Optimal distance to accelerate projectile
The discussion focuses on determining the optimal distance for coils in a mass accelerator project. It highlights the balance needed between coil proximity and the effective acceleration of the projectile. The ideal setup allows the coils to exert sufficient force to initiate movement without losing influence due to excessive distance. Experimental methods are suggested as a way to find this optimal distance, although mathematical calculations and numerical simulations are acknowledged as more complex but possible. Overall, the conversation emphasizes the importance of both experimental and theoretical approaches in optimizing coil placement for effective projectile acceleration.
NeutronFusion
Hi! I am recently involved in a project with a friend. We are trying to build a mass accelerator and thus, I figured that I need to know the optimal distance to place the coils and the winds on the coil. My thought was that if we place the coils too close, the coils wouldn't accelerate the projectile very far, but if it is too far, the coils won't have much influence on the projectile. Can someone please help with this? Thank you! Providing a way to figure it out would be nice!
At the ideal point, the force from the coils is just sufficient to get the projectile moving, assuming you can power your coils long enough. This should be easy to figure out experimentally.
Ok but is there anyway to mathematically calculate it?
With numerical simulations, sure. Simulations with magnetic fields influencing ferromagnetic materials tend to be complicated.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
