Operation of a P channel MOSFET
  • Thread starter Thread starter akhil123
    Channel Mosfet
The operation of a P channel MOSFET requires that the drain-source voltage (Vds) remains less than zero, meaning the source must be positive relative to the drain. This is essential for proper carrier flow from the source to the drain, as the carriers in a PMOS channel are holes. While conduction in the reverse direction is technically possible, it is not advisable for discrete devices due to the presence of a parasitic body diode that becomes forward biased under reverse conditions, leading to potential damage. In integrated circuits, the body can be connected to a different potential to maintain the body diode in reverse bias.
  • Understanding of P channel MOSFET operation
  • Knowledge of carrier types in semiconductor physics
  • Familiarity with parasitic components in MOSFETs
  • Basic concepts of integrated circuit design
  • Study the operation principles of NMOS and PMOS transistors
  • Learn about parasitic body diodes in MOSFETs
  • Explore synchronous rectification techniques using MOSFETs
  • Investigate integrated circuit design strategies for MOSFETs
Electrical engineers, semiconductor device designers, and students studying power electronics and integrated circuit design will benefit from this discussion.
akhil123
Why is it that a P channel MOSFET is always operated with Vds < 0 i.e source positive with respect to the drain? The book says that carrier always needs to flow from the source to the drain, but would the reverse operation harm the MOSFET in any way? Please explain. Thanks.
What is the carrier in the PMOS channel? What needs to happen in order to form the channel? Compare with an NMOS channel and I think you'll have an answer.
Conduction in the inverse direction along a MOSFET channel is generally possible. This is utilised in some types of synchronous rectification, and also in some analogue switches.
What is not possible, at least for most (all?) discrete devices, is for the MOSFET to block a large reverse drain-source voltage. This results from the parasitic body diode, which is reverse biased in normal operation, but will conduct if the polarity is reversed.
The situation of a MOSFET inside an integrated circuit is different, because it may be possible to return the body to a remote potential, so as to maintain the body diode reverse bias.
19K
  • · Replies 49 ·
