Optical-EME for licensed amateur radio operators
The discussion centers on a proof-of-concept for Earth-Moon-Earth (EME) communications using optical frequencies, specifically a one-watt green laser diode for "moon bounce" experiments. Participants discuss the technical challenges of detecting reflected photons and the need for precise modulation techniques, including the use of RF chirps and stable frequency references. Concerns about atmospheric interference and regulatory issues surrounding laser use are also raised, emphasizing the complexity of operating within legal frameworks. The feasibility of using alternative light sources like LEDs or incandescent lamps is debated, with a focus on the limitations of each in achieving effective communication. Overall, the thread highlights the innovative approaches and obstacles faced by amateur radio operators in exploring optical EME communications.
Hop-AC8NS
I am attempting a proof-of-concept demonstration of so-called "moon bounce" or Earth-Moon-Earth (EME) communications at optical frequencies. Hams are allowed to use ANY frequency greater than 275 GHz, with ANY modulation, and the usual 1500 watt power transmission maximum. I will try to use a one-watt visible green laser diode emitting at 532nm +/-10nm, synchronously amplitude modulated and the reflected photons synchronously demodulated. Statistical photon counting and binning are required to "see" the reflected "tagged" photons from a two kilometer diameter area illuminated on the surface of the Moon. More information can be found at this public-facing discussion group: http://optical-eme.groups.io
I am reaching out in this forum for help with the optics associated with the transmitter and receiver design. Comments on the electronics I will design and use are also welcome, but I don't want to hijack PF for that purpose.
73,
Hop AC8NS
Likes Klystron, Greg Bernhardt, Baluncore and 1 other person
Welcome to PF.
I would suggest that the laser diode be on-off modulated with an RF chirp from a DDS that covers a wideband. The received data can be multiplied by the transmitted data, which is both synchronous detection and down conversion. You will need a stable clock, such as a GPS disciplined frequency reference, so the transmitted and received data can maintain low phase noise.
Take the FFT of the TX*RX product, so frequency will give you range. If the FFT has one million samples, you will get a noise reduction, due to transform gain of; √n = 1000 times.
A low pass filter will eliminate atmospheric backscatter, while things at the distance of the Moon will fall in a particular frequency band proportional to range.
Lasers, aimed at retroreflectors on the Moon, transmit PRBS "ranging codes" that enable precise transit times to be measured. https://en.wikipedia.org/wiki/Gold_code
Optical DX on Earth between mountains, uses LED, not laser sources because the laser light rapidly looses collimation in the atmosphere, so 150 watts of LED with a lens is actually more productive than laser.
Likes Klystron, DaveE and Tom.G
Have you checked out the other regulatory agencies? CDRH is the most common one in the USA (Also IEC 60825-1). I can't help because:
1) I only knew the manufacturer requirements for class IV lasers, not the user requirements.
2) It's a bureaucratic quagmire that I never really want to deal with again. Especially not for free.
If you try to do a laser light show in Las Vegas with your HAM license, it won't go over well.
Still, it's not impossible. I believe you can do it.
Maybe start here?
https://www.fda.gov/media/81404/download
BTW, historically, this sort of laser is a Q-Switched (pulsed) laser. It's either the peak power, or more likely, the pulse energy that counts, not so much the average power. There are just too many losses in the signal path for a CW laser signal to be detected.
A laser is really not that good a source of light once it has passed through a few hundred metres of atmosphere. If the light source is from a bank of LEDs, each with a Fresnel lens, all that fear of lasers, and the bureaucratic regulations, can be dismissed, and you get a better S/N.
Optical EME to the antipodes, like optical DX, will need to be aimed close to the horizon. The problem then is narrow-minded people, seeing the unusual coloured light, and reporting it to the police because they don't know what it is. In Tasmania, we were advised to inform the police before operating, to confirm it is NOT a laser, so they could ignore the flood of callers to the emergency number.
I think there is a retro reflector left on the Moon by the Apollo missions.
There is, but it is not actually a true retroreflector.
