Optimal division of a matrix for processing
4 replies · 2K views · last reply
sam_wilson
I apologies if this is in the wrong place!
I'm a Computer science person with a keen interest in maths and occasionally the two topics cross paths.
I am working on an matrix manipulation package in Java/C but seriously require some help with the maths, I am witting into it, parallelization at the moments and i am looking for a solution to this problem below, Hopefully if there is a method to calculate this in linear time i would be great full, if not a heuristic algorithm will have to do
Given a Matrix NxM find a solution x, y which meets the following constraints
z is a Real Positive Interger which is greater than 0 (Set by some processor loading statistics, not variable and could be treated as a constant)
x * y <= z
x mod n = 0
y mod m = 0
n, m, x, y, z > 0
if there is a solution to this, x,y will be the dimensions of a submatrix which will be able to be processed independently of the rest.
Initially I though this would be a trivial Linear programming solution, But up until yet in my maths career i am unaware of how to express a mod function as a feasibility region. From Some of my scribbles on paper and from some simple benchmarking of the problem in my framework i have discovered that the optimal answer is around the sqrt of z, which is would made scene as so far i have only been trying with square matrices.
This problem if solved would provide a fast way of distributing Matrix multiplication across a cluster.
Refinement of one of the constraints
(n/x)*(m/y) <= z
N.BN = n, M = m
Is this really the no brainer, that I think you ask for?
you are looking for multiples of n and m we may call a*n and b*m that fulfill the requirement a*b<=z
So if z>=1 you pick any a < z/2 and b can be chosen as b = z /a
But I think you messed up the modules and you are really looking for: m mod x = 0 This will require prime factorization and you will not find a general linear time algorithm for this.
You are correct i did mess up the modulus constraints opps!
So is the only solution to this problem factorization?
Thanks
