame principle, because by definition, a reference frame is considered at rest.
Your figure 2 is incorrect.
If A fires a light pulse( or laser) at a right angle to its relative motion with respect to B at the moment that A and B are aligned (as shown in the diagram), the pulse will miss B. In order for a light pulse fired from A to hit B, it must be fired before A and B are at right angles to each other as measured relative to there motion, and at an angle less than 90 degrees from the direction of A's motion. In other words, If we consider A as moving and B as stationary, A still has to aim its light in a way as to lead B in order to hit it, just like in the situation where we consider B moving and A stationary.
In the same vein, in the third figure, the light pulse/laser will hit B regardless of whether or not we regard A and B as moving or not. It seems to me that in both these cases you are treating light like it moves with respect to some absolute fixed reference frame, and this is not the case.
That's basically the whole point. You have two light Clocks, A and B each with an observer that measures how long it takes for the light to bounce between the mirrors. Observer A notes that it takes 1 microsecond for the light to make the round trip between the mirrors of his light clock. He also notes that the light bouncing back and forth between the mirrors of Clock B, which has a relative velocity of ~0.87c to him, has to follow a diagonal path that it twice as long, and at the same speed as the pulse bouncing between the mirrors of his clock. Thus the light bounces back and forth between his light clock for every one time it does for Clock B and takes 2 microseconds to make one round trip. The Observer with clock B, which is identical to clock A, measures light as moving at the same speed relative to his clock as A's observer measured light moving relative to Clock A. Thus B measures 1 microsecond for the light to make the round trip between the mirrors. Thus he measures the same time period (light bouncing between the mirrors of clock B as taking half as long as A measured that same light as taking. The two observers measure the same time interval as having different lengths. This is time dilation. In addition, According to observer B, it is the light traveling between the mirrors of Clock A that follows the longer diagonal path and takes longer to make a round trip between the mirrors, and it is Clock A that ticks slower than Clock B. In other words Observer A says clock B ticks slower than his clock and Observer B says clock A ticks slower than B's clock.
Again, you are misinterpreting the behavior of light here and trying to affix its motion to some absolute frame.
You cannot use the behavior of light to determine whether you are moving or not in an absolute sense.
For example, say you have two observers, again A and B, and they are moving relative to each other and meet at some point. At the instant of their meeting a flash of light is emitted from that spot. If you are observer A, you will measure the following: The light Flash will expand outward from you at c with you remaining at the center of the flash and B will be moving away from the center of the flash. However according to B, the light flash expands outward from him at c with himself staying at the center, while A moves away from the center of the flash.
This is what Einstein means with his second postulate which says:
The speed of light in vacuum has the same value c in all inertial frames of reference.
He means as measured relative to the inertial frame from which it is being measured.
Likes BvU
Hi again Janus. I read your article on time: very well written. You're puzzling me here though. I thought that, if the direction of a light ray had to stay independent from the motion of the source, and if that ray had to hit the target at 90 degrees, it necessarily had to be fired at 90 degrees too, thus at the vertical to the observer. What do you mean exactly? Can you develop a bit please?
Fig. 3 is a clone of the light clock, which is not supposed to need an absolute reference frame. Like the clock, it shows light traveling at an angle to hit the target, but in addition, it also shows how aberration and doppler effect would affect the beam.
I thought that two observers moving in the same reference frame would experience the same time flow, that their two clocks would stay synchronized, and you seem to say the contrary. You're puzzling me again. Maybe I don't understand exactly what you mean.
It would be measured by a system of synchronized clocks that are at rest relative to each other (but not at rest relative to the light clock). This is what is meant by time dilation. You are correct that it is not detected by observers on the mirrors.
Hi again Dale! Do you mean that the clock on the mirror would not record the dilation, in such a way that if we would reunite it with those that were not traveling, it would have stayed synchronized with them? Doesn't it contradict the reason why the Hafele/Keating experiment was made, which was to prove that the clocks would really be affected?
I was talking only about a light clock moving inertially in flat spacetime. Once you start talking about non inertial clocks or about curved spacetime then a different approach is simpler. Light clocks are pretty much only useful for understanding inertial motion in flat spacetime.
