Orthogonal Matrices: Questions & Answers
Rearranging the rows of a square orthogonal matrix results in another orthogonal matrix, as the rows still form an orthonormal basis. However, a square matrix is not necessarily orthogonal just because its determinant is +1 or -1; a counter-example demonstrates that a matrix can have a determinant of 1 without being orthonormal. The discussion emphasizes the importance of linear independence and the characteristics of orthogonal matrices. Clarifications on logical implications in mathematical properties were also noted. Understanding these concepts is crucial for accurately determining matrix orthogonality.
war485
1. If I got a square orthogonal matrix, then if I make up a new matrix from that by rearranging its rows, then will it also be orthogonal?
2. True/false: a square matrix is orthogonal if and only if its determinant is equal to + or - 1
no equations
1. I think it should also be orthogonal since it forms a basis, and the basis would be the same, but just a linear combination of the previous, right?
2. false, its determinant doesn't necessarily ensure it is orthogonal. So, how would/should I correct that statement?
An nxn matrix is orthogonal iff its rows form an orthormal basis for \mathbb{R}^n (note the symmetry of AA^T=A^TA=I for an orthogonal matrix A). The linear independence of a collection of vectors doesn't depend on the order in which you write them, so the rows of the new matrix still form an orthonormal basis.
Just be careful your language: a linear combination of a basis reads as a linear combination of its vectors, which gives just one vector.
I forgot about the linear independence part of it for #1.
As for #2, I took a counter-example from wikipedia XD
[ 2 0 ]
[ 0 0.5 ]
where its determinant = 1
but the length of each column is not 1 (not orthonormal)
I guess counter-examples should be enough?
Thanks for the help you two. :)
[ 2 0 ]
[ 0 0.5 ]
The statement #2 is (colloquially) of the form "(property X implies property Y) AND (property Y implies property X)" (*). If all you want to do is show that (*) is false (e.g., if you were asked to prove or disprove the statement), then it suffices to show that property Y does not imply property X.
To show that property Y does not imply property X, it suffices to give an example for which property Y holds but X does not. Why? Because it definitively answers the question as to whether Y implies X. There is no guessing about it!
Yea, you're right Unco. I need to work on my logic a bit more. I'm very grateful for your help :D
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
