Optimizing Isosceles Triangle Problem: Find Min. Sum of Distances
The problem involves finding a point P on the perpendicular bisector of an isosceles triangle that minimizes the sum of distances from P to the triangle's vertices. The triangle has a base of length 4 and two sides of length 2√2.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss placing the triangle in a Cartesian coordinate system to facilitate calculations. There are attempts to derive an objective function based on the distances to the vertices. Questions arise regarding the correctness of coordinates and the formulation of distance equations.
Some participants have offered guidance on simplifying the coordinate system and correcting distance calculations. There is an ongoing exploration of the problem with various interpretations of the coordinates and distance formulas, but no explicit consensus has been reached.
Participants are working under the constraints of homework guidelines, which may limit the types of solutions or methods they can employ. There is also a noted discrepancy between participant calculations and a reference answer from a textbook.
ciubba
An isosceles triangle has a base of length 4 and two sides of length 2sqrt(2). Let P be a point on the perpendicular bisector of the base. Find the location P that minimizes the sum of the distances between P and the three vertices.
N/A
Putting this on the cartesian coordinate system leaves me with one vertex, v1, at (0,0), v2 at (2,sqrt(2)) and v3 at (4,0).
The distance between the vertices and P would then be D_1=(2-x)^2+(\sqrt{2}-y)^2 \; \; D_2=(x-0)^2+(\sqrt{2}-y)^2 \; \; D_3=(4-x)^2+(0-y)^2 Their sum is my objective function, so D_t=(2-x)^2+(\sqrt{2}-y)^2 + (x-0)^2+(\sqrt{2}-y)^2 + (4-x)^2+(0-y)^2
I'm assuming that I can come up with a constraint by similar triangles, but this seems like an incredibly obtuse way of solving this problem. Could someone point me to a better direction?
Choose a coordinate system so that the perpendicular bisector becomes your y-axis. That would simplify things.
Hmm, that's a good idea.
So, v1=(-2,0) , v2=(0,sqrt(2)) , v3=(2,0)
Edit: Still number crunching
Okay, I get
D_1=4+y^2, \; D_2=(\sqrt{2}-y)^2, \; D_3=4+y^2
Thus, the objective function, their sum, is D_t=(\sqrt{2}-y)^2+8+y^2
D_t'=6 y-2 \sqrt{2}
Which has a root at y=\frac{\sqrt{2}}{3}
Unfortunately, that is the reciprocal of the book's answer. Where did I mess up?
I think your coordinates for v2 are not correct. if the side length is 2sqrt(2), then v2 would be 2, right?
Also, your values of D1, D2, and D3 are the square of the distances, so you have to take the square root.
Doing that gives me the right answer-- thanks!
Any time man! :D
  • · Replies 24 ·