If those directions are the same, then yes. But if they're perpendicular, then no. If they were in perpendicular directions in every frame you could use that notion to identify a special frame, distinguishing it from all others. Imagine the interior of a passenger train where a Point F on the floor is directly below a point C on the ceiling. We check that it's directly below by connecting C and F with a straight line, and making sure that line is perpendicular to the level floor. We then shoot a laser beam from F towards C and it hits C. Now we move the train in the usual way that trains move, which is in a direction parallel to the floor of the train. With the train in motion we repeat the shooting of the laser beam, from F towards C. But by the time it gets there it will miss C if its path remains perpendicular to the floor. It would have to move along a diagonal path to hit C. Thus we could use this experiment to determine whether the train was moving or not.
This would be a method to distinguish between a state of rest and a state of uniform motion, violating the Principle of Relativity, something no one has yet figured out a way to do despite numerous attempts.
What's really going on here was explained by Galileo in the 1600's. Stand still and toss a ball directly upward. It's path is a straight line. Now do the same while standing on a moving train. Again the ball goes up and down along a straight and vertical line. But to an observer on the ground watching you through a window in the train car, the ball's path is a parabola. So, which is the ball's "true path"? The straight line or the parabola? The answer is that there is no "true path". The path depends on your frame of reference.
As you move horizontally and launch something vertically it stays above its source regardless of the state of (uniform horizontal) motion of the source, but the only way that can happen is if its path has different shapes in different frames of reference.
Me too, but if the accelerations that the two clocks would have to suffer to be reunited was exactly the same, which is virtually possible if they both travel half the distance to get together, they should stay synchronized. And if there is no way for the observer on the mirror to measure the dilation even if one second is longer, it seems to me that there would be no dilation recorded once the clocks would get together. For instance, whatever the length of those seconds, if one of the clocks indicates 10 seconds, the other will also indicate ten seconds.
Hi MT,
At fig.2, the source is considered in motion and the observer at rest, and the ray is fired at a vertical to the observer. Once light is sent, its is expected to go straight line, so if it is fired in the direction of the observer, it is expected to hit the target, no?
A good way to test the direction of light for two bodies in the same reference frame would be with using the moon as a target while the source would be traveling around the Earth at the same speed and in the same direction than the moon, but the beam would then have to stay as thin as it is when it gets out of the laser, which is unfortunately not the case. But even if the result showed that the beam is missing the target, it would not change the data from the experiments on relativity, and it seems to me that it would not change the postulates of relativity either. Fig. 3 shows that, to hit the observer, the beam should also be sent to its future position, but it also shows that aberration would change its real direction, in such a way that the observer would see the source as if it was at a vertical to him, which is exactly what moving in the same reference frame is supposed to mean. This way, and as you point out, there would be no true observable path for light either, even in the same reference frame, but then, would the light clock still be a good explanation of what is really going on with clocks in motion?
If they have to suffer any acceleration then they are not inertial.
That said, if two non inertial clocks start at rest relative to some inertial frame and afterwards undergo equal and opposite accelerations, then they will read the same when reunited. In the inertial frame where they were originally at rest, they will at all times be equally time dilated and therefore remain synchronized with each other (equally desynchronized from the reference frame).
While the speed of light is independent of the motion of the source, the direction and thus the velocity will depend on the motion of the source. And when I say motion I mean relative motion. So If the source is moving relative to any particular frame call it frame 1, and fires a photon at an angle which, as measured by itself,, was at a right angle to the relative motion, then, as measured in frame 1 the photon will travel at an angle less than 90 degrees relative to the motion of the source. Look at it this way. What would happen if, in figure 1, the light is aimed at point B ( where the observer is when the light is fired) rather than B'? The light will miss the observer because he will have moved to B' in while the light arrives at B. This is exactly the same situation as fig 2, with the difference that in figure 2 we are looking at the scenario from the perspective of the observer instead of the source. The point is that you cannot get different results just by switching viewpoints. Your interpretation of how light works in these situations is mistaken.
