Op-amps how could this possibly be a comparator?
  • Thread starter Thread starter Femme_physics
    Comparator
The discussion centers on the classification of operational amplifiers (op-amps) as comparators or inverters. Participants clarify that the first op-amp, despite having a feedback loop, is not a comparator but an inverter due to the absence of negative feedback. The second op-amp is confirmed as a comparator, with the output behavior dependent on the configuration of connected components, such as LEDs. The key takeaway is that feedback configuration determines the function of the op-amp.
  • Understanding of operational amplifier configurations
  • Knowledge of feedback mechanisms in circuits
  • Familiarity with inverting and non-inverting comparators
  • Basic circuit analysis involving LEDs and voltage levels
  • Study the differences between inverting and non-inverting op-amp configurations
  • Learn about feedback types in operational amplifiers
  • Research the behavior of comparators in various circuit designs
  • Explore practical applications of op-amps in LED control circuits
Electronics students, circuit designers, and engineers interested in understanding operational amplifier functionalities and their applications in comparator circuits.
Femme_physics
I'm asked which type of op-amps these are
http://imageshack.us/photo/my-images/707/opamps.jpg/I think it's clear the SECOND one is a comparator, but the FIRST one is an inverter IMO. It has a feedback loop. If it has a feedback loop, it can't possibly be a comparator! Am I right or what?
The solution manual my teacher made, had them both written as "comparators" :confused:
No, sorry, you're wrong. :frown:
Look closer, there is no negative feedback, no feedback of any description, in fact.
There are inverting comparators, and there are non-inverting comparators.
where R1 is connected- that's not feedback?
R1 just goes to earth. Feedback requires some of the output to feed back to the input (to the (-) input for negative feedback).
(If you ever see positive feedback (i.e., back to the + input) then that makes a comparator.)
Duly noted, thanks for this explanation :-)
I assume that whenver there is a LED after the comparator, only if V+ > V- , then the LED will light up. Is that a correct assumption to make? Also in my specific case?
The output that lights the LED is dependent on where the LED's other pin is connected. :smile:
If the LED is connected between output and ground then it will light up when the output goes high.
In your case, the LED is connected between OP-AMP output and +Vcc, meaning that when the output is high, there will be not much voltage across the LED.
So ...
That clears it :) Thank you
  • · Replies 44 ·
  • · Replies 59 ·