It has an orientation and an angle of cut that reflects the light from where it came from, to where that same point on Earth will be, when the light finally returns to Earth.
Likes Hop-AC8NS and Borek
Not in the USA. CDRH doesn't regulate lasers, it regulates "radiation-emitting electronic products". When you get to calculating the nature of the radiation (divergence, wavelength, power, energy, etc.) then the results are different, but there are still applicable regulations to pay attention to. This makes sense to me since, except for some beam characteristics, there isn't too much difference between an LED and a semiconductor laser.
But, honestly, it's kind of a mess, because the States regulate use too. I wouldn't ever claim to really understand it. If it's bright enough to do this job, there will be safety regulations to deal with here.
Yes, the atmosphere is a huge issue. The real advantage of lasers is the very high pulse energy, or peak power, of Q-switched lasers compared to LEDs. But it sounds like the OP isn't interested in pulses since he wants really high bandwidth comms.
A possible work-around is use an incandescent lamp.
Both 1000W and 2000W are still available:
http://www.google.com/search?hl=en&q=2000+watt+incandescent+lamp
They are used in theater spotlights and projectors using an 8 inch dia. Fresnel lens.
[edit] And often a parabolic mirror behind it with the lamp at its focus.[/edit]
Please keep us updated on your results/non-results!
Cheers,
Tom
High BW requires one retroreflector be used. Since the scattering from the moon's spherical surface is spread over about 10 milliseconds, the reflected broad beam illumination will result in a BW of maybe 1/10 ms = 100 Hz.
To increase the BW would require a narrower illumination beam, and a bigger telescope, to examine only the nearest patch, with minimum curvature, on the Moon's surface. The BW limit will be determined by the surface topography of the scattering area employed.
The scientist Hanbury-Brown did work on the light from binary stars and its fluctuation. He used a 931A photomultiplier tube at the focus of a wartime searchlight. This tube can detect individual photons. Maybe a searchlight itself would be a suitable light source - it is an arc light in a 1 metre reflector. I also understand that the Moon makes continuous small movements which disturb the incoming signal. We know that bandwidth and power can be traded, so I wonder if a very fast transmitted packet could get through unscathed, as its duration is shorter than the mechanical movements of the Moon. Of course, this requires a lot of bandwidth and hence a lot of power.
Not powerful enough. Remember the radar problem of signal strength deceasing as the 4th power of target distance. You also have to go through the Earth's atmosphere twice. The broad spectrum of an incandescent is an issue for signal attenuation and detection difficulty compared to narrow spectrum lasers/LEDs. Also VERY hard to modulate at high frequencies.
Not looking for wide bandwidth. Not (deliberately) using the three arrays of corner-cube retroreflectors. The largest array (A15) has an effective aperture of less than 0.5 m2, useless for communication purposes, but small enough to define its location for, say, Apache Point Observatory Lunar Laser-ranging Operations (APOLLO) in New Mexico. You should read the paper this group released describing the operation in detail. Not interested in measuring the distance to the Moon. Not interested in transmitting picosecond pulses twenty times per second with an average power on the order of one hundred to three hundred watts. Not interested in frequency doubling a Q-switched Nd:YAG laser to create a green probe beam. Cannot afford even a surplus Hollywood search light, with or without arc source. This is a problem in small-signal recovery, not brute force.
Hams are allowed up to 1500 watts transmitter power to their antennas, which in my case is a cheap "beginners" model 102mm refractor. Zapping its lens with 1500 watts is a non-starter. Also doesn't mean that is necessary for optical-EME comms. FCC also says hams must use the minimum amount of power necessary to communicate. I estimate the one watt is doable, but it will take perhaps ten minutes tracking a small (two kilometer diameter) illumination spot on the Moon to collect enough photons. This is the size of the illumination area for ANY diameter laser beam aimed at the Moon.
