Optimization to find parameters?
  • Context: Graduate
  • Thread starter Thread starter johnpjust
    Optimization Parameters
The discussion revolves around optimization techniques for estimating parameters in a regression context, specifically focusing on minimizing error in predicting weight based on measured variables such as pressure and volume. Participants explore various methods for solving the optimization problems presented and discuss the statistical significance of the parameters involved.
  • One participant outlines two optimization problems involving parameters a and b, which are intended to minimize the error in predicting weight based on pressure and volume.
  • Another participant suggests using partial derivatives to find the minimum of the function and proposes setting the derivatives equal to zero to solve for a and b.
  • A participant expresses concern about the potential need for iterative solutions due to the complexity of having many equations with only two variables.
  • There is a suggestion that the error function may have a closed form solution, although this is contested by another participant who believes it may not be straightforward.
  • One participant emphasizes the statistical nature of the problem, comparing it to regression and highlighting the importance of understanding the significance of the parameters after solving for them.
  • Another participant identifies both minimization problems as standard multiple linear regression problems and mentions that statistical packages can estimate the values of a and b while providing insights into their statistical significance.
Participants generally agree that the problems presented are related to regression and minimization of error, but there is disagreement regarding the necessity of iterative solutions and the existence of closed form solutions. The discussion remains unresolved on these points.
Participants express uncertainty about the complexity of the optimization problems and the implications of having many equations with only two variables. There are also unresolved discussions about the statistical significance of the parameters and the methods for estimating them.
johnpjust
Hi guys, I'm a bit rusty on optimization, but i remember enough to be able to setup some problems that I am facing in my research, and would like to know how to go about solving such problems in general. The equations below may have more variables and be in slightly different forms at times, but ultimately we have measured variables (such as pressure and volume, and ground truth of weight) and need conversion parameters (such as a and b). Please be detailed on a few different methods if possible and the reasons for them. Also, if there is a way that I can see the "significance" of the parameters (statistically) and/or the affect they have on reducing error, that would be stellar! Thanks!
minimize:
[itex]^{m}_{j=1} \sum(^{n}_{i=1} \sum((a + b*[pressure]_{ij})*[volume]_{ij}) - [weight]_{j})^{2})[/itex]
and
minimize
[itex]^{m}_{j=1} \sum(^{n}_{i=1} \sum(a*[pressure]_{ij} + b*[volume]_{ij}) - [weight]_{j})^{2})[/itex]
There are only two parameters a and b which are multiplying all the pressures and volumes, right?
To minimize a function you can just take the partial derivatives with respect to each variable, and set them equal to zero. To use your first example, the partial derivative with respect to a is
[tex]\sum_{j} \sum_{i} 2((a+b*[pressure]_{ij})*[volume]_{ij})-[weight]_{j})*[volume]_{ij}[/tex]
and the derivative with respect to b is
[tex]\sum_{j} \sum_{i} 2((a+b*[pressure]_{ij})*[volume]_{ij})-[weight]_{j})*[volume]_{ij}*[pressure]_{ij}[/tex]
This looks bad but some fairly easy algebra can re-write these both as a*(something) + b*(something) + something. Setting them equal to zero gives two equations in two unknowns that you need to solve (and should be able to solve).
I don't understand the last part, is your error the expression you are trying to minimize?
Hi, yes, I am minimizing the error. But the problem is that I will have many, many equations with only two variables. I am almost certain that this will require some kind of iterative solution. I don't think it has a closed form solution, does it?
edit - ok i understand your last question. This is to be used for estimating weight using measured variables of pressure and volume...but don't get hung up on those. Just think of them as some kind of random variables (statistically) that correlate with the weight. What I'm doing has a strong statistical component so I am trying to minimize the error in my prediction of many weights (think something like regression for an analogy)
Do you mean you have many error functions that you want to minimize? Given an error function such as you posted, it has a closed form solution which is not too difficult to obtain. No harder than finding the closed form solution for a and b in terms of x,y,z,m,n and p in the following:
ax+by+z = 0
am+bn+p = 0
OK, so your overall question is how statistically significant the values of a and b are once you solve for them?
Edit: I think you are right after thinking more about this...since I do have a linear system here...
Both minimization problems are standard multiple linear regression problems. You are trying to minimize the total some squared errors of two models:
weight = a*volume + b*pressure*volume
weight = a*volume +b*volume
For each problem, a statistics package can estimate the values of a and b that will minimize the sum-squared errors. It will also give information of how statistically strong the relationship is and how much is gained from including the a-term and the b-term.
  • · Replies 18 ·
  • · Replies 0 ·
  • · Replies 17 ·
  • · Replies 27 ·
