Opamp circuit for Vout = 2v1 - 3v2
  • Topic: Engineering
  • Thread starter Thread starter Squizzel
    Circuit Opamp
6 replies · 10K views
Squizzel
Design an Opamp circuit for which the output voltage will be of the following form
Vout = 2v1 - 3v2
Check with Multisim
We have only learned the basics of Opamps thus far, so I am confused with the question. This is asking for 2 opamps with the first one a gain of 5 and then the second with a gain of -3?
So I would calculate the first opamp with a gain of 5. would that mean that V2 is 5x what ever v1 is?
No, they want a single op amp circuit.
Hint: design the negative section first: Vo = -(Rf/Ri)Vi, then add a voltage divider to the + input to reduce the + gain to 2.
Ok so for the v2 I got -R2/R1(v2) so that would be -3/1 so for v1 I get 1+3/1 * R4/R3+R4
So that means it needs to be 1/2 so all of the Rs must be 1?
So R2 = 3R1, right? So how can all the R's be the same?
For the + input pin you'd get 3+1 = 4 as you state. So what voltage divider do you put at the + input pin to get an overall + gain of 2? You gave the answer: 1/2. So what are your choices of the voltage divider resistors?
Question - did you cover offset current compensation yet?
We haven't gone over what offset current compensation is actually. I am also not sure what exactly a voltage divider is. But as to the question, I meant that the R3 and R4 would be 1k, not all of them.
Are you supposed to turn Vs2 off to calculate Vs1?
The output of a linear circuit can be found with superposition.
Total output = output due to Vs2 with Vs1 zero + output due to Vs1 with Vs2 off.
That's why you can place all of this on one op amp.
Yes. But 'turning off' means zero volts, not an open input!
Your choice of 1K for R3 and R4 is OK. When you get to offset current compensation you will find that R1||R2 should = R3||R4. You can do this and still have R1 = R2.