The Earth is surrounded by a hollow spherical concave-convex variable density atmospheric lens. This lens causes about one arc-second of divergence of the collimated beam as it leaves the atmosphere. From the POV of the Moon, every collimated source is a point-source because of the vast distance. The geometry is simple: calculate the spread of a collimated beam of light on its journey to the Moon if it spreads one arc-second on its way to getting there. Compare this area to the effective area of the A15 array. That's how much the laser power is attenuated when it is bounced off A15 to measure the distance to the Moon. Not interested in doing that. For optical-EME comms, photons coming from the entire illumination area must be detected and counted. This requires "tagging" the illumination photons to distinguish them from the regular photons reflected from other light sources: earthshine, starshine, sunshine. Lots of other shine to reject. A narrow-band optical filter will help suppress most of this backgo
So, your suggestion to use a search light lens is spot-on. But totally impractical for amateur radio. Hams are notorious penny pinchers. I grew up that way in the 1950s as I tried to pursue a budding electronics hobby. I raided the dumpsters behind radio and TV repair shops for discarded chassis and "slightly used" electron vacuum tubes. I can "pinch" and Indian Head penny so hard that his feathers fall off.
Today, in retirement, I have inherited a Celestron 102GT Computerized Telescope from my younger brother who died in Sarasota FL ten years ago. The "seeing" here in Venice FL is not quite as bad as the seeing in Sarasota (fewer bright lights) but it is generally quite awful. I thought I would give it a try anyway. The arrays of corner-cube retroreflectors were my inspiration, but after doing due-diligence research I realized that hams don't need them, and probably cannot use them, for communication purposes.
Hams have been using the Moon as a passive reflector of radio frequencies (VHF, UHF, and microwave) since the 1950s. Weak-signal digital signal processing is the de facto method used today to modulate and demodulate their signals. There is a group on the Internet devoted to exploring and extending this technology. They are all standing on the shoulders of Claude Shannon, as do I.
The quantum photon detector of choice is an avalanche photo-diode detector (APD). A ham friend in Australia (Rex VK7MO) uses a largeish one (US$ 500) for his line-of-sight and "cloud bounce" optical comms receiver. He collects light transmitted from an array of LEDs with a single large Fresnel lens focused on his expensive APD. I want to do the same type of "receiver" using an array of Fresnel lenses to collect photons and focus them onto the photo-cathode of a 1P21 PMT. This PMT is "new old-stock" or NOS that I acquired many years ago, still in its original box. I only have two of them, but am willing to share with another ham who is seriously interested in optical-EME.
Rex VK7MO in Australia ran across this problem when he was doing line-of-sight and so-called "cloud bounce" comms with a large, red, high-power, LED array. Folks would see the red glow on the horizon and "alert" the authorities to the "forest fire". He solved the problem by switching to near-infrared LEDs.
Likes Klystron and DaveE
I work with and support several amateurs in southern Tasmania, so I know Rex. By moving to near IR, they have left the shorter wavelength optical records open for others.
I have a box of 50 or so good PM tubes in the shed if you need some, they are from a medical gamma camera. I believe they were designed to work with scintillators, at the blue end of the spectrum.
As you are in Florida, many years ago while serving at Range Group out of Nellis AFB in Nevada we participated in a Florida-based government electronic equipment salvage program operated from Patrick AFB (DoD) and Cape Canaveral (NASA).
We liberated loads of working test equipment and surplus once-state-of-the-art gear paying only shipping costs. Leftover equipment was sold to the public at low cost. I still own a small Tektronix O-scope and nice pair of Zeiss binoculars purchased surplus at a Nellis "flea market" open to locals with base access.
Given your frugality, you might find a contemporary program.
Likes Hop-AC8NS and dlgoff
I was an Air Force officer's Brat, along with my younger brother. Dad retired to Dayton OH, home of Hamvention, after flying for SAC on the three-man crewed B-47 bombers as their radar navigator/bombardier. He was a bombardier on B-17s during WWII, a POW, and a career officer after VE-Day. So Hamvention and Hamcation (near Orlando FL) are my "go to" places to find electronic "boat anchors" and other fine stuff. There are many local "ham conventions" with "tail gate" vendors from which to pursue the hobby. For common components, my go-to source has been Amazon since vendors such as Radio Shack are no longer around.
