Full-Wave Rectifier w/ 2 P-N Junction Diodes & Transformer
The discussion focuses on using two P-N junction diodes with a transformer to create a full-wave rectifier, including the need for a circuit diagram and waveform sketches to explain operation. Participants seek to calculate the peak, mean, and RMS currents for a 25V peak output applied to a 1000W resistive load. Initial calculations presented include peak current as 0.25A, RMS voltage as approximately 17.68V, and mean current around 0.016A, but there are corrections regarding the interpretation of voltage and current relationships. Clarifications emphasize using Ohm's law for current calculations based on voltage and resistance. The conversation highlights the importance of accurate terminology and calculations in electrical engineering discussions.
Solidsam
Show how two P-N junction diodes can be used in conjunction with a
transformer that has two secondary windings, to form a full-wave rectifier.
(Draw a circuit diagram including connections to the mains transformer).
Explain the operation of your circuit using sketches of waveforms. (3 marks)
(ii) If the output from your rectifier is 25V(PEAK) at 50 Hz and is applied to a 1000W
resistive load, find:
a) The peak current in the load
b) The mean current (3 marks)
c) The RMS current
how do i solve a,b and c? i know how to sketch the p-n junction.
c) The RMS current
Why don't you post us a sketch of your schematic? I realize you've said you understand that part, but a sketch of the circuit is always a good place to start.
You need to show us your work and a reasonable attempt at the solution before we can help!
1000w should be 1000ohms
Vpk=25/1000=0.25A
Vrms=25/sqroot2=17.68v Irms=17.68/1000=0.0177Arms
Vmean=Vrms*0.9=15.9V Imean=15.9/1000=0.016Amean
Are these result and equations correct? sry don't have a scanner so can't post sketches
Vpk=25/1000=0.25A
You have Vpk = 0.25A. Vpk represents a voltage not a current.
P = I_{pk}V_{pk}
I_{pk} = \frac{P}{V_{pk}}
ok well since i have the mean voltage, rms voltage and peak voltage can i no just use V/R=I
so Vpk/1000ohms=Ipk
then do the same for the rest of them?
so Vpk/1000ohms=Ipk
Oh you where pointing out a typo, not your actual reasoning? (This with regards to the 1000W or 1000 ohms)
