Solving an Op Amp Circuit with Mathematica
The discussion centers on optimizing the feedback resistor (Rf) in an op amp circuit with a temperature-dependent resistor (Rs) defined by Rs = R0 - 1.8T. The goal is to maximize circuit sensitivity, which is determined by the derivative of output voltage (Vout) with respect to temperature (T). The user has derived expressions for Vout and sensitivity using Mathematica and is questioning the correctness of their approach. A suggestion is made that increasing Rf may enhance gain but could lead to output limitations due to op amp power rails. The conversation emphasizes the importance of knowing the temperature range to effectively constrain Rs and optimize Rf for maximum sensitivity.
engineer23
Here's my problem:
Rs is a resistor whose value depends on temperature. Rs = R0 - 1.8T, where R0 = 5000 ohms and T is in Kelvin.
If the ideal op amp has +/- 15 V power rails and you want to maximize the circuit's sensitivity, what should Rf be on the op amp? What is your maximum sensitivity at this resistance?
A drawing of the circuit is attached as a file. R2 corresponds to Rs (the temperature-dependent resistor) and R7 = R8 correspond to Rf. Please note that the drawing shows the circuit solved for T = 72 degrees Fahrenheit and Rf = 300 kOhm.
What I have done:
I have solved the circuit (using Mathematica) to obtain an expression for Vout in terms of Rf and Rs. Circuit sensitivity is dVout/dT (first derivative of voltage with respect to temperature), so I also have an expression for this. Since the power rails on the op amp dictate the maximum Vout, I should have Vout = 15. Maximum sensitivity is the second derivative of Vout with respect to T set equal to zero, correct? So then I have two equations and two unknowns and can solve for Rf and Rs.
Is this approach correct? Or am I missing something easier?
Hmm, I'd have to write the equations to be sure, but I would think that the sensitivity is monotonic with respect to the feedback resistor values. Increasing the feedback resistance should increase the gain of the bridge output circuit, so it seems more likely that the limiting equation would come from the opamp railing out. For that, we'd need to know the maximum temperature range that is desired to measure, and then that gives us the extremes of the Rs values, which would then constrain the max value of Rs.
And to get close to full rail-to-rail output on the opamp, it would need to be a fairly high quality FET model. (I know they are assuming an ideal opamp in this problem)
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
