Optics - Angular Magnification
The discussion centers on calculating the angular magnification of a compound microscope with given focal lengths for the eyepiece and objective lenses, as well as their separation distance. The initial confusion arises from differentiating between total magnification and angular magnification, with participants clarifying the formulas involved. The total magnification is related to both angular and lateral magnification, prompting questions about how to compute lateral magnification in a two-lens system. Participants emphasize the importance of using the object-image relation to determine the correct distances for calculations. Ultimately, the conversation highlights the need for a clear understanding of the relationships between the components of the microscope to arrive at the correct angular magnification.
Hyperfluxe
The eyepiece of a compound microscope has a focal length of 2.50 cm and the objective has a focal length of 1.5 cm. The two lenses are separated by 17 cm. The microscope is used by a person with normal eyes (near point at 25 cm). What is the angular magnification of the microscope?
a) 283 x
b) 145 x
c) 97 x
d) 113 x
e) 242 x
Angular Magnification = Near point / f (eye piece) = 25cm / f (eye piece)
Total magnification = 25cm(s1') / (f1f2)
At first, I just thought it was asking for total magnification and got 113x, which is wrong. I know that the angular magnification is 25 / f (eye piece) so 25/2.5? Clearly not right. Perhaps I need to use the object-image formula (1/s + 1/s' = 1/f) to derive more information, but I'm not sure how. Help would be appreciated =)
Why did you use 25cm for the near-point in the formula?
How may the other two measurements be used?
Do you know how the total magnification is related to the angular magnification?
I used 25cm because that is the normal near point, and it says it in the problem statement. The total magnification = angular magnification * lateral magnification, where lateral magnification = s1'/s1
Since I know that the total magnification is 113.333 (as calculated in my original post), I just have to divide by the lateral magnification to get the angular magnification. I don't know which measurements to use for lateral magnification though...
<checks> Oh so it does - well done ;)
How would you normally compute the lateral magnification in a system of two lenses?
Using the object-image relation formula (1/s + 1/s' = 1/f), the image from the first lens becomes the object of the second lens. I tried doing that, but I'm not sure which lens acts as the object, and would the first object distance be 17cm?
You are doing well - see how these questions refine the problem by stages?
Which lens gets the light from the actual object first?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
