P-N junction - Need explanation
In a P-N junction, the n-side contains positively charged donor ions, which are neutralized by conduction band electrons. When an electron diffuses from the n-side to the p-side, it leaves behind a fixed positive charge on the n-side and combines with an acceptor ion on the p-side, creating a negative charge. Holes moving from the p-side to the n-side have a similar effect, resulting in charge carrier depletion near the junction. The fixed charges accumulate near the junction plane because that is where donor and acceptor atoms are in close proximity, leading to the formation of a depletion region. This region can be influenced by external bias, affecting its size and the behavior of the junction.
uzair_ha91
"...Recall that the n-side is studded throughout with positively charged donor ions, fixed firmly in their lattice sites. Normally, the excess positive charge of each of these ions is compensated electrically by one of the conduction band electrons. When an n-side electron diffuses across the junction plane, however, the diffusion uncovers one of these donor ions, thus introducing a fixed position charge near the junction plane on the n-side. When the diffusing electron arrives on the p-side, it quickly combines with an acceptor ion (which lacks one electron), thus introducing a fixed negative charge near the junction plane on the p-side. In this way, diffusion of electrons results in the build up of space charge on each side of the junction plane. HOLES DIFFUSING THROUGH THE JUNCTION PLANE FROM P TO N-SIDE HAVE EXACTLY THE SAME EFFECT. (TAKE THE TIME NOW TO CONVINCE YOURSELF OF THAT)..."
There's the problem for me, I'm unable to grasp what will happen when the holes enter the n-side.
Can anyone please fill that in for me?
Can you also explain... "...introducing a fixed position charge near the junction plane on the n-side..." why near the junction plane? Why not in the centre or the side away from the plane?
Thanking in advance...
The donor atom is effectively dissociating into a positively charge ion and an electron which are loosely bound by electrostatic attraction. The electron may diffuse through the lattice, but the ion is fixed in place by chemical bonds to the surrounding atoms. If the electron diffuses into a region rich in acceptor atoms, it drops into the valence band, effectively filling the hole associated with an acceptor atom.
Likewise an acceptor atom dissociates into a negative ion (by accepting an electron) and a hole. If the hole diffuses into a region rich in donor atoms, it combines with an electron and ceases to exist.
Since donor atoms are found in n-type material and acceptor atoms are found in p-type material, the only place where donor and acceptor atoms are nearby is in the vicinity of junction.
This gives you a region near the junction where charge carriers are depleted, although the size of this region can be altered by a bias potential.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
