Oscilloscope: Applying AC Voltage to a Circuit
  • Thread starter Thread starter herbgriffin
    Oscilloscope
To apply AC voltage to a circuit using an oscilloscope, first connect an AC signal source to the circuit. The oscilloscope is primarily used for measuring signals rather than supplying them. After connecting the AC source, attach the oscilloscope probes to the desired points in the circuit to monitor the voltage. This setup allows for real-time observation of the circuit's response to the applied AC voltage. Understanding the distinction between measurement and application is crucial for effective circuit analysis.
herbgriffin
how can i apply an ac voltage to a certain circuit using an oscilloscope and an ac signal...hopefully you can help me
what exactly are you trying to do ? what is the circuit ?
An oscilloscope is for measuring signals/voltages in a circuit, not applying them to a circuit
Dave
um... apply the ac source to the circuit. Then hook up the oscilloscope to wherever you want to read the voltage from.
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
  • · Replies 48 ·
  • · Replies 78 ·
  • · Replies 63 ·
  • · Replies 27 ·