Any aberration or Doppler effect only exists in the frame that the light clock is moving with respect to. As far as the light clock itself is concerned there is no aberration or Doppler effect. And by this, I don't mean that the aberration/Doppler effect was canceled out, but that it never existed. Again, there is no difference in figure 3 if we consider it as the viewpoint of an observer "at rest" with the light clock moving, or as the viewpoint of an observer moving past a light clock that is itself is at rest. In the second case, the observer would see an aberration and Doppler effect in the light, just like in the first case, but the light clock still wouldn't, and it would be a little silly to attribute this to the idea that somehow this was due to some cancelling out. In this, and any situation all that matters is the relative motion between the two frames, not which one we consider moving or at rest.
Two observers at rest with respect to each other measure the same time rate. But in this instance, we are dealing with two clocks that are not at rest with respect to each other. Observer A and his light Clock at at rest with respect to the same reference frame and measure time the same as each other. Observer B and his light clock are at rest with respect to another reference frame and measure time the same. However, these two reference frames are in motion with respect to each other. Thus is A's rest frame, B is moving, and In B's rest frame, A is moving. And clocks moving with respect to each other do not measure time the same.
Hi MT,
No, as explained above
Your example of the Moon and a source traveling around the Earth is a bad one. It involves circular motion, which is accelerated motion, and quite frankly, until you clear up your confusion of how light behaves under non-accelerated conditions, it is best that you stay clear of accelerated motion examples.
(For an example what I mean, if you consider things from the perspective of the source traveling around the Earth, the Laser it emits would not follow a straight line but would appear to curve.) You are also not clear by what you mean by the source and Moon moving at the same speed. Do you mean that the Moon is directly overhead at all times relative to the source, in which case, their "speed" is not the same. The Moons travels at ~1 km/s in its orbit. A source traveling around the Earth and keeping the Moon overhead would only be moviing at 17 meters/sec.
The better example is two spaceships traveling side by side with their engines shut off. Ship A fires a Laser at Ship B. You seem to be under the impression that in order for A to hit B, that A has to aim ahead of B, But because of aberration and Doppler effect, B will see the light coming directly from A. But this is a violation of the principle of Relativity and the postulates of Special Relativity. This is because A has to change his aim depending on whether We consider A and B as moving or not. If A and B are "At rest" he aims straight across, if they are "moving" he has to aim at some other angle. This implies a "preferred rest frame", the one where A can aim straight across and hit B. There is no such frame. The only thing that determines where A has to aim in order to hit B is the relative motion between A and B, and not any perceived shared motion of A and B.
You have to be real careful dealing with acceleration. If Clock A and Clock B both accelerated in opposite directions at the same rate and for equal times, then drifted for some time, came to a stop, accelerated towards each other and then can to a stop when they met up with each other, then yes, they would show the same time when they meet up, providing Everything about their trip is symmetrical, including the time they drift. But they will read a different time from Clock C that stays at the start and end point.
But then consider the following scenario: The accelerations remain the same. They both accelerate for the same time and the same rate when leaving, turning around and stopping, so that the acceleration experienced by both clocks during the trip are identical. However, Clock B drifts for twice as long as Clock A. This means that Clock B returns to Clock C first and has to wait for Clock A to return. When Clock A returns, the two clocks compare readings. Clock A will read less time than Clock B, Even though they both experienced identical acceleration during their respective trips.
I agree with your reasoning Janus, and I also agree that testing relativity with the moon experiment that I suggested would be a bit difficult to make, but I guess it would also be difficult to synchronize the speed and direction of two spaceships even if we had a beam that would stay thin enough for us to be able to measure with sufficient precision the direction it had in the beginning.
I agree, but then it follows that the time measured by the observer on one of the mirrors will be as dilated as the light clock itself, so that he will not be able to register the dilation even if it happens for real, and because of aberration, he will not be able either to measure the direction of the ray even if it also happens for real. In that sense, two bodies moving in the same reference frame would only be a particularity, not a reference as the name suggests, because choosing that situation as a reference means considering that light goes straight line for real between two bodies in that particular situation, which would not be the case. On the other hand, if this can be proven with maths, then it means that a very thin light ray would miss the target if aimed at the actual position of a body moving in the same reference frame as the source. Again, I think that it would not contradict the postulates of relativity, but I'm not a specialist. Would it?
