Optimal Total Current for Parallel Loads
  • Thread starter Thread starter MrBrain
    Current Parallel
For supplying power to two lifts operating at 380 V with a maximum current of 13 A each, the total current requirement is indeed 26 A. However, it is crucial to consider local electrical and building codes when determining the appropriate size for the main breaker. The selected cable sizes of 16 mm for the main supply and 10 mm for the lifts are appropriate, but the main breaker size must comply with legal standards. Consulting a licensed electrician is recommended to ensure compliance with regulations and safety standards. Proper adherence to these guidelines is essential for the project's success.
MrBrain
Hey .. !
I hope everyone is doing well.
I'm working on a project and i have to supply electric power to two lifts. Each lift is operated with 380 V and iMAX of something around 13 A. I've selected a cable ( 16mm ) to provide the electric power from the source to the main breaker. Then, a cable ( 10 mm ) will go from the breaker to each lift.
My first question is which size should I use for the main breaker? The second question is, what amount of total current should I provide for both lifts? Can I just add the two currents up and end up with a total current of 26 A?
~ Any help is so appreciated ~
MrBrain ..
You are asking the wrong kind of questions. You should be asking about local electrical and building codes that specify the legal requirements for wiring, and ask where to find a licensed electrician.
Likes MrBrain
I see, so what requirements are to be specified first?
Actually I'm a trainee engineer. And this is the first task by my supervisor.
Thanks ~
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
