Pair Production Velocity Calculation
The discussion centers on calculating the velocity of a proton and anti-proton pair created by a photon with a wavelength of λ= 6.607×10-7 nm. The energy of the photon is calculated as Ephoton = 3.009 x 10-10 J, while the rest energy of each particle is E0 = 1.506 x 10-10 J. The kinetic energy (KE) is derived as KE = 0.029 MeV, leading to a calculated speed of 2.36 x 106 m/s. However, discrepancies arise when using more significant figures, suggesting a potential relativistic effect that may require different equations for accurate results.
  • Understanding of photon energy calculations using Ephoton = h ⋅ c / λ
  • Knowledge of rest energy calculations with E0 = m0 ⋅ c2
  • Familiarity with kinetic energy equations, specifically KE = 0.5 ⋅ m ⋅ v2
  • Basic principles of relativistic physics and its implications on particle velocities
  • Explore relativistic energy-momentum relationships in particle physics
  • Learn about the implications of significant figures in scientific calculations
  • Study the conversion of energy units between Joules and MeV
  • Investigate advanced kinetic energy equations for relativistic particles
Students and professionals in physics, particularly those focused on particle physics and energy calculations, as well as anyone interested in the implications of relativistic effects on particle velocities.
ikihi
[/B]
A proton and anti-proton are created by a photon with wavelength λ= 6.607×10−7 nm. What is the magnitude of the velocity of the newly created proton and anti-proton pair? Note, the mass of a proton/anti-proton is mp= 1.673×10-27 kg = 938.3M MeV/c2.
Ephoton = h ⋅ c / λ
E0 = m0 ⋅ c2
KE = 0.5 ⋅ m ⋅ v2
Ephoton= 3.009 x 10-10 J
KE=Ephoton - 2 ⋅ E0 / (2)
KE= 3.009 x 10-10 - 2 ⋅ 1.506 x 10-10 J / (2)
KEof either particle= -1.5 x 10-13 J
Google calculator shows 938.3 MeV=1.503E-10 Joules.
if you convert the energy of the photon to Mev and subtract from it (2*938.3 Mev) it will give a positive number
i guss the problem is the mass of the proton missing a lot of digits and the speed of light as well.
like Bandersnatch said if you use the full digits of the mass and speed of light it will give 1.503*10^-10
Likes ikihi
I calculated E0 using E0 = m0 ⋅ c2. So is that the same as the given value?
You are right. I converted both to MeV and it came out to KE = 0.029!
0.029 MeV ---> 4.646 x10-15 J
I calculate that the speed is 2.36 x 106 m/s.
However after using more sig fig digits the answer goes to 0 m/s. Maybe this is a relativistic problem that needs a different equation?
That seems rather unlikely. If you cannot find a mistake please post all your working.
  • · Replies 54 ·
11K