Maybe you misinterpreted drawings 1 and 2, because they are symmetrical and they give exactly the same result for doppler effect and for the apparent direction of the ray, except that it is a relativistic doppler effect for fig. 2 whereas it is a direct one for fig. 1.
Janus said:
The better example is two spaceships traveling side by side with their engines shut off. Ship A fires a Laser at Ship B. You seem to be under the impression that in order for A to hit B, that A has to aim ahead of B, but because of aberration and Doppler effect, B will see the light coming directly from A. But this is a violation of the principle of Relativity and the postulates of Special Relativity.
That's the question I was asking Dale. Let's see... First postulate: it doesn't seem to change the laws of physics, does it? Second postulate: it doesn't seem to change the way light would travel between bodies in motion, namely it would still have the same speed, but as I said, I might be wrong. What do you think? Now, how could it violate the relativity principle if, by chance, the postulates were perfectly respected?
You are still struggling under the misconception that there is an absolute reference by which motion can be measured. When you talk about the observer not being able to measure the time dilation he is undergoing, You are treating things like his absolute motion with respect to "space" has some effect that causes time dilation to effect him. That time dilation is due to some outside influence acting on him and his clock due to his motion with respect to "space".
This is not what time dilation is. Time dilation is the difference in time measured between frames that are moving relative to each other. Time dilation is what you measure happening to a clock that is moving with respect to you. And, If that clock is moving with respect to you, you are moving with respect to that clock, and thus that clock measures time dilation as happening to you. Time dilation is always something happens to "the other guy" and never applies to yourself.
That's not what the first postulate implies, states, or means. Changing the laws of physics is not the same as demonstrating that the laws of physics are different in different inertial reference frames.
What we're referring to as the Principle of Relativity is the first postulate. For the reasons we've stated, the scheme you propose would allow someone to distinguish between a state of rest and a state of uniform motion. That is sufficient to violate the first postulate and negate the analysis of the light clock.
Even if you could do both of those things, you'd still be lacking an explanation of how it is that the analysis of the light clock yields a result that matches the way real clocks behave.
On the contrary, the way aberration and doppler effect would be nullified in fig. 3 shows that there would be no way to differentiate between rest and uniform motion even if light would behave that way for two bodies in the same reference frame. It thus seems to me that the only difference would be that a light ray would miss the target if sent directly to the actual position of the observer. Since that possibility is almost impossible to experiment, the only way to test it is to check if it respects the postulates. It certainly respects the way light is expected to move once it has been emitted, and I think that the laws of physics would stay the same in all inertial frames too, but what about c? Would it always be measured the same by any observer? I think so, but what about you?
When I suggest that the observer's clock on one of the mirrors will run as slow as the light clock itself, I am referring to the same external observer for both of them, one that is considered at rest while the clocks are considered moving.
Correct.
However "happens for real" is usually an indication of someone thinking in terms of an absolute reference frame.
You lose me here. What are you referring to by "it also happens"
The "two bodies moving" scenario from the earlier posts involved non inertial motion. So you could not use those two bodies to divine an inertial frame.
However, if you were to consider two bodies moving inertially with the same velocity, those would be acceptable for defining an inertial frame.
It would help if you would be explicit about whether you are considering inertial or non inertial motion.
Light travels in straight lines in inertial frames. It's path in non inertial frames may be bent. It isn't clear which you are asking about.
DaleSpam said:
... "happens for real" is usually an indication of someone thinking in terms of an absolute reference frame.
If I was thinking in those terms, I would also think that the speed of light would not be the same for all observers, and its not the case.
I was just examining aberration and doppler effect for two bodies in the same reference frame: with relativity, the two properties are linked, so if doppler effect was unobservable even if it existed, then it should be the same for aberration.
I was just looking for a way to compare the two clocks, and unfortunately, there is no other way than to change their direction and speed.