DaveE said:
Excellent resource! Our next door neighbors (who have since moved) got into trouble a few years ago when they put up some very bright Christmas decorations. They got a visit from the Sarasota County Sheriff who told them they had to take 'em down. Well, duh! We live on one of two takeoff and approach paths to Venice Airport, so its no wonder someone noticed. But, yeah, there is a form I need to submit for FAA approval before I can point a laser at the Moon. Also need to (perhaps) coordinate with Space Force as they are very sensitive about what happens to their assets in orbit. They will issue "shutter" commands to Government entities, and civilian entities should also comply on a volunteer basis, but it is the FAA that is "in charge" of skyward-pointing lasers. And I want to check back with the FCC to make sure hams are still allowed to operate at any frequency greater than 275 GHz. All this "paperwork" is absolutely necessary as we get tons (literally) of Snowbirds flying in every winter. The are all mostly gone by Easter, but the Venice Airport is popular with private aviation.
Thanks, but I will stick to my two 1P21 PMTs for the proof-of-concept. If successful, an amateur radio operator who wants to build an optical-EME rig will probably do their own scrounging of a suitable PMT or APD.
I am going to investigate using a GaAs PCSS as a photon detector. In a previous life (before retirement) I got to know these remarkable devices rather well. They are photo-conductive devices in the ordinary sense, i.e. no semiconductor junction. But if biased above about four kilovolts per centimeter they will go into avalanche conduction after a photon "triggers" them into conduction. Because of the extremely high electron mobility in the GaAs crystal lattice they turn on very fast (picoseconds), and stay turned on, labeled lock-on operation by their inventors at Sandia National Laboratories, until the current drops below a threshold value that commutates conduction. The PCSS devices we made conducted mainly across their surface in a "lightning like" discharge, but a photo-sensor would probably need to have a thin epitaxial film grown on a GaAs substrate, which is how hetero-junction bipolar transistors are manufactured for use in high-performance integrated circuits.
I used to electrically isolate those devices by injecting oxygen ions at various energies through apertures in a thick mask, applied by our customer to their integrated circuits on a 100mm wafer. Lost that job when they went to a larger wafer that we could not implant. So, at age 70, I retired.
Perhaps a "passivization" layer could first be grown on a semi-insulating GaAs wafer, followed by a thin layer that performs the photon detection function. This is waaay above my level of incompetence; even our customer had a third party grow the HBTs on a bare wafer.
I cannot afford a commercial APD, so I will stick with my pair of PMTs and hope I don't damage the spare. But thank you for the offer. How much would you charge to let one of those blue-sensitive PMTs go?
They are optimised for a gamma camera, so may not be good for your application.
Photonis. Type XP5312/SN. PH:40 pC. PHR:8.7% Made in France. Nov 1998.
9-stage PMT, Round tube, 76mm (3") diam.
https://www.diyphysics.com/wp-content/uploads/2013/01/XP5312.pdf
They were recovered when the instrument was decommissioned to scrap, and stored as a community resource. The scintillation plates went elsewhere. Send me a Private Message with your proposed application, explaining why I should donate one or more to your project.
A little early for that, but it's nice that you are willing to donate to a worthy cause. I am at least a year away from sending photons to the Moon. If successful, I would implore you to lend me one for evaluation. If it works out, maybe other hams could arrange something with you. I would want to see a commitment from them first that they are serious about optical-EME. In the meantime, I'll keep plugging away. Microscope should arrive tomorrow from Amazon. Anxious to see if I can create microscopic holes (1 - 2 µm diameter) for my spatial filter. Any suggestions for that? I am going to try to discharge a capacitor into a pulse transformer to create a spark to punch holes in aluminum foil. Did this years ago with an old Ford spark coil (the one in a wooden box with two HV terminals on the top and a vibrating interrupter on the end) to create "invisible" holes in my mom's cigarettes, ruining the "draw" and making them impossible to smoke. IIRC, Mother did not appreciate her budding genius child.
