Optimization of the Area of a Triangle
reigner617
Find the area of the largest isosceles triangle that can be inscribed in a circle of radius 4. Solve by writing the area as a function of θ
A=1/2 (bh)
Given the side h and the hypotenuse 4, we can find the base of the smallest triangle to be sqrt(16-h2) which means that the base of the largest triangle is 2(sqrt(16-h2)). Its height can be considered as h+4, which would give a side length of sqrt(8h+32). So the area would be:
sqrt(16-h2)(h+4). However, they want it to be solved in terms of theta, which is the part that I am not sure of.
can you express h in terms of theta? express the sides of the triangle in terms of theta.
for convenience, I'll say c= sqrt(8h+32). Would it be correct if I said the height was c(sinθ) and the base of the largest triangle 2c(cosθ)?
I don't know where you got ##c = \sqrt{8h+32}##. It would help if you labeled your picture. If you note that the angle between the two sides that you have labeled ##4## and ##h## is ##2\theta## that will help you get the two legs of that little right triangle in terms of ##\theta##.
LCKurtz said:
If you note that the angle between the two sides that you have labeled 4 and h is 2θ
How did you determine that angle to be 2θ?
And to answer your question, I used the pythagorean theorem to find one of the side lengths
From what you have above, it seems that the height ##(h+4)= Ccos(\theta)## Where, as you mentioned, C is the length of the hypotenuse. You should be able to solve that for h in terms of theta and plug that into the formula for area.
If I solve for h, that would give me Ccosθ-4=h. Is it ok to have an extra variable (C) in there?
That upper triangle is an isosceles triangle with equal sides of ##4##. Its angles are ##\theta,\theta, 180 -2\theta##. Label them. The supplement of that last one is the angle you are looking for.
Once you have that you have both ##h## and the other leg in terms of ##\theta##.
Are these labeled correctly?
If those are correct, can I use the law of sines such that
h/(sin90-2θ) = 4/sin90
h = 4(sin90-2θ)
h=4(1-2θ)
h=4-8θ
You mean ##h/\sin(90-2\theta)##. Parentheses are important.
h = 4(sin90-2θ)
h=4(1-2θ)
h=4-8θ
Which is why you then get nonsense. Also, it is silly to use the law of sines given the picture. You have adjacent sides to the ##h## and ##4## for the angle ##2\theta##. What trig function does that give you for ##h##? Similarly for the other leg.
That would be cos2θ=h/4
4cos2θ=h
Yes. And what about the other leg?
Well since h=4cos2θ, couldn't we just substitute it into the expression to get sqrt(16-(4cos2θ)^2) for the base?
That looks a lot like ##4(\sqrt(1-\cos^2 2\theta)##. It seems like the long way to get to the opposite side from the angle ##2\theta## with hypotenuse 4.
Yes, you could, but you would want to simplify it. But, again, it is silly to do it that way. What trig formula uses opposite/hypotenuse?
That would be sine. So if I were to use that, I would get sin(2θ)= [sqrt(16-(h^2))]/4. But I don't understand what this would accomplish since we're trying to look for max area, and that involves base and height
Ahhh never mind. I think I see it now
So instead of calling that leg ##\sqrt{16-h^2}## you can call it ##4\sin(2\theta)##. Now you have both legs of that little triangle in terms of ##\theta##. Now you can express the area of the original big triangle in terms of ##\theta##. Then you are ready for the calculus problem of maximizing the area. Too bad the trig is holding you back so badly. Perhaps you should review it.
So A= 1/2 (4cos(2θ))(4sin(2θ))
= 8cos(2θ)sin(2θ)
deriving this, we get A'= -16(sin(2θ))2 + 16(cos(2θ))2
setting it to zero, we get θ= 30 degrees
substituting this for θ we get 2(sqrt(3))
However, another part of the question was solving the area in terms of h (I used A= [sqrt(16-h2)](h+4)
Following the same steps as I did for the one above, I get h=-4 and 2. h can't be -4 because if we use it, h+4 would go to zero, and the whole area would be zero. So h can only be 2.
Substituting this for h I get 12(sqrt(3))
What am I doing wrong?
= 8cos(2θ)sin(2θ)
Isn't the height of your triangle ##4+4\cos(2\theta)##? And why the 1/2 out in front?
Ah thank you for pointing that out. It works now. The 1/2 was put there by mistake because I was thinking fo 1/2 (bh). Thank you for all your help
It works now? Given what I have seen so far, I doubt it. How about showing what you did to finish?
I used 4cos(2x)+4 for the height so A=4sin2x(4+4cos2x). I derived that and still got 30 for the angle. Substituting that into the Area formula, I get 12(sqrt(3)) which is the same as the answer I got when I solved in terms of h
##4\sin 2\theta## is 1/2 base and ## 4 + 4 \cos 2\theta## is the height.
Your method of taking the derivative and setting it to zero is good. The best option is to rearrange the derivative as a quadratic function of ##\cos 2 \theta##. h=-4 will be your minimum (zero) and another value for h will be your max. Both should be solutions of A'=0.
Good job. I presume you have noticed that the optimal shape is an equilateral triangle.
