What is the relationship between escape velocity and orbital velocity?
The discussion explores the relationship between escape velocity and orbital velocity, focusing on how an object's energy changes as it approaches a planet. As an object moves from infinity, its kinetic energy decreases while potential energy becomes more negative, leading to orbital motion when its speed matches the orbital velocity. If the object's speed exceeds this velocity, it will escape the planet's gravitational influence, following a hyperbolic path if total energy is positive or a parabolic path if total energy is zero. The analysis concludes that an object with negative total energy can achieve elliptical orbits only by losing kinetic energy. The relationship between kinetic energy and potential energy at a certain distance is also linked to escape velocity, raising questions about the mathematical proof of this concept.
gokul.er137
I am trying to understand the existence of orbits apart from the elliptical one. I have used the following line of thought.
Consider an object moving from infinity towards a planet. The object has kinetic energy alone at infinity. But it develops a potential energy as it comes closer to the planet. Thereby, its kinetic energy reduces. As it comes sufficiently closer to the planet, its kinetic energy reduces. At the radial distance wherein its speed is equal to the orbital speed of the planet, it starts to move around and orbit the planet. But if its speed throughout somehow manages to be larger than the orbital speed then it continues to move away from the planet, suffering only a light deflection.
Thus, I gather that it is imperative that the speed of the object at all points be larger than the orbital velocity. But then, the gravitational force only always tends to infinity. In other words, the gravitational force always affects the object no matter how far away it keeps on going. My analysis is that, if the change in velocity as the object moves closer and farther away from the planet is negligible, then the object movies in a hyperbola. But if the change is not negligible and not larger enough reduce the speed to the orbital speed, then I guess it moves in a parabola.
I am developing on the mathematics to follow this. But I would like to know if my analysis is right.
Thanks in advance.
As your object approaches a planet, wouldn't it get MORE kinetic energy from being pulled towards it?
In a system where you assign zero potential energy at infinite distance, as you approach the planet ,he potential energy becomes negative and becomes more negative as the closer you get to the planet. Thus the potential energy goes down and the kinetic energy goes up.
An object with exactly zero total energy (kinetic+potential) follows a parabolic path.
An object with positive total energy follows a hyperbolic path.
An object with negative total energy follows either a elliptic or circular orbit.)
Since an object falling from infinity cannot have less than zero total energy, it could only enter into a elliptic orbit if it sheds some of its kinetic energy in some manner.
Thanks. I messed up the signs. As you say, If the potential is 0 at infinity as it moves closer and closer to the planet, the potential energy should become more negative. I should however have understood intuitively that kinetic energy increases as an object comes closer and closer to the planet. Thanks to Drakkith too. I will post doubts as they plague me.
I gather that when you say 0 total energy the Kinetic energy exactly accounts for the potential energy at that point. Which implies that the velocity is sqrt(2*G*M/r), the escape velocity for that point. Is there any proof for this?
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