When I was operating the Tandetron particle accelerator I had a gamma ray detector, probably much like yours. It was a chrome-plated cylinder with a scintillation crystal and some sort of photo-detector inside. We were supposed to zap targets with various ions and look for the characteristic radiation peak that occurs at specific ion energies. This was to "calibrate" the energy imparted to the ions by the accelerator. For what I was doing (implanting oxygen ions to various depths in GaAs wafers) the exact value of energy was less important than the dose. I wound up putting it on the shelf after checking to make sure it actually worked. I was used to having to work with leftovers and hand-me-downs from previous employments.
The optical-EME QSO will probably have to occur over two or more nights of Lunar viewing because the returning photon flux is quite small. This is possible because the transmitted bit sequences are transmitted for a finite duration in synchronism with a GPS-disciplined oscillator controlling a UTC clock. Except for a delay, that varies slowly over the course of an evening as the Earth-Moon distance changes, after accounting for that delay the expected position of each bit in the message is known a priori.
This means statistically up-counting received noise plus signal photons into bins, synchronized to UTC time, and then down-counting noise photons, in the same bins during an equal-length "silent" interval after the message is transmitted, results in a signal-to-noise ratio improvement that is a function of the square root of the number of message cycles transmitted.
Depending on transmitter power (affects the number of photons per second transmitted to the Moon) and the area of the receiver aperture (affects the number of photons per second accepted on Earth for photon counting), the number of message cycles could be as little as just one (humongous transmit power, Palomar-sized receiving aperture) or many millions of message cycles (peanut-sized power, smallish receiving telescope).
Either way, it all boils down to patience. Some hams will have it; some will not. Here near the Gulf Coast of Florida the "seeing" is generally terrible. I also want to "shoot the Moon" near its local zenith for these proof-of-concept trials. That probably means it could take me a month of moonlit nights to receive just one message! Another ham, more favorably located, might be able to receive the same message in only a few minutes. So, the effective data rate is extremely variable.
During the half-second transmit interval (followed by another half-second of non-transmission) the laser beam can be on/off modulated (OOM) extremely fast with the right equipment. Megahertz modulation rates are possible, but probably not by pulsing a laser diode on and off. The affordable laser diodes take time to "warm up" before they reach a stable internal temperature. During this warm up interval, the diode current must be rigidly controlled and ramped up to prevent destroying the laser. Because of this warm-up time, which must be repeated each time the laser diode is allowed to cool down, I plan to leave the laser diode on all the time and amplitude modulate the laser beam further down the optics train.
One idea I want to test is using a piezo-electric transducer to block and un-block the laser beam. This would occur by placing a movable vane at the plane of a pin-hole spatial filter. This filter consists of a microscope objective that accepts the incoming laser beam and focuses it to a small spot at the plane of the pin-hole aperture, used to extract a TEMoo beam from the multi-modal diode-pumped solid-state (DPSS) laser beam. That should be good for a few kilohertz with bit transitions possibly occuring every millisecond during the 0.5 second transmission interval. So, five hundred bit transitions possible per message. More if the modulation frequency can be increased.
Another OOM (on/off modulation) method comes to mind: Faraday polarization rotation between two Nicol polarizing prisms, using an optical cell holding a substance with a suitable Verdet constant. Another polarization-dependent scheme does this with high voltage instead of high current through an inductor: a Pockels cell. A disadvantage of using polarization to modulate the laser beam is half the power is immediately thrown away in polarizing the laser beam. Another problem is the high voltage required to switch the Pockels cell. And for a DIY project, probably neither scheme is acceptable. So I will try the mechanical interruption of the laser beam technique first.
This topic doesn't seem to have garnered much attention, but I did seem to observe some comments as to why it won't work, and therefore no need to waste any more time discussing how to do the impossible. When I was a working engineer, and before that, a working technician, I and many of my colleagues tried to follow these instructions: The difficult we will do immediately. The impossible will take a little while longer. It didn't always work, but we kept on trying until the money (or the time) ran out. This is my "bucket list" project. Learning how to fly an airplane is on the list, too, but this one is at the top of the list. I'll probably skip the sky-diving lessons...
