Optimizing Knights on 8x8 Chess Board with Integer Programming
The discussion revolves around optimizing the placement of knights on an 8x8 chessboard using integer programming to ensure every square is covered by at least one knight. The initial approach involves expanding the board to a 12x12 grid to simplify constraints, with binary variables representing knight placements and coverage. Participants share code snippets in Julia for implementing the solution using linear programming, highlighting the model's constraints and objective function. A simpler backtracking method is also mentioned, which reportedly finds a solution in a short time. The conversation concludes with a request for clarification on the problem's solution and its underlying logic.
thomas49th
On a 8x8 chess board format an Integer program to optimize the amount of knights required such that every square is covered by at least one knight.
I know of a similar problem where we use duality for the placing 5 queens such that the maximum number of pawns can be placed as to not be covered by the queens, but I don't think we need to us the duality here as duality is useful for problems where by taking the dual, the problem size decreases.
There was a hint to introduce artificial rows (2 either side, so our chess board becomes 12x12). Let's say the board goes from -1 to 10, where 1 to 8 is the original chess board. This may be helpful as if you stick a knight at the corner of the 8x8 board it will cover the 12x12... I think this may somehow reduce some constraints (see below).
If I let x_{ij} be the binary variable which states if a knight is placed on square x at row i, column j
I think I should also introduced a binary variable c_{ij}, which if 1 implies the square is covered by at least one knight.
I have written out the 8 positions a knight can cover with respect to itself i.e: c_{i-1,j-2}. If a knight was placed at (4,4) then one of the 8 spots it covers is (3,2).
The objective function of the program should be
\sum_{j=1 to 8} \sum_{i = 1 to 8} x_{ij}
Some constraints
Other things such as the sum of c over i and j should be at least 64 and the independent row and column sum should be 8.
\sum_{j=1 to 8} \sum_{i = 1 to 8} x_{ij} ≥ 64
Also no knight can be placed outside the original 8x8 chess board. I can only see
\sum_{j=-1 to 0, j = 9,10} \sum_{all i} x_{ij}
\sum_{j = 1 to 8, j = 9 to 10} \sum_{i = -1 to 0, i = 9, 10} x_{ij}
I like to think I can somehow get rid of having 4 discrete regions here.
Any hints of where I can go now? Or is that my linear program?
Thanks
Thomas
Thomas,
Have you ever found the solution to this problem?
Many thanks,
Christina
ChristinaK said:
Thomas,
Many thanks,
Christina
linear programming is too much work.
Simple backtracking gets you the solution in 4 minutes.
00000000
00000000
01111110
00000000
01100110
00000000
00111100
00000000
14 knights. 48 billion recursive calls.
ChristinaK said:
Thomas,
Many thanks,
Christina
This problem made a nice little exercise in Julia. Note that if you don't have Julia installed locally, you can run it for free here:
https://juliabox.com/
Code:
using JuMP
using Cbc
m = 8
mymodel = Model(solver= CbcSolver())
@variable(mymodel, x[i = 1:m^2], Bin)
@variable(mymodel, y[i = 1:m^2] >=0)
X_matrix = reshape(x, (m, m)) # game board with knight positions
Y_matrix = reshape(y, (m, m)) # squares covered by the knights
i_shifts = [ 1, 1,  2, 2, -1, -1, -2, -2]  # [u 1, u 1, u 2, u 2, d 1, d 1, d 2, d 2]
j_shifts = [-2, 2, -1, 1, -2,  2, -1, 1]   # [l 2, r 2, l 1, r 1, l 2, r 2, l 1, r 1]
shift_size = size(i_shifts)[1]
for i = 1:m
  for j = 1:m
    running_sum = 0
    for idx = 1:shift_size
      if (1 <= i + i_shifts[idx] <= m) && (1 <= j + j_shifts[idx] <= m)
        # && == "and"
        # this checks that your reachable position is not off the board
        # if you don't want if stmts, the easiest alternative is to use the padding method suggested by OP
        running_sum += X_matrix[i + i_shifts[idx], j + j_shifts[idx]]
      end
    end
    @constraint(mymodel, Y_matrix[i,j] == running_sum)
    @constraint(mymodel, Y_matrix[i,j] >= 1)
  end
end
@objective(mymodel, Min, sum(X_matrix))
solve(mymodel)
# formatting for a printable output is done below
output = getvalue(X_matrix)
answer_matrix = round(Int64, output)
print("total knights = ", sum(answer_matrix),"\n")
print(isapprox(sum(answer_matrix) - sum(output),0), "\n")
# just a check on floating point nits -- should print "true"
for i = 1:m
  print(answer_matrix[i,:],"\n")
end
Code:
using JuMP
using Cbc
m = 8
for i = 1:m
  for j = 1:m
    running_sum = 0
        # && == "and"
      end
    end
  end
end
solve(mymodel)
for i = 1:m
end
Why de solution is this?
[0,0,0,0,0,0,0,0]
[0,0,1,0,0,1,0,0]
[0,0,1,1,1,1,0,0]
[0,0,0,0,0,0,0,0]
[0,0,1,1,1,1,0,0]
[0,1,1,0,0,1,1,0]
[0,0,0,0,0,0,0,0]
[0,0,0,0,0,0,0,0]
I do not understand the problem yet