I am always discussing the light clock mind experiment, whose mirrors are considered in the same reference frame, but which is considered moving with respect to a distant observer. If we imagine light traveling longer between the mirrors, and if we imagine the clock getting late compared to the observer's clock because of that, then we must also consider that light is really traveling this way, but without an observer aboard being able to observe the direction of the ray, and this is exactly what my drawings show. In fact, I am only applying aberration and doppler effect to the light clock, but I never saw this idea elsewhere, so I am uncertain that I am aloud to do that. Am I?
Do you know how a light clock at rest will behave? There's an observer there, also at rest, and we know what he'll see.
But we don't know how a light clock in motion will behave because an observer at rest is not aboard.
I think I'm finally starting to see what you're saying.
Two bodies at rest wrt each other will measure neither a Doppler shift nor aberration.
And when you do so they are not inertial. The postulates of relativity are formulated with respect to inertial frames only.
The traditional light clock thought experiment is with a light clock that is moving inertially. So there is no accelerating or reuniting. Hence my confusion at your comments.
Certainly you are allowed to do that. Both the relativistic Doppler shift and aberration are zero for a detector at rest wrt the source.
Of course we know there is no aberration or doppler effect if there is no relative motion, but we also know that these effects manifest themselves if there is, in such a way that if a laser beam is sent between two bodies in relative motion, it will miss its target if it is not sent in the direction of the future position of the observer. When I apply this principle in fig. 3, I don't think that I refer to an absolute reference frame, I think that the only reference I use is light. Could aberration and doppler effect be an absolute reference for bodies in motion? Does that contradict the relativity principle?
The effects are symmetrical: Mount a source and a detector on each body, and both will see the same effects. So which body would be in absolute motion?
Hi A.T.,
I did not mean absolute motion wrt to another body, I meant absolute motion wrt incoming light rays, which is symmetrical and thus applies to the two bodies, as on fig. 1 and 2.
We have explained ad nauseam that if this adjustment to the direction were necessary it would be possible to use the results of the adjustment to distinguish between a state of rest and a state of uniform motion. Such a thing has been demonstrated both theoretically and experimentally to be false.
The real world is different from the world you describe.
Hi A.T.,
The term "absolute motion wrt" doesn’t make any sense. if it's "with respect to" something, then it's relative, not absolute.
Yes, that is correct.
No. I am not sure what makes you think that it would. Could you explain your reasoning in more detail for the specific case of inertial motion only?
Anything that would allow determination of an absolute reference frame would contradict the relativity principle.
@ A.T.
Maybe I should have described light as a relative instead of absolute reference, but we know its properties are absolute in all inertial reference frames, so I used absolute.
I think that I do not use fig. 3 to distinguish between rest and motion, but only to show that the properties of light would be respected if it would travel the way it does, which means that it could really travel this way without changing anything to our observations, except for the laser beam missing its target, of course. But would that contradict relativity? I don't think, but I'm not sure.
I've tried to redraw the pictures correctly.
A' is a short time after A, B' is a short time before B.
Lowercase letters show the direction of light.
In Fig.1, A has to send light at an angle, and it arrives to B vertically.
In Fig.2, A has to send light at an angle, and it arrives to B vertically.
In Fig.3, A has to send light vertically and it arrives to B vertically.
Does that answer your questions?
  • #31
Perhaps the reason you're not sure is because you haven't understood the responses posted in this thread. For example, I haven't seen you ask about or attempt to refute major portions of the explanations offered in Posts #7 and #11.
You are incorporating the constancy of the speed of light (2nd Postulate) into your worldview without incorporating the Principle of Relativity (1st Postulate). The concepts you need to address are part of Galilean relativity. You need to do that before you attempt to address Einsteinian relativity.
  • #32
Once light is emitted from a body, it is expected to conserve its speed, its frequency and its direction forever, not only wr to this body, but wr to any other body at a time. At any time, all the light rays that are actually traveling in space can be used as a reference to tell if a body is moving wr to any other one, because if it is, then these rays will suffer aberration and doppler effect whether the source or the observer is moving, and they will not suffer any if they are at rest from one another. To me, this reasoning suggests that its not the distance traveled by light between the mirrors that produces the slowing of the light clock since it would not suffer any doppler effect or aberration even if it was traveling this way, a reasoning which is supported by the idea that there would be no way for an observer sited on one of the mirrors of the light clock to record that slowing since its own clock would also be slowed. For one slow back and forth motion of the beam, one slow second would be recorded by that clock, but one second would also be recorded for each bouncing whether the clock would be in motion or not.
  • #33
I think that my third drawing accounts for the fact that it is impossible to distinct rest from inertial motion while observing the objects at rest wr to us, which is a property of Galilean relativity, but it seems to me that adding the direction of light in the drawing the way I did helps to understand why it is so even if light is no more considered instantaneous. No?
  • #34
Thanks for caring to remake the drawings ST, but I think that mine were easier to understand, at least for me, because they show the distance traveled by the bodies by the time light travels between the source and the observer, which is the way the calculations for aberration are made I think. Anyway, you say that, in fig. 2, A has to send light at an angle, but it shows A at a vertical to B. What do you mean exactly? In fig. 3, you say that A has to send light vertically, but you show a diagonal line between source and observer, so what do you mean again?
  • #35
No. Just because a piece of your argument (or one of your drawings) is consistent with the Principle of Relativity doesn't mean the whole of it is.
Again, what you are doing indicates that you are not facing the issue.
Unless you are willing to do that, there's little reason left to indicate that you have any intention of addressing the issues that refute your argument.
  • #36
Yes, with the important caveat that neither the frequency nor the direction are frame invariant. Another way of expressing this is that the energy and momentum of the light are conserved but not invariant.
Why? I agree with all of the facts you mention previously to this, but I don't see the connection. Why would the conservation of energy and momentum lead to invariance of path length?
Yes. This is a direct consequence of the principle of relativity.
  • #37
As the line A'-a' shows, the beam of light is staying behind the source A as it is moving. That is only possible if A sends the light at an angle, same as Fig.1 shows.
The light is sent from A vertically, but A is moving. The position of light in point a' has to be vertically below A', because that's what "sent vertically" means.
It is easier to understand if you imagine A being a car, and it's throwing a ball at B. The ball moves vertically as seen from A, but also keeps the car's horizontal speed. The same mechanism applies with light.
Truth is, your scenario does not deal with Einstein's relativity at all, it can be explained with just Galilean relativity. Relativistic aberration and time dilation are subtle effects, that are not clearly seen in your (or my) pictures.
  • #38
Here is the argument you had MT. Sorry, I should have answered this more directly earlier.
You are right, and we could use it to detect the rotation of the Earth too, so it seems that it would contradict the result of the Michelson/Morley experiments, but not for the same reason. M/M wanted to test the aether dragging possibility, whereas this one would test the possibility that doppler effect and aberration would be unobservable for two bodies in the same reference frame even if they really existed. An interferometer is a very precise instrument, precise enough to detect that kind of speed, but unfortunately, I think that it cannot be used to detect the direction of light, and it cannot be used to detect doppler effect and aberration either since the source and the detector are in the same reference frame. A laser beam could, but wouldn't it spread out too much with distance? MM results also lead to the conclusion that the speed of light would be the same in all directions, and it seems to me that this experiment would not show the contrary, because on the paper, it seems obvious that it would take less time for the vertical beam to hit the floor than for the angled one. I must make a mistake somewhere since it seems to contradict SR, but I still can't see where!
  • #39
There are technical difficulties associated constructing a real light clock, and this is a valid one. In the light clock like the one I described in the train car, the spreading of the beam is an issue. But in principle making the train move fast enough would overcome that. Of course, we can't move real trains fast enough to do that. However, we are confident that the reasoning used in the thought experiment is valid because there are no apparent flaws in it and it yields quantitative predictions that match the way real clocks behave.
This passage explains where ...
  • #40
I think that this example works for a ball because it carries mass, and because we can detect its path while observing the light rays that it reflects, but a light ray is not supposed to carry mass and it doesn't reflect other light rays so we cannot really detect its path. The only way to detect a light ray is to put the detector on its path and orient it against its direction. Its what we would have to do to detect the laser beam on the train or between two spaceships. This way, we would know the position of the source and that of the observer, but we wouldn't know for sure the path followed by the beam, not because it depends of the reference frame, but simply because a light path cannot be observed. This is precisely why I had the idea to add doppler effect and aberration to the light clock, because if we could see a light ray as it is shown on the drawings, we would probably know how it really travels between the two mirrors, and we might not have though to make this mind experiment. But then, without it, how to predict that the light clock would be slow? Worse, how to even suspect that it could be? Again, it seems to contradict SR, but I think that it doesn't contradict the properties of light, and I think that it doesn't contradict SR postulates either.
I just had another idea for a mind experiment. I am probably not the first one to present it, but It supports my reasoning on the light clock, so here it is:
Let two spaceships pass by the Earth on inertial motion and one beside the other wr to earth, and let the farthest from Earth send a laser beam towards an observer on Earth exactly when the two ships align with this observer. If light is considered traveling as in the train, it will hit the other ship thus it will never reach the earth, but if it is considered traveling as in my drawing, it will miss the other ship and it will hit the observer on earth. Both solutions might be true, but certainly not both at a time, and it seems to me that the beam would probably hit the Earth since the other ship will have moved by the time it takes for light to travel between the two ships. Again, it seems to me that my drawings do not contradict SR, but they do not explain how the light clock would slow down either.
  • #41
You keep repeating the same mistake.
When I shine a laser across the width of a standing train, it will land at some spot on the opposite wall.
When I repeat this experiment in a moving train, it will land on the same spot.
It seems you think it will land a bit behind that spot, which is wrong.
If I then remove the wall, the light will keep going in that same direction,
- that is, perpendicular to the movement of the train as seen from the train,
- that is, at an angle as seen from above by an observer that is not moving with the train.
  • #42
A very common misconception. For example, if you shoot a bullet out of a gun barrel, what keeps the bullet moving after it leaves the barrel? The common answer is it has inertia. Objects in motion tend to stay in motion, that's inertia. The bullet has inertia because it has mass.
But this language fosters the misconception that the effect is a property of the bullet. It's not. The effect is due to the fact that you're viewing the bullet from a particular frame of reference. View it instead from a different frame and it's at rest.
In my opinion the term inertia has no purpose in the lexicon of physics. Most people use it as a constant of proportionality between force and acceleration, but in fact there is no constant of proportionality between force and acceleration. The two are not in general even in the same direction!
[...], and it seems to me that the beam would probably hit the Earth since the other ship will have moved by the time it takes for light to travel between the two ships.
There are three points to be made here.
1. If light beams travel the way you think they do the 1st Postulate is not valid.
2. If light beams behave the way you think they do the light clock would keep time in a way that's different from the way real clocks keep time.
3. If light beams travel the way you think they do, countless experimental outcomes would be different, including but not limited to, interferometer measurements like those performed in the MM experiments.
  • #43
From wiki on aberration of light, here is an animation that shows how aberration is calculated using the Lorentz transforms:
https://upload.wikimedia.org/wikipedia/en/6/6d/Aberrationlighttimebeaming.gif
It is presented as in my fig. 2, namely, at the right, it shows the distance traveled by the source while the light ray reaches the observer, the only difference being that the source appears to be at an angle to the observer because it was at an angle when it emitted its light. On my fig. 2, the source appears to be right above the observer because it was there when its light was emitted. You say that my scenario does not need relativity, but I made my drawings so that they would match this animation. To me, saying that light would not travel vertically in fig. 2 is like saying it would not travel as it does on the right part of the animation. I'm sorry but I think I still don't understand your drawings, could you use that animation instead.
  • #44
The Wikipedia animation clearly demonstrates that the light is sent vertically, but arrives at an angle.
To arrive vertically, as it does in your Fig.2, it has to be sent at an angle "behind" the source. That angle is A'-a' in my Fig.2, or A'-B in your Fig.2.
  • #45
Note that the wiki sim starts after that wave train has fully formed. I wish you could watch, in slow motion, a simulation that showed the formation of that wave train. It would show every crest and trough of that wave being formed directly below the source at each instant. There is no diagonal aiming of the wave train to make it hit its target.
Imaging a ball with a piece of ribbon trailing behind it. Focus your attention on the left panel of the wiki sim. The ribbon trails directly behind the ball forming a line segment that's perpendicular to the target's direction of motion. If you view that same scenario from the observer's rest frame you'll see just what's shown in the right panel of the wiki sim.
So, does the ribbon take a straight path as shown in the left panel, or a longer diagonal path as shown in the right panel?
The answer depends on your frame of reference.
  • #46
I agree with you that our concept of inertia is confusing: on one hand, it is a resistance to a force, and on the other, it is motion without a force. But isn't that the same for our concept of mass? If we reject the term inertia, we would have to reject the term mass too, no? But we can't do that, because we would have to replace it by a better term, thus by a better theory, and as far as I know, we don't have any on hand.
Mister T said:
1. If light beams travel the way you think they do, the 1st Postulate is not valid.
I think that it could be valid if we would consider that a laser beam is made of light rays that travel in many different directions, as for any light source, because then, even if those directions are limited for a laser, they would suffer enough spreading to account for the motion involved. In other words, the beam on the train would spread enough for part of it to precede the motion, thus to travel at an angle, and aberration would straighten it for an observer on the wall, exactly as my fig. 3 shows.
I agree with you this time, because it seems to me that there would be no way for an observer on the light clock to register the longer path, which means that a traveling clock would not slow down for real, but it doesn't mean that it would not appear to slow down from a distance, as for the experiments with the muon for instance.
As I said earlier, I think that an interferometer could not account for the direction of light, because it is made to account for its difference in frequencies. But as I just said above, if a laser beam would spread enough, part of it would still hit the mirror when it travels sideways to the motion, and aberration would also straighten it, so I think that it would not change the null result. I may be wrong though, do you still think it would? And if so, how?
  • #47
The animation shows that aberration not shown on the left part is calculated from the angle shown on the right part. The way I see things, except for the initial position between the source and the observer, my fig. 2 is the same as the right part, and my fig. 1 is the same as the left part. Do you agree with that?
  • #48
No. Mass is the invariant length of an object's 4-momentum vector. It is perfectly well-defined and doesn't have any of the problems you mention.
For any real laser, this will in fact be true; but the discussion in this thread is assuming an idealized laser that only emits light in one single direction, i.e., a pulse of light from this laser is just one ray.
What you are failing to do in this entire thread is actually do the math. Write down the equation of the light ray emitted by the laser in one inertial frame; then transform into another inertial frame and look at the properties of the light ray in that frame, as given by the transformed equation. You will see aberration, Doppler, etc. all pop out of this analysis with no problem at all. But you have to actually do the math; you can't just guess, which is what you've been trying to do.
Likes Dale
  • #49
That's mass, but only in the Newtonian approximation. In a more general theory, which is the theory discussed here, mass doesn't play that role, for the reasons I stated.
Apparently you missed my point entirely. Motion without a force is not a property of the object that's moving. It's a consequence of the observer's relative motion or lack thereof.
No, it's the pre-Einsteinian concept of mass.
No, mass has a precise meaning. We can keep it and do just fine without inertia.
Einstein showed that the concept of mass has a meaning that's different from the prior meaning it had. There's no way to resurrect that old meaning with a new theory. The concept of inertia is a historical artifact that, in my opinion, should no longer be part of the lexicon of physics. I see no pedagogical value in it, even when teaching Newtonian physics.
But to measure that frequency you need a detector of some kind, and you have to aim the beam so that it hits the detector. No adjustment needs to be made when the interferometer is rotated. Even MM knew this, as it's part of Galilean relativity.
  • #50
Hi Peter,
Yes, I know how the maths work, and I know that they give the same numbers as our observations, but I never saw aberration applied to two bodies in the same reference frame with light traveling between them the way it travels between the mirrors of the light clock, so I did, and I came to the conclusion that this possibility might change the way we think that light travels between bodies in motion. Of course, its one thing to imagine how light would travel, and its another one to see it traveling for real, but then, we might be wrong to use the idea that the rays contained in a laser beam could all travel in the same direction as you suggest. Is it logically permitted to use an impossibility to demonstrate a possibility? Even if there was only two light rays in a laser beam, they couldn't have been sent absolutely parallel, could they? On the other hand, how could a muon appear to live longer as our observations show an not live longer for real??
